Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 07-09-2007, 15:03   #1 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
**BB5 Phone Code Removing Tutorial Using Usb Cable**
here You Can Remove Yor Phone Code Using Usb Cable With The Help Of An External Power Supply.see Attachment.(EASY WAY TO GET TEST OR LOCAL MODE)
conect Power Supply Positive Crocodile To Battery Positive And Negative To Negative Terminal Of The Phone And Conect Power Supply Green Crocodile To Middle Point Of The Phone Battery Terminal Called Battery Temp,press Power Botton Shortly And You Will See Test Mode,now Conect Dku-2 Cabvle To Phone And Do Want You Want.
The Following 4 Users Say Thank You to ..::AppleLinks::.. For This Useful Post:
Old 07-09-2007, 15:10   #2 (permalink)
Member: 310933
Thanks Meter: 2
i dont think,this is needed..
with only cable usb dku2 and nemesis
u can read code in PM.
Old 07-09-2007, 15:13   #3 (permalink)
PARMATMA's Avatar
Member: 201107
Sonork: 100.1576954
Thanks Meter: 737
@applelinks , i cant understand what u want to say.
Old 07-09-2007, 15:13   #4 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
Originally Posted by corsariso View Post
i dont this is needed..
BB5 PHONE with lock CODE DOES NOT ENTER LOCAL OR TEST MODE THEN HOW YOU CAN GET INFO?????
Old 07-09-2007, 15:17   #5 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
CHECK ATTACHMENT AND YOU WILL SEE...ALL U WILL UNDERSTAND.
Old 07-09-2007, 15:20   #6 (permalink)
Member: 310933
Thanks Meter: 2
Originally Posted by ..::AppleLinks::.. View Post
BB5 PHONE CODE DOES NOT ENTER LOCAL OR TEST MODE THEN HOW YOU CAN GET INFO?????
Write small words please
now i understand.
Old 07-09-2007, 15:23   #7 (permalink)
Member: 247264
Thanks Meter: 28
what is this? no any explatin?
Old 07-09-2007, 15:36   #8 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
EASY WAY TO EMNTER LOCAL OR TEST MODE FOR UI SETTINGS.
Old 07-09-2007, 15:48   #9 (permalink)
hackerbd's Avatar
Member: 247758
Sonork: 100.1574842
Thanks Meter: 259
Yes you are right.Thanks for remember it.
!!blshohel!!
Old 07-09-2007, 19:27   #10 (permalink)
snsoftkiller's Avatar
Member: 250468
Sonork: 100.110362
Thanks Meter: 96
MT box with usb mode, Jaf usb + F-bus mode.
Old 07-09-2007, 19:40   #11 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 471
but some have problem to read security codes what aboiut man for that alls plz verify
Old 07-09-2007, 21:24   #12 (permalink)
hans salim's Avatar
Member: 292087
Sonork: 1575183
Thanks Meter: 194
what software i can use with this cable?
Old 07-10-2007, 06:27   #13 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
if u get test or local mode mode and u r software not reset your security code then do full ui settings (facteroy defalts),this tutoirial is for TEST MODE or Local Mode.
Old 07-10-2007, 06:29   #14 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
you can use JAF or MT BOX...with conecting DKU-2 USB cable.
Old 07-10-2007, 07:57   #15 (permalink)
Member: 513276
Hi,
Where goes the other end of green cable, to + or - of powersupply?
3250,6270 dead phones CAN BE flash using usb? mccm MT-BOX 2 07-24-2006 09:13
new sw of phone code remove here MAK_US1977 Sharp 1 11-24-2003 14:56
c45 phone code remove?????? dollyb x1x to x45/x50 1 03-20-2002 02:34
Aria phone code removing? repraky Mitsubishi 1 06-08-2001 22:00
needc28v61 phone code remove tone x1x to x45/x50 0 03-31-2001 19:11
Page generated in 0.18971 seconds with 10 queries
