Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
04-30-2005, 17:10 | #1 (permalink) |
Junior Member Join Date: Feb 2005 Age: 50
Member: 120879 Status: Offline Thanks Meter: 0 | nokia pc suite 6.5 and nokia 3230 |
04-30-2005, 19:19 | #3 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: new delhi, india Age: 39
Member: 120647 Status: Offline Thanks Meter: 32 | Quote:
if u recieve files as messages, then try to swap memory of messages. | |
04-30-2005, 19:29 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | the easiest and simplest way is use file manager which is built in Nokia PC Suite, just right click on the startup Icon which is show near time and u'll see a list then just select file manager. 2nd option is to open my computer then use Nokia Phone Browser and then your mobile will be displayed there just open it and then use your memory card directly for transfering as big file as u like to send hope so your MMC's drive will be E: there take care |
04-30-2005, 19:33 | #5 (permalink) | |
Freak Poster Join Date: Mar 2005 Location: <= I-N-D-I-A => Age: 39
Member: 128795 Status: Offline Thanks Meter: 1 | Quote:
Bluesoleil bluetooth dongle works abs fine on WIN XP SP2 drivers. I use the same device even for connecting to internet via GPRS. Hey Koponen, If u hv WIN XP SP2...GR8.. If not Bluesoleil drivers r not bad at all. Regarding Phone memory, JASCORP9 has already explained in one of his posts, how to send incoing message to MMC. Steps : 1. Open " MESSENGING " 2. Then Go to " Options " 3.Then Go to " SETTINGS " 4. Then Go to " OTHER " 5. Then u will see " Memory in use: " 6. Change it from Phone to Memory card. That's it now on every message will go to phone memory. enjoy................... This will work for 3650/3660/6600 .......not for N-gage. for n-gage, u will hv to use one installation file for the same purpose. BYE | |
04-30-2005, 22:24 | #7 (permalink) | |
Member: 120879 Status: Offline Thanks Meter: 0 | Quote:
05-01-2005, 03:43 | #8 (permalink) | |
Member: 128795 Status: Offline Thanks Meter: 1 | Win Xp Sp2 Quote:
don't u hv Win XP SP2, because it has built in support for Bluetooth SATCK. If u r using Win XP PRO then, u will hv to download following drivers http://download.microsoft.com/downlo..._stack_rtm.exe Enjoy............................................. ............................ | |
05-02-2005, 16:43 | #10 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 41
Member: 78673 Status: Offline Thanks Meter: 1,253 | Follow theinstructions below: 1.install MSDRIVE in your device memory, 2.after the installation start the appz(it will do nothing,it will just blink) 3.restart the device,now it will use the Card memory for storing messages. 4.if u want to use your device memory again, just remove your MMC and then restart your phone.(now it will again use your device memory) Enjoy...! |
The Following User Says Thank You to HuBMOBILE For This Useful Post: |
05-07-2005, 20:36 | #12 (permalink) | |
Junior Member Join Date: May 2005 Age: 39
Member: 143606 Status: Offline Thanks Meter: 0 | Quote:
Well I am downloading it,Hope It works,Please post some comments ,those who are using this in nokia 3230!! thx | |
05-28-2005, 11:46 | #13 (permalink) | |
Junior Member Join Date: Mar 2005 Age: 43
Member: 126831 Status: Offline Thanks Meter: 0 | Plz give your feedback. Quote:
05-28-2005, 23:22 | #14 (permalink) |
Member: 143606 Status: Offline Thanks Meter: 0 | well its not working with 3230??i dont know why ? but might someone can make use of it!! i am posting the help to install this 1)first i got fexplorer install in my phone 2)download attachment and send using bluetooth to you phone 3)dont open the msg,use fexplorer to find where it put(use show path)in your inbox and move it to you MMC(copy at phone memory and paste to MMC memory) 4)DELETE the msg in you message inbox,REMEMBER YOU MSG CENTRE NUMBER. 5)use fexplorer search you Msvdrive at E:,install it to MMC dont in phone memory 6)In the menu you will see new icon,run it and wait a while.after the icon flashing back to the menu,now go to you messaging and you will see the icon at the top is change to mmc memory in use Smile ,go to setting and type again you msg centre number. 7)NOW you can receive any huge file to you phone as long as you memory card can support Wink CAUTION:THE MESSAGE IN YOU MESSAGE INBOX WILL DISAPPEARED AND ONLY CAN BE VIEW IN FEXPLORER other than that u can use this link to see more http://www.symbian-freak.com/quides/smsmmc.htm well try !!if someone got it working please tell me the procedure ,what method u use!! Best Of luck!! |
05-30-2005, 15:37 | #15 (permalink) |
Member: 142730 Status: Offline Thanks Meter: 0 | Works fine on my 3230. Just did it again after formatting the phone. You can follow Hubmobile's instructions above. A few comments: - erased all sent / received messages before starting. Anyway you will not see them after the change - uninstalled the app after running, it is not needed anymore. If you run again by mistake, it may erase your messages |
Nokia PC Suite 6.70.22 and Widcomm 5.0.1.1400 | gsmBTjoco | Bluetooth-Software | 9 | 05-24-2009 10:39 |
Nokia PC Suit 6.8 + Nokia Software Updater + Cables Drivers | gsmmama | Nokia Base Band 5 ( BB-5 ) | 4 | 06-26-2008 09:07 |
I need nokia game installer for nokia pc suite 6.0 !!! | mg70brz | Nokia Multimedia | 6 | 10-31-2005 12:27 |
6230i & PC Suite 6.5 | RadyR | Nokia Multimedia | 7 | 05-24-2005 09:20 |
Nokia 3230,Can't Link With Nokia PC Suite 6.5 | ranga | Nokia Multimedia | 1 | 04-15-2005 18:05 |
