07-11-2007, 13:53 | #46 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
07-11-2007, 14:34 | #47 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: Earth
Member: 426389 Status: Offline Thanks Meter: 2,356 | Quote:
Tested with 6270 and N73 | |
07-12-2007, 06:59 | #53 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | If U have a modified F-Bus cable and it show local or test Mode in phone...then No Need for USB cable...this solotion is...when ever a modified F-Bus cable is not avilable,Then Usb cable will Use For Operation. |
07-12-2007, 09:20 | #56 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | check above solotion it will work for you,Conect red to positive and blacke to negative while green to midlle point of your 6233 battery terminlas,press power botton and wait, you will see test mode,now conect DKU-2 cable use jaf,all will be fine. |
07-20-2007, 08:18 | #57 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Nokia 6300 Test Mode Using External Power I TEST ALSO NOKIA 6300 WITH EXTERNAL POWER SUPPLY (INVITER),USING RED TO PHONE POSITIVE AND BLACK TO NEGATIVE AND GREEN TO MIDDLE POINT OF THE BATTER TERMINAL. NOKIA 6300 TEST MODE USING EXTERNAL POWER |
07-22-2007, 07:44 | #60 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 305905 Status: Offline Thanks Meter: 9 | why just try to understand the point of the thread starter,,he just simply want to say that this is just the method of puting the phone in test mode ,,bcoz bb5 is so hard toenter in test mode sometime, |
3250,6270 dead phones CAN BE flash using usb? | mccm | MT-BOX | 2 | 07-24-2006 09:13 |
new sw of phone code remove here | MAK_US1977 | Sharp | 1 | 11-24-2003 14:56 |
c45 phone code remove?????? | dollyb | x1x to x45/x50 | 1 | 03-20-2002 02:34 |
Aria phone code removing? | repraky | Mitsubishi | 1 | 06-08-2001 22:00 |
needc28v61 phone code remove | tone | x1x to x45/x50 | 0 | 03-31-2001 19:11 |
