Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 10-02-2006, 19:21   #1 (permalink)
Member: 222583
Thanks Meter: 32
how to solve 6131 camera stand by(operation failed).
i have aphone with camera problem , the phone is new .
i try to flash it but noting , problem still .
what solution of this problem.
regards.
Old 10-02-2006, 21:50   #2 (permalink)
Member: 7621
Hardver Problem No Sw
Repair Original Nokia Service Center.
Old 11-08-2006, 19:07   #3 (permalink)
..::alexis::..'s Avatar
Member: 289200
Thanks Meter: 219
I have same problem after flashed pack "e". When I flashed pack "c" camera is working, but when I click OK to photograph phone write "File format is not supported", 10 sec LCD is white and camera is in stand by mode.
So I think it is soft problem. Please help me.
Old 11-08-2006, 19:32   #4 (permalink)
Member: 269021
Thanks Meter: 87
6131
Flash to the latest version!
it should fix da problem
use Mt-Box & Latest Flash wid Phoenix 2006
if not problem wid handset hardware!
Old 11-09-2006, 17:59   #5 (permalink)
Member: 289200
Thanks Meter: 219
I have no MT-Box- only JAF and UFSxHWK.
At first phone have version 3.50- I flash 3.70 pack "e" and have problem with camera- when I open it I have white LCD.When I flashed pack "c" camera is working but when I try to photograph is write "File format is not supported". Can I flash 3.72. It change situation?
Old 11-09-2006, 18:00   #6 (permalink)
Member: 333743
Thanks Meter: 8
5.50 was released yesterday, you can try flashing that.
Old 11-09-2006, 20:16   #7 (permalink)
Member: 289200
Thanks Meter: 219
can you attached it?
main and pack "c"
Old 11-10-2006, 00:34   #8 (permalink)
Member: 333743
Thanks Meter: 8
main and pack "c"
I don't know what pack "c" is. PM me your email and product code and I'll send you the files for that.
Old 11-10-2006, 13:22   #9 (permalink)
Member: 289200
Thanks Meter: 219
da123, please read PM.
Old 01-28-2007, 12:10   #10 (permalink)
Member: 88008
Thanks Meter: 10
help
my 6131 also same> camera operation failed !!!!
The Following User Says Thank You to ckkckk For This Useful Post:
Old 02-04-2007, 19:46   #11 (permalink)
Member: 289200
Thanks Meter: 219
it's really hardware problem.
Change camera module.
Old 10-09-2007, 14:25   #12 (permalink)
Member: 400705
Thanks Meter: 31
Changing flex cable solves the problem 100%!!! - just tried it myself
Old 08-23-2008, 13:29   #13 (permalink)
..::My3gtech::..'s Avatar
Member: 158032
Thanks Meter: 331
I have the same problem to the custmer says he press the button and open the flip at a time then this problem has been started i also think its strip fault but better to discues first because its better so any body who solve the fault..please reply.
Omairbutt786
Old 01-27-2009, 08:30   #14 (permalink)
saqib_islam's Avatar
Member: 446881
Thanks Meter: 707
someone have direct download links for 6131 please
Old 01-27-2009, 08:38   #15 (permalink)
Member: 446881
Thanks Meter: 707
Your Problem Is 100% Solved here. Just Check this out.
6131 Camera Problem
Mobile Repairing Picture Help
Nokia Phones Repairing Section
Sonyericsson Phone Repairing Section
If you like the post please HIT THANKS BUTTON
The Following 9 Users Say Thank You to saqib_islam For This Useful Post:
2330c camera on standby how to solve lilong_lee MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 02-25-2011 04:06
Nokia n73 after flash now camera not work, why and how to solve? svchost HWK 3 01-06-2010 03:55
how to solve (applet 2 not found! update using correct package!) [SOLVED] ammar715 FuriousGold 2 06-16-2009 21:28
how to disable 6131 camera saturn Nokia Base Band 5 ( BB-5 ) 1 04-26-2007 13:45
Page generated in 0.21395 seconds with 9 queries
