cannot reflash dead nokia6280 help cannot flash dead nokia 6280 error msg:trying to verify communication filed,cold not verify communikation to UA.0x8401225A(-2080300454)adl loader does not start.this may hapen if USB has not jet configuret,in this case wait USB to configure and restart the operation.In X products this can mean than wrong dcm:( dll is used.Help me plz! |
You just have to be patient and it will work after many retries,use latest 156 phoenix and latest 5.92 firmware,dead phone usb flash work with this versions. |
had the same problems. if flashing is over and phoenix wants to verify the proces and the message you describe appears, disconnect the phone and connect it after that push retry button and all will be fine! |
First, in Phoenix, under Manage Connections, select NO CONNECTION (or move it to the top of the list if you have several options there already). Press APPLY then CLOSE. Second, under File menu, select Open product and choose your model. Then select Flashing - Firmware update, choose product version and Phone as Manufactured/refurbish. Checkbox USF flash dead phone will be activated, check it, then press Flash button. When requested, press the power button on the phone. Should work. Worked like miracle for me (6270, 6280 & 3250). |
Thanks,but i cannot download 5.92 firmware from rapidshare:mad: |
i get 5.92 firmw,but nokia 6280 still dead:( |
I tried flash as dead phone(6280) with firmware 3.70,3.81,3.82,5.92 and software phoenix (versions: 2006_20_9_148, 2006_20_14_153, patch_2006_20_15_154, 2006_34_2_156), many times(more month), but phone still dead. Quote:
p.s. Sorry for my english ;) |
oops123, maybe the problem is not in the software? Was the phone working before you flashed it? Did you notice what version of firmware it was on? Because I have personally flashed successfully 6280 from dead state (turns on, shows Nokia and dies) using NO CONNECTION method in Phoenix. The procedure is described a couple posts above. If this fails, maybe the problem is in thephone hardware... Or if you downgraded the phone firmware, which is bad. |
When phone worked firmware was 3.70. in process reflashing to firmware 3.81 got error message(about 80%-90%), phone dead. --- i use NO CONNECTION but still dead. p.s. sorry for my english ;) |
Also, if battery is not a problem, try a different set of firmware files. Maybe yours are corrupted. The best way would be to download and install the full data package. Search for my other posts, I have posted links to 5.92 data package. That's a full working one. Tested. :) |
Flash the phone using DEAD USB FLASHING with a Jaf box , a DKU cable , 6280 sw version 5.92 . and all will be ok. :) This is the thread- http://forum.gsmhosting.com/vbb/show...ight=6280+DEAD BR Ayoade |
1 Attachment(s) i have firmwares. buttery was full. its now buttery empty(control with multimeter 2.81 volts), but i may charging. i tried also some versions driver p.s. sorry for my english |
