03-08-2009, 06:58 | #1 (permalink) |
Major Poster Join Date: Sep 2007 Location: Finland
Member: 597471 Status: Offline Thanks Meter: 4 | n70 config key 00000 no power this is the logs; JAF version 1.98.61 Detected PKEY: Card life counter: 80.84% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Backup IMEI zone... Setting local mode... Reading IMEI... Reading IMEI data... IMEI data corrupt... Getting MCUID... MCU ID: 0xFF81 Can't find boot file... Failed!!! Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk07v47 30-01-07 RM-84 (c) Nokia. HW version: 7001 PCI version: RFIC version: 150a160f DSP version: rolf_05wk07v29p1 Retu version: 32 Tahvo version: 52 Production serial number: CPE739082 Product code: 0524118 Module code: Basic production code: 0527595 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 351863012774341 IMEI spare to net: 3A 15 68 03 21 77 34 04 IMEI SV to net: 33 15 68 03 21 77 34 14 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0524118 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\ Searching for default location of ini... Checking path: \Products\RM-84\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! complete flashing but you cant switch on....ill tried to replace lcd cristal ic but no luck pls tell me the right procedure for this matter... |
03-08-2009, 07:59 | #4 (permalink) |
No Life Poster Join Date: Nov 2007 Location: quantum mss
Member: 638396 Status: Offline Sonork: 100.1615405 Thanks Meter: 170 | IMEI plain: 351863012774341 IMEI spare to net: 3A 15 68 03 21 77 34 04 IMEI SV to net: 33 15 68 03 21 77 34 14 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 I think imei & simlock data its OK sir.., try connect charger? any respon? |
03-08-2009, 08:31 | #6 (permalink) |
Member: 638396 Status: Offline Sonork: 100.1615405 Thanks Meter: 170 | when flashing process is completed.., whether the phone enter local mode ( show nokia in display ) if yes.., check switch on/off ways.., |
n95 (rm-159_) config key 00000 | nishantha | HWK | 0 | 08-22-2009 10:34 |
n96 config key 00000 unknown provider done by pm 120 & unlock by cyclone | shawgsm | Cyclonebox | 5 | 07-12-2009 19:25 |
6085 config key 00000 to FFFFFFFFFFFF | patric | Nokia Base Band 5 ( BB-5 ) | 3 | 06-14-2009 14:09 |
*n70 config key ffffff resolved via bb5 free version no tp and no pkey* | GELANEROB | Nokia Base Band 5 ( BB-5 ) | 4 | 12-12-2008 07:55 |
