02-21-2011, 10:57 | #1 (permalink) |
No Life Poster Join Date: Dec 2008
Member: 934255 Status: Offline Thanks Meter: 63 | How to Downgrade nokia 5800 I have a nokia 5800 with version .52. After the upgrade Radio and Bluetooth don't work anymore. I read already that a few nokia 5800 after the upgrade have this problem. So i want to downgrade, already try with JAF or MXKEY but after the downgrade the phone don't power on. I have to put again the .52 to the phone work again. How can i do this? Tanks in advanced |
02-25-2011, 16:50 | #3 (permalink) | |
Freak Poster Join Date: Apr 2008
Member: 748428 Status: Offline Thanks Meter: 33 | Quote:
- back up RPL & PM - erase ( got advance-klik get adress-tick force whole flash) - full flash with correct firmware - restore imei if after that procedure can't local mode - go to service tab- tick BB5 software downgrade & BB5 RAP3NAND Erase User Area- do selecte job goodluck Last edited by ocha_vista; 02-25-2011 at 16:59. | |
The Following User Says Thank You to ocha_vista For This Useful Post: |
03-03-2011, 18:15 | #4 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | Hello, already try... When mxkey is erasing after a few seconds stay stuck and i have to close program in "X" Then try to flash with lower version and give error at the end.... anymore solutions?? |
The Following User Says Thank You to XPTO2511 For This Useful Post: |
03-07-2011, 13:41 | #6 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Noise City
Member: 889564 Status: Offline Thanks Meter: 336 | See this Tested by me and many more technicians http://forum.gsmhosting.com/vbb/f299...3/#post6582888 Follow point by point!!!Without point 2,that's all |
03-08-2011, 13:15 | #7 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | I many tanks this solution works.... But the problem remains.... Is strange because before the upgrade the bluetooth works... Then the *******r change the product code and upgrade to .52... Now i make the downgrade but the bluetooth and the radio don't work... |
03-08-2011, 13:40 | #8 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | Now write PM and check again You have full backup,right?!And don't forget after writing the PM to repair the SD (1-309 field with auth. with MX-key or Cyclone)and Unlock the set |
The Following User Says Thank You to DundyTM For This Useful Post: |
03-08-2011, 16:57 | #9 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | Here is the logs: MCU SW version: V ICPR72_09w44.4 20-11-09 RM-356 (c) Nokia HW version: 1101 RFIC version: 17141715 DSP version: ICPR72_09w43 APE SW Core version: V 40.0.005 APE Variant version: V 40.0.005V 40.0.005 V 40.0.005 APE Test version: eno_version Retu version: 16 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 Content Pack version: v 40.0.002_023_xxx_U01 27-11-09 vanilla RM356 WLAN ID: 00 B4 62 39 7D 24 Bluetooth ID: 00 24 7D 38 C6 74 DVB-H receiver Bootloader version: t 8 Product Info: Production serial number: CZB681854 Product code: 0577187 Basic production code: 0552692 Long production SN: 0 Serial Numbers: IMEI plain: 354183025501467 IMEI spare to net: 3A 45 81 03 52 05 41 06 IMEI SV to net: 33 45 81 03 52 05 41 56 F2 #pw+ 310733803335300 +7 # Other Info: Model: Nokia 5800 XpressMusic (Classic Phone) CS type: EGSM/DCS1800 BSI: 4,1 KOhm Imei net: 354183025501467 Version: SIMLOCK SERVER Provider: Optimus - Telecomunicaçôes, S.A. , Country: Portugal Counter: 0/3, 0/10 CONFIG_DATA: 2680300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=26803F [Portugal-Optimus - Telecomunicaçôes, S.A. ] BT mac self test ...failed BT mac reset ...OK. BT mac self test ...failed Writing PM Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (80 bytes) Warning: failed to write 1 - 35 (16 bytes) Warning: failed to write 1 - 37 (4 bytes) Warning: failed to write 1 - 39 (36 bytes) Warning: failed to write 1 - 44 (182 bytes) Warning: failed to write 1 - 45 (182 bytes) Section: 2 - Key: 0, size 448 bytes written. Section: 4 - Key: 1, size 80 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 28, size 2 bytes written. Section: 8 - Key: 0, size 2 bytes written. - Key: 1, size 16 bytes written. - Key: 2, size 16 bytes written. - Key: 3, size 128 bytes written. - Key: 4, size 128 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 8 bytes written. - Key: 10, size 24 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1061 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 2 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 2 bytes written. - Key: 10, size 2 bytes written. - Key: 11, size 2 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 1 bytes written. - Key: 16, size 1 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 2 bytes written. - Key: 20, size 2 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 1 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 4 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 1 bytes written. - Key: 47, size 16 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 20 bytes written. - Key: 51, size 10 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 20 bytes written. - Key: 54, size 10 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 1 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 1 bytes written. - Key: 61, size 1 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 1 bytes written. - Key: 64, size 1 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 32 bytes written. - Key: 67, size 32 bytes written. - Key: 68, size 2 bytes written. - Key: 69, size 2 bytes written. - Key: 70, size 2 bytes written. - Key: 71, size 2 bytes written. - Key: 72, size 2 bytes written. - Key: 73, size 2 bytes written. - Key: 74, size 2 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 2 bytes written. - Key: 79, size 2 bytes written. - Key: 80, size 2 bytes written. - Key: 81, size 2 bytes written. - Key: 82, size 2 bytes written. - Key: 83, size 2 bytes written. - Key: 84, size 2 bytes written. - Key: 85, size 2 bytes written. - Key: 86, size 2 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 2 bytes written. - Key: 89, size 2 bytes written. - Key: 90, size 2 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 2 bytes written. - Key: 93, size 2 bytes written. - Key: 94, size 2 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 2 bytes written. - Key: 97, size 2 bytes written. - Key: 98, size 2 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 2 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 2 bytes written. - Key: 103, size 2 bytes written. - Key: 104, size 2 bytes written. - Key: 105, size 2 bytes written. - Key: 106, size 2 bytes written. - Key: 107, size 2 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 2 bytes written. - Key: 110, size 2 bytes written. - Key: 111, size 2 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 1 bytes written. - Key: 116, size 4 bytes written. - Key: 117, size 4 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 16 bytes written. - Key: 121, size 4 bytes written. - Key: 122, size 2 bytes written. - Key: 123, size 2 bytes written. - Key: 124, size 685 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 26 - Key: 0, size 16 bytes written. - Key: 1, size 68 bytes written. Section: 31 - Key: 4, size 14 bytes written. Section: 44 - Key: 0, size 1 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 2 bytes written. - Key: 1, size 20 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 79 bytes written. - Key: 2, size 79 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. - Key: 26, size 12 bytes written. Section: 117 - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 8, size 26 bytes written. Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. - Key: 6, size 68 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 208 - Key: 1, size 4 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 291 - Key: 0, size 92 bytes written. Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Section: 313 - Key: 0, size 173 bytes written. Section: 322 - Key: 0, size 1 bytes written. Section: 329 - Key: 0, size 8392 bytes written. Section: 334 - Key: 0, size 1 bytes written. Section: 341 - Key: 0, size 1 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 4520 bytes written. Section: 354 - Key: 0, size 10 bytes written. Section: 356 - Key: 0, size 2 bytes written. - Key: 1, size 8 bytes written. Completed in 16.422 s The phone is already unlocked try to make the unlock again? The problem remains no radio no bluetooth |
03-09-2011, 09:24 | #10 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | Bro,you didn't write the PM as I told you!Use SX4 auth.and write 1-309 field!And there is "Bluetooth repair"button,why don't you use it? About ur question "Why should I unlock it again,it was already unlocked"??!-Always unlock ur set after messing with the PM,cause If there are somewhere bad section,unlocking the set repairs them... |
03-09-2011, 11:03 | #11 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | ok done Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 98 bytes written. - Key: 18, size 98 bytes written. - Key: 20, size 98 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 4 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 98 bytes written. - Key: 29, size 10 bytes written. - Key: 31, size 98 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 80 bytes written. - Key: 35, size 16 bytes written. - Key: 37, size 4 bytes written. - Key: 39, size 36 bytes written. - Key: 44, size 182 bytes written. - Key: 45, size 182 bytes written. Section: 2 - Key: 0, size 448 bytes written. Section: 4 - Key: 1, size 80 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 28, size 2 bytes written. Section: 8 - Key: 0, size 2 bytes written. - Key: 1, size 16 bytes written. - Key: 2, size 16 bytes written. - Key: 3, size 128 bytes written. - Key: 4, size 128 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 8 bytes written. - Key: 10, size 24 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1061 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 2 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 2 bytes written. - Key: 10, size 2 bytes written. - Key: 11, size 2 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 1 bytes written. - Key: 16, size 1 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 2 bytes written. - Key: 20, size 2 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 1 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 4 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 1 bytes written. - Key: 47, size 16 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 20 bytes written. - Key: 51, size 10 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 20 bytes written. - Key: 54, size 10 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 1 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 1 bytes written. - Key: 61, size 1 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 1 bytes written. - Key: 64, size 1 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 32 bytes written. - Key: 67, size 32 bytes written. - Key: 68, size 2 bytes written. - Key: 69, size 2 bytes written. - Key: 70, size 2 bytes written. - Key: 71, size 2 bytes written. - Key: 72, size 2 bytes written. - Key: 73, size 2 bytes written. - Key: 74, size 2 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 2 bytes written. - Key: 79, size 2 bytes written. - Key: 80, size 2 bytes written. - Key: 81, size 2 bytes written. - Key: 82, size 2 bytes written. - Key: 83, size 2 bytes written. - Key: 84, size 2 bytes written. - Key: 85, size 2 bytes written. - Key: 86, size 2 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 2 bytes written. - Key: 89, size 2 bytes written. - Key: 90, size 2 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 2 bytes written. - Key: 93, size 2 bytes written. - Key: 94, size 2 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 2 bytes written. - Key: 97, size 2 bytes written. - Key: 98, size 2 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 2 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 2 bytes written. - Key: 103, size 2 bytes written. - Key: 104, size 2 bytes written. - Key: 105, size 2 bytes written. - Key: 106, size 2 bytes written. - Key: 107, size 2 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 2 bytes written. - Key: 110, size 2 bytes written. - Key: 111, size 2 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 1 bytes written. - Key: 116, size 4 bytes written. - Key: 117, size 4 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 16 bytes written. - Key: 121, size 4 bytes written. - Key: 122, size 2 bytes written. - Key: 123, size 2 bytes written. - Key: 124, size 685 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 26 - Key: 0, size 16 bytes written. - Key: 1, size 68 bytes written. Section: 31 - Key: 4, size 14 bytes written. Section: 44 - Key: 0, size 1 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 2 bytes written. - Key: 1, size 20 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 79 bytes written. - Key: 2, size 79 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. - Key: 26, size 12 bytes written. Section: 117 - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 8, size 26 bytes written. Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. - Key: 6, size 68 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 208 - Key: 1, size 4 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 291 - Key: 0, size 92 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. Section: 313 - Key: 0, size 173 bytes written. Section: 322 - Key: 0, size 1 bytes written. Section: 329 - Key: 0, size 8392 bytes written. Section: 334 - Key: 0, size 1 bytes written. Section: 341 - Key: 0, size 1 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 4520 bytes written. Section: 354 - Key: 0, size 10 bytes written. Section: 356 - Key: 0, size 2 bytes written. - Key: 1, size 8 bytes written. The bluetooth repair that you say is "BT MMC Repair" ?? Already done but no sucess Says : BT MAC repair ...error : 0x11 |
