07-10-2007, 08:35 | #18 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Dera applelink@ yur tuteral is confusing all ,why bb5 phone required test mode? to find lock code can u explain |
07-10-2007, 14:09 | #23 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | this cable set comes frm manufacters (power supply inviter) in which some resistance are included.red green black and yellow crocodile is prese with this cable.you should to check frm any one and u can make it by u r self. |
07-10-2007, 14:13 | #25 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | i check this solotion is almost all Bb5 phones even 6280..6233 etc,u can see in picture.is u r power supply cable is ok , the resistance in power supply cable are ok, r u conecting green cable to middle point of battery terminla.this solotion is 100% working. |
07-10-2007, 14:33 | #27 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | The USB cable Operation is to easy and safe..But the Problem is that, the phone should be unloked (phone code) or in TEST or Local mode,bcz u can not do ui settings..if a phone is "phone locked". |
3250,6270 dead phones CAN BE flash using usb? | mccm | MT-BOX | 2 | 07-24-2006 09:13 |
new sw of phone code remove here | MAK_US1977 | Sharp | 1 | 11-24-2003 14:56 |
c45 phone code remove?????? | dollyb | x1x to x45/x50 | 1 | 03-20-2002 02:34 |
Aria phone code removing? | repraky | Mitsubishi | 1 | 06-08-2001 22:00 |
needc28v61 phone code remove | tone | x1x to x45/x50 | 0 | 03-31-2001 19:11 |
