03-26-2008, 12:48 | #1 (permalink) |
Freak Poster Join Date: Apr 2007 Location: http:// Age: 43
Member: 480132 Status: Offline Sonork: GSM MAMA(1627760) Thanks Meter: 56 | Nokia PC Suit 6.8 + Nokia Software Updater + Cables Drivers THREE IN ONE Nokia PC Suite [IMG]http://i49.*******.com/u/f49/12/09/57/15/untitl10.jpg[/IMG] Nokia PC Suite is a package of Windows-based PC applications developed especially for use with Nokia phones. Depending on your phone model, Nokia PC Suite lets you edit, synchronize and back up many of your phone's files on a compatible PC through a cable or wireless connection. Connection method compatible with your Nokia mobile phone: - Infrared (IrDA) port - Bluetooth via a supported stack: Digianswer Bluetooth Software Suite, - Microsoft Windows XP Bluetooth, or WIDCOMM Bluetooth for Windows 1.4 - Nokia Connectivity Cable DKU-2 (USB) or Nokia Connectivity Adapter Cable DKU-5 (serial) Key features : · Automatic, secure data, information, pictures, and music transfer from phone to phone or phone to PC · Fast, easy connection to the Internet · Connect wirelessly or via cable · Connect by using your phone as a modem · Manage messages, contacts, images, and music · Synchronize your phone and PC calendars · Install Java™-based applications in your phone · Convert ringing tone formats · Play multimedia messages and videos · Send text messages from the PC · Back up and restore phone files · Over 30 languages Requirements for Nokia PC Suite : Available hard disk space: 150 MB (file size approx. 25 MB) Supported operating systems: * Windows Vista x32 and x64 editions * Windows XP Professional x64 edition * Windows XP (Professional or Home Edition) (Service Pack 1 or Service Pack 2) * Windows 2000 (Service Pack 4) Connection methods: USB cable, infrared, or Bluetooth Supported Bluetooth stacks / software: * Windows Vista x32 and x64 editions: o Microsoft Windows Bluetooth * Windows XP x64: o Microsoft Windows Bluetooth * Windows XP: o Microsoft Windows Bluetooth (only in Service Pack 2) o Toshiba Bluetooth stack for Windows XP/2000, driver version 4.0 and 5.0 o WIDCOMM BTW 1.4, 3.0, 4.0, 5.0 o IVT BlueSoleil Bluetooth stack for Windows XP/2000, driver version 1.6.1.4 and 2.x * Windows 2000: o Toshiba Bluetooth stack for Windows XP/2000, driver version 4.0 and 5.0 o WIDCOMM BTW 1.4, 3.0, 4.0, 5.0 o IVT BlueSoleil Bluetooth stack for Windows XP/2000, driver version 1.6.1.4 and 2.x Device software update [IMG]http://i49.*******.com/u/f49/12/09/57/15/nsu_no10.jpg[/IMG] Use the Nokia Software Updater application to help you update your Nokia device software. Nokia Software Updater is compatible with most Nokia devices. Allows you to download and install the latest Nokia device software. Only needs to be downloaded once to your PC. Use this tool to determine the software version currently installed on your Nokia device and to see if there’s a new version available. Can I update my Nokia device software? Use this tool to determine the software version currently installed on your Nokia device and to see if there’s a new version available. Tip: You can use this tool to check for device software updates whenever you don’t have access to a PC with Nokia Software Updater installed on it. Nokia Mobile Cable Drivers [IMG]http://i49.*******.com/u/f49/12/09/57/15/compat10.jpg[/IMG] 1. Driver for Nokia DKU-5 Install the driver to establish a cable connection between your compatible Nokia phone and a compatible PC with a Nokia Connectivity Adapter Cable DKU-5. Before downloading and installing the driver, make sure the cable is disconnected from your PC. Refer to the guide for detailed installation and verification instructions. Tip: If you have trouble downloading the file, right-click on the link and open in a new window or disable your pop-up blockers. 2. Nokia Connectivity Cable Driver r6.8.5 Driver for Nokia DKE-2, DKU-2, CA-42, CA-53, CA-70, CA-101 Install the driver to establish a cable connection between your compatible Nokia phone and a compatible PC. Important for Windows 2000 or XP or Vista users: Drivers for the Nokia DKE-2, DKU-2, CA-42, CA-53, CA-70, and CA-101 cables are now integrated into PC Suite. Instead of downloading the cable driver separately, we recommend you download PC Suite. This driver is compatible with the following Nokia data cables: Nokia Connectivity Cable DKE-2 Nokia Connectivity Cable DKU-2 Nokia Connectivity Adapter Cable CA-42 Nokia Connectivity Cable CA-53 Nokia Charging Connectivity Cable CA-70 Nokia Charging Connectivity Cable CA-101 Before downloading and installing the driver, make sure the cable is disconnected from your PC. Refer to the guide for detailed installation and verification instructions. Tip: If you have trouble downloading the file, right-click on the link and open in a new window or disable your pop-up blockers. http://rapidshare.com/files/10096579...es_Drivers.rar Only Takes A Second to Say Thanks... |
The Following 5 Users Say Thank You to gsmmama For This Useful Post: |
06-24-2008, 14:15 | #2 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Kushtia,Bangladesh
Member: 597569 Status: Offline Sonork: 100.1593870 Thanks Meter: 271 | Quote:
06-26-2008, 09:07 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BD/Italy
Member: 324042 Status: Offline Sonork: 100.1578276 Thanks Meter: 3,504 | Nokia PC Suit + Nokia Software Updater + Cables Drivers for any Nokia mobile ......................... Free and easy link in the "Download software" section on this site. .........link............. http://europe.nokia.com or http://europe.nokia.com/A4144903 |
The Following User Says Thank You to mehedi.h.j For This Useful Post: |
[[[[[New]]]]]Nokia Pc Suite 6.8 Released(22 Multilanguage Support) | ankit_jain | Nokia Multimedia | 2 | 02-16-2007 18:38 |
==Nokia PC Suite 6.8 Release 22 Release 24 May 06= | bakarioss | Java, iOS, Android, Symbian development | 2 | 06-24-2006 10:59 |
I need nokia game installer for nokia pc suite 6.0 !!! | mg70brz | Nokia Multimedia | 6 | 10-31-2005 12:27 |
nokia pc suite 6.5 and nokia 3230 | Koponen | Nokia Multimedia | 16 | 09-01-2005 11:06 |
Nokia 3230,Can't Link With Nokia PC Suite 6.5 | ranga | Nokia Multimedia | 1 | 04-15-2005 18:05 |
