Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 10-02-2008, 09:06   #1 (permalink)
Member: 534073
Thanks Meter: 68
n73 restarts problem
n73 switch on the phone starts and few second the display fade away and then restart again.canot info canot flash.help...pls...
Old 10-02-2008, 09:20   #2 (permalink)
piyush.kothiya's Avatar
Member: 515506
Thanks Meter: 28
Dear friend
if you are useing JAF box or other box, use leatest flash file (version 4.0750.31.2.1 or 4.0812.4.2.1) after flash do it format user area, then do factoryset, and if u are use mmc card then before use memory card you have to format first then u can use,
otherwise if u don't have any software box, then remove batter, remove mmc, then insirt batter press switch (call key + * key + 3 key + power key) hold all key, until menu not comes on screen, then select country, then formate mmc card on computer then u can use your handset
i hope your problem will solved, otherwise check hardware,
thanks
piyush
The Following 3 Users Say Thank You to piyush.kothiya For This Useful Post:
Old 10-02-2008, 09:36   #3 (permalink)
Member: 534073
Thanks Meter: 68
i have hwk jaf ub box . my problem s can't connect
Old 10-02-2008, 09:38   #4 (permalink)
Member: 534073
Thanks Meter: 68
key 4 wd2 only not on bb5 phone
Old 10-04-2008, 07:32   #5 (permalink)
Member: 515506
Thanks Meter: 28
you can use this key 4 BB5, on display there is no format shows, but internaly is formated, ok
i have tried and i got resullt, just try and do it
piyush
Old 10-06-2008, 09:08   #6 (permalink)
Member: 534073
Thanks Meter: 68
piyush
THANKS 4 THE HELP . my n73 ok
Old 10-06-2008, 14:12   #7 (permalink)
Member: 236726
Thanks Meter: 11
sir n70 every thing ok butt white lcd what prblem ?
thanks n advance
Old 10-06-2008, 14:20   #8 (permalink)
Member: 796626
Thanks Meter: 2
remove vcore ic just short vcore&vio
The Following User Says Thank You to afsal pt For This Useful Post:
Old 10-06-2008, 14:44   #9 (permalink)
Member: 870358
Thanks Meter: 2
N73 No power on
When write flash with mt-box has finish but not power on but when I write with n-box is shown error not finish.as picture below please help me.
Thank you
Old 10-10-2008, 07:43   #10 (permalink)
Member: 515506
Thanks Meter: 28
Thank you
dear friend
use JAF and give logs, may be after flash procedure faild
thanks
piyush
Old 10-10-2008, 07:45   #11 (permalink)
Member: 515506
Thanks Meter: 28
dear arnoldobalobao
i m not saying without test, so please check i hope you understand,
thanks
piyush
Old 10-10-2008, 07:48   #12 (permalink)
Member: 421573
Sonork: 100.1650534
Thanks Meter: 54
chang the software and mmc
Old 10-10-2008, 07:50   #13 (permalink)
Member: 421573
Sonork: 100.1650534
Thanks Meter: 54
Dear friend
thanks
imran
Old 10-27-2008, 07:45   #14 (permalink)
Member: 870358
Thanks Meter: 2
n70+ power problem
I have n70 some time it easy to power on , some time it no power on,, but when i put it maybe 3 to 5 minute it can power on ,,,,,,, pl help me , thanks,,,,,,,,,
Old 10-27-2008, 19:53   #15 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
hehot RAM UPP its will be work for u
Nokia N73 M Restart Problem remains after updating sumedhmeshram Nokia Base Band 5 ( BB-5 ) 11 10-22-2013 08:26
N73 restart problem. .::AkhavanGSM::. Nokia Hardware & Hardware Repair 17 09-26-2011 16:39
<<< n73 goes off or restarting problem when playing music >>> mawxep03 Universalbox 2 12-02-2009 13:35
N76 Power off and Restart... N73..Mic Problem lath123 Nokia Base Band 5 ( BB-5 ) 5 07-11-2007 22:11
n73 restart problem waleedy Nokia Base Band 5 ( BB-5 ) 1 10-18-2006 22:18
Page generated in 0.22316 seconds with 10 queries
