To All final solution for unlock phone Contact Retailr hi today i have n958gb i need unlock i work 4 hors for unlock but All Failed After unlock give phone startup i test All method for reapir Contact Retailr but Failed now i give to All how to reapir this 100% WORK WITH ME this logo for unlock phone then After unlock give me Contact Retailr Searching for UFS box ... UFS box detected Box firmware version: 208 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-320 Version: V 06wk41v46.1 13-11-07 RM-320 (c) Nokia IMEI: 3569830 SP LOCK status: Config Key: 0000000000000000 Provider Key: 2081000000000000 Counters: 0/3, 0/10 Phone is Locked Reading PM Field 120 Subfield 0 with length 152 bytes Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-320_356983012737885_PM120_PM308_Locked_08-04-2009_172203.bin Saving to file: RM-320_356983012737885_120_and_308_Locked_08-04-2009_172203.pm PM120 and PM308 backup OK BB5 FLASH bb5challenge ... ASIC ID: 000000010000022600010006400C192101021103 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 CMT Boot Ready Initial PM 308 sent Certificates sent Unlocked PM 308 SL buffer received Unlocked PM 308 field build OK After unlock. Searching for phone ... Phone found on FBUS interface Writting PM Field 120 Subfield 0 with length 56 bytes Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Fields 120 and 308 written OK Waiting for phone to power up ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-320 Version: V 06wk41v46.1 13-11-07 RM-320 (c) Nokia IMEI: 356983012737885 SP LOCK status: Config Key: 0000000000000000 Provider Key: 0000000000000000 Counters: 0/3, 0/10 Phone is Unlocked Read Phone Info OK Successfully done. ================================== now logo for complete unlock with oute problem Searching for UFS box ... UFS box detected Box firmware version: 208 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-320 Version: V 06wk41v46.1 13-11-07 RM-320 (c) Nokia IMEI: 3569830 SP LOCK status: Config Key: 0000000000000000 Provider Key: 2081000000000000 Counters: 0/3, 0/10 Phone is Locked Reading PM Field 120 Subfield 0 with length 152 bytes Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-320_356983012737885_PM120_PM308_Locked_08-04-2009_172203.bin Saving to file: RM-320_356983012737885_120_and_308_Locked_08-04-2009_172203.pm PM120 and PM308 backup OK BB5 FLASH bb5challenge ... ASIC ID: 000000010000022600010006400C192101021103 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 CMT Boot Ready Initial PM 308 sent Certificates sent Unlocked PM 308 SL buffer received Unlocked PM 308 field build OK After unlock. Searching for phone ... Phone found on FBUS interface Writting PM Field 120 Subfield 0 with length 56 bytes Writting PM Field 308 Subfield 1 with length 8192 bytes ====================================== now All you need don't complet unlock phone Writting PM Field 120 Subfield 0 with length 56 bytes Writting PM Field 308 Subfield 1 with length 8192 bytes After this massege remove cable form phone then phone unlock eith no any problem i test 2 phone work with me |
goood job bro B.R Dr.DeathX |
fine trick but the phone have signal and working normal after that? i can't belive that. Also if you update firmware ?? Does anyone else can confirm that? (sorry bro for disbelief :confused::confused:) B.R GabiRo |
THX zakryia BEST REGARDS |
i just dont understand this post... would u please be little more clear??? |
BB5 Contact Service, Restart Problem,How To Erase BB5, Restore PM and RPL Backup!!! B.R., kashi4gul |
yes bro would u please be little more clear....? or caps ........? |
Hi bro.. i cant understand that where to find that PM , read from zulea soft when tick " make unlocked pm" , or simple org pm ? Then with what box need to worked , with j.a.f or ? Can bee a little clear about your work mate? Best.r |
Good Job Bro............................ |
n96 start-up failed after phone successfully unlocked i followed the below procedure still the same thing. now All you need don't complet unlock phone Writting PM Field 120 Subfield 0 with length 56 bytes Writting PM Field 308 Subfield 1 with length 8192 bytes After this massege remove cable form phone then phone unlock eith no any problem i test 2 phone work with me |
Writting PM field 120 and 308 with JAF or how to do that , if you have little time to be more clear please?? |
yes it also worked for me on n95 8gb |
yes yes you best today i test n958 gb work no any problem |
