12-09-2006, 12:27 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: P A K I S T A N
Member: 113943 Status: Offline Thanks Meter: 73 | 6280 dead usb flashing with phoenix |
12-09-2006, 13:02 | #3 (permalink) |
Insane Poster Join Date: Oct 2006
Member: 371047 Status: Offline Thanks Meter: 13 | Dead Phone USB flashing’: This method should be used in the following cases: - The phone to be flashed is not responding any more (e.g. it does not switch on) - The phone to be flashed starts but contains MCU SW version older than version 3.65. In this case, be aware that all the user settings will be lost during the flashing. When flashing a phone that kind of phone, do not switch on the phone before the flashing starts. 1. Setting up the connection: To allow the flashing of a dead phone, the used connection must be set to ‘NO CONNECTION’. To do this, go to File -> Manage Connection In the window ‘Manage Connection’, highlight the ‘NO CONNECTIONS’ bar and set it at the first place of the priority list. Press ‘Apply’ button and then close the ‘Manage Connection’ window. 2. Setting the product name: Open the product ‘RM-78’ using the menu File -> Open Product 3. Flashing the phone To perform the flashing, proceed as follows: - Choose menu ‘Flashing -> Firmware update’ - Activate button ‘Dead Phone USB flashing’ - Choose the variant to be flashed Press ‘Start’ button The flashing starts. After a few seconds the message ‘Cmt->Waiting USB device (1 of 30). Press phone’s power button’ appears. Press the phone’s power button. The flashing will be performed When it is OK then Carrying out firmware update: 1. Setting up the connection To allow the flashing of a dead phone, the used connection must be set to ‘USB’. To do this, go to: File -> Manage Connection. In the window ‘Manage Connection’, highlight the ‘USB’ bar and set it at the first place on the priority list. Press ‘Apply’ button and then close the ‘Manage Connection’ window. 2. Scan the product and start the flashing - Unplug the USB cable, if it has been plugged in before - Power on the phone with the USB cable unplugged - Plug the USB cable - Scan the product by using Crtl-R key combination or going to ‘File -> Scan Product’ - After successful scanning of the product, go to ‘Flashing -> Firmware Update’ - Choose between ‘Restore User Product’ or ‘Phone As Manufactured / Refurbish’ and press ‘Start’ button After a couple of seconds the message ‘Mode change’ appears on the ‘Firmware Update’ window. In the meanwhile, the message ‘Start up phone without SIM card?’ appears on the mobile phone’s display. On the mobile phone side, press on the ‘Accept’ button to confirm the phone’s start. The flashing goes on. After a while the flashing is finished. Haribo |
The Following 6 Users Say Thank You to Haribo11 For This Useful Post: |
04-29-2007, 03:40 | #4 (permalink) |
Junior Member Join Date: Apr 2007
Member: 497291 Status: Offline Thanks Meter: 1 | hi thanks for the intro, however for RM-42 Nokia N90 phone they don't support dead phone flashing.... so what can I do? because my Nokia N90 is dead |
The Following User Says Thank You to leeycian For This Useful Post: |
11-08-2008, 20:30 | #5 (permalink) |
Junior Member Join Date: Nov 2008
Member: 894751 Status: Offline Thanks Meter: 1 | Hi, I have a E61i phone which is dead (only blank white screen while booting) after trying to upgrade the firmware using NSU. I tried to flash it using phoenix 2007 and CA-53 cable. But it seems phoenix is not able to connect to the phone and is giving an error shown below. Can anyone let me know how to flash this phone using phoenix? Pls heeeeeeeelp. The flashing failed. Do you like to retry the flashing? HRESULT 0x84012286 (-2080300410) Flash: The device driver did not load. Verify phone is connected and powered on. |
The Following User Says Thank You to niroopr For This Useful Post: |
05-14-2011, 15:12 | #7 (permalink) |
Junior Member Join Date: May 2011
Member: 1574999 Status: Offline Thanks Meter: 0 | I tried to flash my nokia 5220 xpress music using phoenix But after some process i am getting error The error is- The flashing failed. Do you like to retry the flashing? HRESULT 0x84210027 (-2078212057) Firmware: Firmware updating failed. Error 0x8401F167 - Flash: Failed to initialize update server. The after this much of process i am getting error- Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Scanning image files... Waiting for USB device... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device --- Press phone's power button! --- Loading secondary boot code: 14592 bytes Secondary boot loaded Loading update server code: 302784 bytes Update server loaded Error initializing Algorithm. 0x84009427 ERROR: Failed to set phone to flashmode Pls pls anyone give the solution for this!!! thanx in advance.............. |
09-12-2012, 17:25 | #9 (permalink) |
Junior Member Join Date: Sep 2012
Member: 1809879 Status: Offline Thanks Meter: 0 | I have the RM-42 Nokia N90 and it is dead. When press power button the screen going white but nothing more. Windows don't regognize it when conected. It tryes to find driver but it can't and use the unknown device for this usb port. So i can't use the DEAD PHONE procedure on the Phoenix program. Any idea ??? |
Dead N73-Trying dead usb flashing with phoenix/jaf! Some help? | TnF | Nokia Base Band 5 ( BB-5 ) | 12 | 10-14-2011 01:14 |
Dead phone usb flashing with Phoenix | Murat Bekar | MT-BOX | 4 | 06-08-2006 09:16 |
