04-04-2009, 14:00 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: rochdale uk
Member: 396778 Status: Offline Thanks Meter: 155 | E51 Start-up failed contact retailer i got a E51 which was working 100% ok but i tried to change the language on it and then its got dead and it was only show the blank screen and then turn off but i revive it flashing with a same firmware which its had it before and now its turn on but it say START UP FAILED. i tried to restore the rpl back up and pm 308 but still same thing..... plz help me thanks |
04-04-2009, 18:52 | #5 (permalink) | |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | Quote:
Correct! and for more info: Read Here B.R., kashi4gul | |
The Following User Says Thank You to kashi4gul For This Useful Post: |
04-04-2009, 22:08 | #6 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: Mozambique
Member: 582113 Status: Offline Thanks Meter: 46 | Quote:
I had the same problem if you have the back up it's fine ... I don't have the backup but I got rid of contact retailer and phone is working fine ...... http://forum.gsmhosting.com/vbb/show...95&postcount=1 BR ... | |
04-05-2009, 13:28 | #7 (permalink) | |
Member: 396778 Status: Offline Thanks Meter: 155 | Quote:
here is the log file from jaf box# Powering on the phone... FAILED!!! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V ICPR71_08w44.4 11-12-08 RM-244 (c) Nokia HW version: 0605 PCI version: RFIC version: DSP version: APE SW Core version: 300.34.56 APE Variant version: 300.34.56300.34.56_v01 APE Test version: rm244ENO708.1_100.15.37v020 Retu version: 15 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 Production serial number: SAN859475 Product code: 0552345 Module code: Basic production code: 0545341 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 357663014737112 IMEI spare to net: 3A 75 66 03 41 37 17 01 IMEI SV to net: 33 75 66 03 41 37 17 31 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file D:\Program Files\ODEON\JAF\JAF_RM-244.ini Saved INI not found, loading INI list... Searching for JAF saved location of ini... Checking path: D:\Program Files\Nokia\Phoenix\Products\\ Searching for default location of ini... Checking path: D:\Program Files\Common Files\Nokia\DataPackage\Products\\ Searching for JAF saved location of ini... Checking path: D:\Program Files\Nokia\Phoenix\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! | |
04-05-2009, 13:31 | #8 (permalink) | |
i tried your manual but still i got the same problem...i didnt understand that how to solve config key problem and i did self test i got fail security.... here is log file frm jaf box Powering on the phone... FAILED!!! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V ICPR71_08w44.4 11-12-08 RM-244 (c) Nokia HW version: 0605 PCI version: RFIC version: DSP version: APE SW Core version: 300.34.56 APE Variant version: 300.34.56300.34.56_v01 APE Test version: rm244ENO708.1_100.15.37v020 Retu version: 15 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 Production serial number: SAN859475 Product code: 0552345 Module code: Basic production code: 0545341 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 357663014737112 IMEI spare to net: 3A 75 66 03 41 37 17 01 IMEI SV to net: 33 75 66 03 41 37 17 31 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file D:\Program Files\ODEON\JAF\JAF_RM-244.ini Saved INI not found, loading INI list... Searching for JAF saved location of ini... Checking path: D:\Program Files\Nokia\Phoenix\Products\\ Searching for default location of ini... Checking path: D:\Program Files\Common Files\Nokia\DataPackage\Products\\ Searching for JAF saved location of ini... Checking path: D:\Program Files\Nokia\Phoenix\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! | |
04-05-2009, 13:32 | #9 (permalink) |
Member: 396778 Status: Offline Thanks Meter: 155 | still same problem here is the log file and i tried self test and i got fail.. here is log file Powering on the phone... FAILED!!! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V ICPR71_08w44.4 11-12-08 RM-244 (c) Nokia HW version: 0605 PCI version: RFIC version: DSP version: APE SW Core version: 300.34.56 APE Variant version: 300.34.56300.34.56_v01 APE Test version: rm244ENO708.1_100.15.37v020 Retu version: 15 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 Production serial number: SAN859475 Product code: 0552345 Module code: Basic production code: 0545341 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 357663014737112 IMEI spare to net: 3A 75 66 03 41 37 17 01 IMEI SV to net: 33 75 66 03 41 37 17 31 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file D:\Program Files\ODEON\JAF\JAF_RM-244.ini Saved INI not found, loading INI list... Searching for JAF saved location of ini... Checking path: D:\Program Files\Nokia\Phoenix\Products\\ Searching for default location of ini... Checking path: D:\Program Files\Common Files\Nokia\DataPackage\Products\\ Searching for JAF saved location of ini... Checking path: D:\Program Files\Nokia\Phoenix\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! |
04-05-2009, 13:34 | #10 (permalink) |
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | CONFIG KEY: 0000000000000000 is normal, no need to worried. its oK. . . now phone is working well or on Contact Service/Provider ? B.R., kashi4gul |
04-05-2009, 13:58 | #13 (permalink) |
Member: 396778 Status: Offline Thanks Meter: 155 | here is the another log when the was working order 28:03:2009 19:20 -> Card life counter: 99.56% 28:03:2009 19:20 -> P-key nokia module version 01.02 28:03:2009 19:20 -> FBUS INTERFACE NOT CONNECTED!!! 28:03:2009 19:20 -> USB Cable Driver version: 7.1.8.0 28:03:2009 19:20 -> Changing mode...28:03:2009 19:20 -> Done! 28:03:2009 19:20 -> Searching for phone...28:03:2009 19:20 -> Detected P-KEY: xxxxxx28:03:2009 19:20 -> P-key nokia module version 01.02 28:03:2009 19:20 -> Init usb communication... 28:03:2009 19:20 -> Found 28:03:2009 19:20 -> MCU SW version: V ICPR71_08w44.4 11-12-08 RM-244 (c) Nokia 28:03:2009 19:20 -> HW version: 0605 28:03:2009 19:20 -> PCI version: 28:03:2009 19:20 -> RFIC version: 28:03:2009 19:20 -> DSP version: 28:03:2009 19:20 -> APE SW Core version: 300.34.56 28:03:2009 19:20 -> APE Variant version: 300.34.56300.34.56_v236.06 28:03:2009 19:20 -> APE Test version: rm244ENO708.1_100.15.37v020 28:03:2009 19:20 -> Retu version: 15 28:03:2009 19:20 -> Tahvo version: 22 28:03:2009 19:20 -> APE HW version: 256 28:03:2009 19:20 -> APE ADSP SW version: 256 28:03:2009 19:20 -> APE BT version: HCI Version 8 (rev. 0). LMP Version 32 (rev. 4127). Manufacturer 13064. 28:03:2009 19:20 -> Production serial number: SAO252677 28:03:2009 19:20 -> Product code: 0558765 28:03:2009 19:20 -> Module code: 28:03:2009 19:20 -> Basic production code: 0545341 28:03:2009 19:20 -> Flash code: 28:03:2009 19:20 -> Order number: 28:03:2009 19:20 -> Product specific data: 28:03:2009 19:20 -> Long production SN: 0 28:03:2009 19:20 -> ATO: 28:03:2009 19:20 -> Default SN type: 28:03:2009 19:20 -> IMEI plain: 357663014737112 28:03:2009 19:20 -> IMEI spare to net: 3A 75 66 03 41 37 17 01 28:03:2009 19:20 -> IMEI SV to net: 33 75 66 03 41 37 17 31 F1 28:03:2009 19:20 -> LOCK STATUS: CONFIG KEY: 2440700000000000 28:03:2009 19:20 -> Provider: AT&T;U.S.A. (3650) 28:03:2009 19:20 -> Key Code count: 0, FBUS Code count: 0 28:03:2009 19:20 -> Block 1: 28:03:2009 19:20 -> Lock 1: OPEN 28:03:2009 19:20 -> Lock 2: OPEN 28:03:2009 19:20 -> Lock 3: OPEN 28:03:2009 19:20 -> Lock 4: OPEN 28:03:2009 19:20 -> Lock 5: OPEN 28:03:2009 19:20 -> Block 2: 28:03:2009 19:20 -> Lock 1: OPEN 28:03:2009 19:20 -> Lock 2: OPEN 28:03:2009 19:20 -> Lock 3: OPEN 28:03:2009 19:20 -> Lock 4: OPEN 28:03:2009 19:20 -> Lock 5: OPEN 28:03:2009 19:20 -> Block 3: 28:03:2009 19:20 -> Lock 1: OPEN 28:03:2009 19:20 -> Lock 2: OPEN 28:03:2009 19:20 -> Lock 3: OPEN 28:03:2009 19:20 -> Lock 4: OPEN 28:03:2009 19:20 -> Lock 5: OPEN 28:03:2009 19:20 -> Block 4: 28:03:2009 19:20 -> Lock 1: OPEN 28:03:2009 19:20 -> Lock 2: OPEN 28:03:2009 19:20 -> Lock 3: OPEN 28:03:2009 19:20 -> Lock 4: OPEN 28:03:2009 19:20 -> Lock 5: OPEN 28:03:2009 19:20 -> Block 5: 28:03:2009 19:20 -> Lock 1: OPEN 28:03:2009 19:20 -> Lock 2: OPEN 28:03:2009 19:20 -> Lock 3: OPEN 28:03:2009 19:20 -> Lock 4: OPEN 28:03:2009 19:20 -> Lock 5: OPEN 28:03:2009 19:20 -> Block 6: 28:03:2009 19:20 -> Lock 1: OPEN 28:03:2009 19:20 -> Lock 2: OPEN 28:03:2009 19:20 -> Lock 3: OPEN 28:03:2009 19:20 -> Lock 4: OPEN 28:03:2009 19:20 -> Lock 5: OPEN 28:03:2009 19:20 -> Block 7: 28:03:2009 19:20 -> Lock 1: OPEN 28:03:2009 19:20 -> Lock 2: OPEN 28:03:2009 19:20 -> Lock 3: OPEN 28:03:2009 19:20 -> Lock 4: OPEN 28:03:2009 19:20 -> Lock 5: OPEN 28:03:2009 19:20 -> |
Nokia 3650 Start up failed.Contact retailer! | Dido76 | WD2 & APE (Symbian Phones) | 9 | 07-21-2013 11:49 |
Help... SX1 : PHone Start Up Failed Contact Retailer. | bestncheap | SIEM Service Tools | 15 | 07-29-2007 18:02 |
3650 Phone start-up failed contact retailer | wiky | WD2 & APE (Symbian Phones) | 5 | 10-23-2004 02:32 |
Nokia 3650 start up failed. Contact retailer. | DoubleA | WD2 & APE (Symbian Phones) | 1 | 10-04-2004 10:19 |
3650 - phone start-up failed. contact retailer. | rockmaker | WD2 & APE (Symbian Phones) | 0 | 11-24-2003 23:34 |
