10-02-2008, 09:20 | #2 (permalink) |
Freak Poster Join Date: May 2007
Member: 515506 Status: Offline Thanks Meter: 28 | Dear friend if you are useing JAF box or other box, use leatest flash file (version 4.0750.31.2.1 or 4.0812.4.2.1) after flash do it format user area, then do factoryset, and if u are use mmc card then before use memory card you have to format first then u can use, otherwise if u don't have any software box, then remove batter, remove mmc, then insirt batter press switch (call key + * key + 3 key + power key) hold all key, until menu not comes on screen, then select country, then formate mmc card on computer then u can use your handset i hope your problem will solved, otherwise check hardware, thanks piyush |
The Following 3 Users Say Thank You to piyush.kothiya For This Useful Post: |
10-04-2008, 07:32 | #5 (permalink) |
Member: 515506 Status: Offline Thanks Meter: 28 | you can use this key 4 BB5, on display there is no format shows, but internaly is formated, ok i have tried and i got resullt, just try and do it piyush |
10-06-2008, 14:44 | #9 (permalink) |
Junior Member Join Date: Sep 2008 Location: Cambodia Age: 45
Member: 870358 Status: Offline Thanks Meter: 2 | N73 No power on When write flash with mt-box has finish but not power on but when I write with n-box is shown error not finish.as picture below please help me. Thank you |
10-10-2008, 07:50 | #13 (permalink) |
Freak Poster Join Date: Dec 2006 Location: PAKISTAN Age: 38
Member: 421573 Status: Offline Sonork: 100.1650534 Thanks Meter: 54 | Dear friend if you are useing JAF box or other box, use leatest flash file (version 4.0750.31.2.1 or 4.0812.4.2.1) after flash do it format user area, then do factoryset, and if u are use mmc card then before use memory card you have to format first then u can use, otherwise if u don't have any software box, then remove batter, remove mmc, then insirt batter press switch (call key + * key + 3 key + power key) hold all key, until menu not comes on screen, then select country, then formate mmc card on computer then u can use your handset i hope your problem will solved, otherwise check hardware, thanks imran |
10-27-2008, 07:45 | #14 (permalink) |
Member: 870358 Status: Offline Thanks Meter: 2 | n70+ power problem I have n70 some time it easy to power on , some time it no power on,, but when i put it maybe 3 to 5 minute it can power on ,,,,,,, pl help me , thanks,,,,,,,,, |
Nokia N73 M Restart Problem remains after updating | sumedhmeshram | Nokia Base Band 5 ( BB-5 ) | 11 | 10-22-2013 08:26 |
N73 restart problem. | .::AkhavanGSM::. | Nokia Hardware & Hardware Repair | 17 | 09-26-2011 16:39 |
<<< n73 goes off or restarting problem when playing music >>> | mawxep03 | Universalbox | 2 | 12-02-2009 13:35 |
N76 Power off and Restart... N73..Mic Problem | lath123 | Nokia Base Band 5 ( BB-5 ) | 5 | 07-11-2007 22:11 |
n73 restart problem | waleedy | Nokia Base Band 5 ( BB-5 ) | 1 | 10-18-2006 22:18 |
