02-16-2009, 09:27 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: X-Sol
Member: 954575 Status: Offline Thanks Meter: 244 | 6300 shut off after 10 to 15 mins... i have here 6300.. blue light at the side only,,, I flash it in version 7.21, write pm, unlock then fall fact.. the phone is ok... the problem is after 10 to 15 mins.. it will shut off.. I already try 5 good batt but still the same problem.. the IMEI is intact........... I need some advice guys.................. |
The Following User Says Thank You to pathfinder333 For This Useful Post: |
02-16-2009, 12:09 | #3 (permalink) | |
Freak Poster Join Date: Nov 2008
Member: 898963 Status: Offline Thanks Meter: 69 | Quote:
The Following 2 Users Say Thank You to kirta For This Useful Post: |
02-16-2009, 13:15 | #4 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: In Apple Device
Member: 638481 Status: Offline Sonork: 100.1601053 Thanks Meter: 749 | Quote:
i will guide u what can u do. | |
The Following 2 Users Say Thank You to EJAZGUL For This Useful Post: |
02-16-2009, 14:10 | #5 (permalink) |
Member: 954575 Status: Offline Thanks Meter: 244 | her the info logs bro............ Reading... MCU SW version: V 07.21 05-11-08 RM-217 (c) Nokia. HW version: 1000 PCI version: RFIC version: 17211721 DSP version: ICPR61_08w10 PPM version: V 07.21 05-11-08 RM-217 (c) Nokia. R BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: r V 07.21 05-11-08 RM-217 (c) Nokia. Production serial number: DJG259850 Product code: 0546632 Module code: 0203166 Basic production code: 0537040 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 359835016945632 IMEI spare to net: 3A 95 38 05 61 49 65 03 IMEI SV to net: 33 95 38 05 61 49 65 23 F5 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-217.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0546632 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-217\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done Last edited by pathfinder333; 02-16-2009 at 14:17. |
02-16-2009, 14:52 | #6 (permalink) |
No Life Poster Join Date: May 2006 Location: iran,isfahan
Member: 269202 Status: Offline Thanks Meter: 281 | hi try sx4 and writ good pm if phone dosnt accept sx4 then you must use rpl this problem couse dou to unlock with bb5king |
The Following 2 Users Say Thank You to mohammadhadi For This Useful Post: |
02-16-2009, 16:23 | #7 (permalink) |
No Life Poster Join Date: Jun 2008 Location: dunja
Member: 786607 Status: Offline Thanks Meter: 66 | selft test failed after rpl write and pm i buyed rpl wrote and pm too but no self test possible here is log Reading... MCU SW version: V 07.21 05-11-08 RM-217 (c) Nokia. HW version: 4001 PCI version: RFIC version: 17211721 DSP version: ICPR61_08w10 PPM version: V 07.21 05-11-08 RM-217 (c) Nokia. C BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: c_fr V 07.21 05-11-08 RM-217 (c) Nokia. Production serial number: 7K0451091 Product code: 0537631 Module code: 0203166 Basic production code: 0537040 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 359538018282299 IMEI spare to net: 3A 95 35 08 81 82 22 09 IMEI SV to net: 33 95 35 08 81 82 22 29 F5 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN |
The Following User Says Thank You to manule For This Useful Post: |
02-16-2009, 16:39 | #8 (permalink) | |
Member: 638481 Status: Offline Sonork: 100.1601053 Thanks Meter: 749 | about ur logs i dont think ur prob solve with rpl coz ur SP DATA is oki & also imei is oki... just flash with letest ver if prob same than about my think its hardware prob...resold battry terminal... Quote:
02-17-2009, 08:28 | #10 (permalink) | |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | Quote:
did you try to solve this problem by downgrading ? or did you try. . . by erasing rap. . . ? i m sure your problem can be solve by erasing but don't erase this phone without knowledge or without instructions. (Erasing rap cause Imei and SL Zone damage) B.R., kashi4gul | |
The Following 2 Users Say Thank You to kashi4gul For This Useful Post: |
02-17-2009, 09:02 | #12 (permalink) | |
Now we are going to erase flash, follow these below steps: - Erase Flash with BB5Erase_8MBrap, BB5Erase_16MBrap and also with BB5Erase_32MBrap (Erase files are attached) Put erase files One bye One in MCU Part only like this: MCU Flash file: X:\All_BB5_Erase_Files\BB5Erase_8mbBrap.bin (Untick CRT308 and CRT BKP all the time after both backup saved) and then click to Flash, when it completed then again put 16mb in MCU Part like this: MCU Flash file: X:\All_BB5_Erase_Files\BB5Erase_16MBrap.bin and start erasing. . . . . and when it also completed then Put 32MB in MCU Part and start erasing again. . . MCU Flash file: X:\All_BB5_Erase_Files\BB5Erase_32MBrap.bin after this now connected phone will be fully erased and now you have to start the flash procedure. - Full flash with latest FW 7.21 (with MCU + PPM + CNT) - Write/Restore the Orignal backup of RPL (CRT BKP) - Writ/Restore the Orignal backup of PM 308 (CRT 308) - Use SX4 Auth Service, when it done then - Write Full PM (Attached) - And then make Factory Settting. Note: Don't Forget to Save your both backup PM 308 (CRT 308) and RPL (CRT BKP) before start erasing. That's all. . . hope problem will fixed . . . Best of luck. . . B.R., kashi4gul | |
The Following 10 Users Say Thank You to kashi4gul For This Useful Post: |
04-01-2009, 19:00 | #13 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Middle East
Member: 950386 Status: Offline Thanks Meter: 114 | I get no signal or no service or sometimes i will get contact service message on nokia 6300. But mostly after bb5 erase and using firmware 7.21 i get no service on the phone. So i have tried the above and followed the steps when i get to the sx4 auth step i get errors. I get access to the server but i get error messages please view log below (also note my imei) what can i do to get passed this step? or why am i geting no service on my phone after flash? regards 01:04:2009 18:08 -> Powering the phone... 01:04:2009 18:08 -> Reading... 01:04:2009 18:08 -> MCU SW version: V 07.21 05-11-08 RM-217 (c) Nokia. 01:04:2009 18:08 -> PCI version: 01:04:2009 18:08 -> RFIC version: 17211721 01:04:2009 18:08 -> DSP version: ICPR61_08w10 01:04:2009 18:08 -> PPM version: V 07.21 05-11-08 RM-217 (c) Nokia. I 01:04:2009 18:08 -> BT MCM version: 06cc-P9.1 01:04:2009 18:08 -> Retu version: 32 01:04:2009 18:08 -> Tahvo version: 53 01:04:2009 18:08 -> Content Pack version: Content: i V 07.21 05-11-08 RM-217 (c) Nokia. 01:04:2009 18:08 -> Production serial number: 01:04:2009 18:08 -> Product code: 01:04:2009 18:08 -> Module code: 01:04:2009 18:08 -> Basic production code: 01:04:2009 18:08 -> Flash code: 01:04:2009 18:08 -> Order number: 01:04:2009 18:08 -> Product specific data: 01:04:2009 18:08 -> Long production SN: 01:04:2009 18:08 -> ATO: 01:04:2009 18:08 -> Default SN type: 01:04:2009 18:08 -> IMEI plain: 12345610654321? 01:04:2009 18:08 -> IMEI spare to net: 1A 32 54 16 60 45 23 01 01:04:2009 18:08 -> IMEI SV to net: 13 32 54 16 60 45 23 21 F5 01:04:2009 18:08 -> LOCK STATUS: CONFIG KEY: 0000000000000000 01:04:2009 18:08 -> PROVIDER KEY: 0000000000000000 01:04:2009 18:08 -> Provider: Unknown provider 01:04:2009 18:08 -> Key Code count: 0, FBUS Code count: 0 01:04:2009 18:08 -> 01:04:2009 18:08 -> Searching for saved ini... 01:04:2009 18:08 -> Checking for file C:\Program Files\ODEON\JAF\JAF_RM-217.ini 01:04:2009 18:08 -> Saved INI not found, loading INI list... 01:04:2009 18:08 -> Setting local mode... 01:04:2009 18:08 -> Reading product code... 01:04:2009 18:08 -> Product Code: 01:04:2009 18:08 -> Searching for JAF saved location of ini... 01:04:2009 18:08 -> Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ 01:04:2009 18:08 -> 01:04:2009 18:08 -> Searching for default location of ini... 01:04:2009 18:08 -> Checking path: \Products\RM-217\ 01:04:2009 18:08 -> Searching for JAF saved location of ini... 01:04:2009 18:08 -> Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ 01:04:2009 18:08 -> No ini files found... 01:04:2009 18:08 -> FILES SET FOR FLASHING: 01:04:2009 18:08 -> MCU Flash file: NONE 01:04:2009 18:08 -> PPM Flash file: NONE 01:04:2009 18:08 -> CNT Flash file: NONE 01:04:2009 18:08 -> APE Variant file: NONE 01:04:2009 18:08 -> Done! 01:04:2009 18:09 -> Backing up CRT data... 01:04:2009 18:09 -> Setting FLASH MODE 01:04:2009 18:09 -> Loader version: 01.1E.0001:04:2009 18:09 -> -> Revision: 0000 01:04:2009 18:09 -> Patching CMT boot step1... 01:04:2009 18:09 -> Patching CMT boot step2... 01:04:2009 18:09 -> Patching CMT boot step3... 01:04:2009 18:09 -> CMT Boot Ready 01:04:2009 18:09 -> CMT Flash ID: 01:04:2009 18:09 -> 0041000101:04:2009 18:09 -> <=> SPANSION -> Type not in database 01:04:2009 18:09 -> CMT Flash Data: 01:04:2009 18:09 -> 00000000000000000000000000000000 01:04:2009 18:09 -> CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg 01:04:2009 18:09 -> Loader version: 01.21.0101:04:2009 18:09 -> -> Revision: 0000 01:04:2009 18:09 -> Patching CMT loader step1... 01:04:2009 18:09 -> Patching CMT loader step3... 01:04:2009 18:09 -> CMT Loader Ready 01:04:2009 18:09 -> Reading CMT NPC certificate... 01:04:2009 18:09 -> Reading CMT VARIANT certificate... 01:04:2009 18:10 -> VARIANT CRT empty, skip save... 01:04:2009 18:10 -> Reading CMT CCC certificate... 01:04:2009 18:11 -> CCC crt empty skiping save... 01:04:2009 18:11 -> Reading CMT HWC certificate... 01:04:2009 18:11 -> HWC crt empty skiping save... 01:04:2009 18:11 -> Saved to C:\Program Files\ODEON\JAF\ProgData\12345678901234_CRT_backup _18914.rpl 01:04:2009 18:11 -> Backup CRT OK! 01:04:2009 18:11 -> Reading SW version...01:04:2009 18:11 -> 07.21 01:04:2009 18:11 -> Done! 01:04:2009 18:11 -> Total time: 0 Minutes, 0 Seconds 01:04:2009 18:11 -> DCT4/BB5 counter: 120 01:04:2009 18:11 -> After flash processing... 01:04:2009 18:11 -> Waiting for phone to boot... 01:04:2009 18:11 -> Reading... 01:04:2009 18:11 -> Phone type: RM-217, Software version: 07.21 01:04:2009 18:11 -> IMEI: 12345610654321? 01:04:2009 18:11 -> APE Ver: (null) 01:04:2009 18:11 -> Variant Ver: (null) 01:04:2009 18:11 -> Product Code: 01:04:2009 18:11 -> Done! 01:04:2009 18:12 -> Backing up SIMLOCK data... 01:04:2009 18:12 -> Setting local mode... 01:04:2009 18:12 -> Reading IMEI... 01:04:2009 18:12 -> C:\Program Files\ODEON\JAF\ProgData\12345610654321?_CRT_backu p_181214.pm 01:04:2009 18:12 -> Done! 01:04:2009 18:12 -> Backup LCK OK! 01:04:2009 18:12 -> Reading SW version...01:04:2009 18:12 -> 07.21 01:04:2009 18:12 -> Done! 01:04:2009 18:12 -> Total time: 0 Minutes, 0 Seconds 01:04:2009 18:12 -> DCT4/BB5 counter: 120 01:04:2009 18:12 -> After flash processing... 01:04:2009 18:12 -> Waiting for phone to boot... 01:04:2009 18:12 -> Reading... 01:04:2009 18:12 -> Phone type: RM-217, Software version: 07.21 01:04:2009 18:12 -> IMEI: 12345610654321? 01:04:2009 18:12 -> APE Ver: (null) 01:04:2009 18:12 -> Variant Ver: (null) 01:04:2009 18:12 -> Product Code: 01:04:2009 18:12 -> Done! 01:04:2009 18:14 -> Checking for local SX card... 01:04:2009 18:14 -> Trying to use SX4 server... 01:04:2009 18:14 -> Server say: Hello! 01:04:2009 18:14 -> Login... 01:04:2009 18:14 -> Detected P-KEY: 900229C6 01:04:2009 18:14 -> Server say: Login OK, you are number 5 in the queue, you must wait aprox. 20 seconds... 01:04:2009 18:14 -> Connecting to phone... 01:04:2009 18:15 -> Error receiving data from server step2... |
The Following User Says Thank You to LOCKED4EVER For This Useful Post: |
02-28-2011, 17:23 | #14 (permalink) |
Registered User Join Date: Oct 2005
Member: 189506 Status: Offline Sonork: 100.1576871 Thanks Meter: 126 | ur imei goes 123456...., write rpl backup...... u have no need to do this all just buy mxkey, & do repair sd. all is fine......... very simple only done it with mxkey take only 5 min. |
3110 power off after 10 or 15 mints | nangia khan | Nokia Hardware & Hardware Repair | 10 | 03-22-2010 09:59 |
6300 truns off after 10 minutes | ofencemir | Nokia Hardware & Hardware Repair | 9 | 01-06-2010 12:09 |
6300 truns off after 10 minutes | ofencemir | Nokia Hardware & Hardware Repair | 5 | 01-01-2010 13:47 |
Nokia n70 shut down in 10 to 30 min. | mobilee_fun | Nokia Base Band 5 ( BB-5 ) | 11 | 06-10-2009 15:00 |
6270 turn of after 10 to 15 min | aklil70 | Nokia Base Band 5 ( BB-5 ) | 0 | 05-01-2009 13:48 |
