**BB5 Phone Code Removing Tutorial Using Usb Cable** 1 Attachment(s) here You Can Remove Yor Phone Code Using Usb Cable With The Help Of An External Power Supply.see Attachment.(EASY WAY TO GET TEST OR LOCAL MODE) conect Power Supply Positive Crocodile To Battery Positive And Negative To Negative Terminal Of The Phone And Conect Power Supply Green Crocodile To Middle Point Of The Phone Battery Terminal Called Battery Temp,press Power Botton Shortly And You Will See Test Mode,now Conect Dku-2 Cabvle To Phone And Do Want You Want. |
i dont think,this is needed.. with only cable usb dku2 and nemesis u can read code in PM. |
@applelinks , i cant understand what u want to say. |
BB5 PHONE with lock CODE DOES NOT ENTER LOCAL OR TEST MODE THEN HOW YOU CAN GET INFO????? |
now i understand. |
what is this? no any explatin? |
Yes you are right.Thanks for remember it. BR !!blshohel!! |
MT box with usb mode, Jaf usb + F-bus mode. |
but some have problem to read security codes what aboiut man for that alls plz verify |
what software i can use with this cable? |
Hi, Where goes the other end of green cable, to + or - of powersupply? |
