Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Windows & MeaMo/MeeGo based
Nokia Windows & MeaMo/MeeGo based N900,N9,N950,700,710,N800,800,920,925 etc all linux and WP phones flashing & unlocking only here
Old 01-17-2010, 07:46   #1 (permalink)
Member: 540878
Thanks Meter: 910
N900 hangup successfully flashed/updated by MAEMO Flasher 3.5
phone looks like this one.....for the newbies or not familiar this phone
status of the phone upon arrival, nokia only then you will see the 5 dotted white circles on the center
you need the following:
1.firmware -you can download it from navifirm.. If you have no navifirm ( navifirm.exe - 72 Kb)
..use the latest version, sample i am using this firmware
RX-51_2009SE_2.2009.51-1.003_PR_F5_003_ARM
for convenience download it here: http://depositfiles.com/files/be78stu6o
2.maemo_flasher-3.5_2.5.2.2
http://depositfiles.com/files/0fenjtg5n
3.usb cable
intructions:
* Download and install the maemo flasher
* Download the latest firmware (.bin) file and save to ‘c:\Program Files\maemo\flasher-3.5\’
so it is the content of folder flasher-3.5
* Fully charge the battery.
* Unplug charger and switch off the device.
* Open the command prompt on XP. Start + Run. Type cmd and press Enter.
* Change directory to the flasher program
cd "c:\Program Files\maemo\flasher-3.5"
* Connect the USB cable while pressing ‘u’ key on the N900
1. Turn off Maemo device
2. Press and hold down key ‘u’
3. Connect USB cable between Maemo device and host PC while holding down key ‘u’
4. When USB cable gets connected it powers Maemo device and set’s it to flashing mode
5. When USB icon appears on right upper corner Maemo device is in flashing mode
6. You can release key ‘u’
* Run the following command:
flasher-3.5.exe -F RX-51_2009SE_2.2009.51-1.003_PR_F5_003_ARM.bin -f -R
The update will take about 4 minutes after which the N900 will reboot and display the Welcome screen with Regional settings.
screenshot in flashing
logs in flashing
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\SoftwareMan 1>cd c:\Program Files\maemo\flasher-3.5
C:\Program Files\maemo\flasher-3.5>flasher-3.5.exe -F RX-51_2009SE_2.2009.51-1.0
flasher v2.5.2 (Sep 24 2009)
SW version in image: RX-51_2009SE_2.2009.51-1.003_PR_003
Image 'kernel', size 1704 kB
Version 2.6.28-20094803.3+0m5
Image 'rootfs', size 153344 kB
Version RX-51_2009SE_2.2009.51-1.003_PR_003
Image 'cmt-2nd', size 81408 bytes
Version BB5_09.36
Image 'cmt-algo', size 519808 bytes
Version BB5_09.36
Image 'cmt-mcusw', size 5824 kB
Version rx51_ICPR82_09w47
Image '2nd', size 14720 bytes
Version 1.4.14.2+0m5
Image 'xloader', size 14848 bytes
Image 'secondary', size 109440 bytes
USB device found found at bus bus-0, device address \\.\libusb0-0001--0x0421-0x0
105.
Found device RX-51, hardware revision 2101
NOLO version 1.4.13
Version of 'sw-release': RX-51_2009SE_1.2009.44-1.002_PR_002
Sending xloader image (14 kB)...
100% (14 of 0 kB, avg. 14 kB/s)
Sending secondary image (106 kB)...
100% (106 of 0 kB, avg. 106 kB/s)
Flashing bootloader... done.
Sending cmt-2nd image (79 kB)...
100% (79 of 0 kB, avg. 79 kB/s)
Sending cmt-algo image (507 kB)...
100% (507 of 0 kB, avg. 507 kB/s)
Sending cmt-mcusw image (5824 kB)...
100% (5824 of 0 kB, avg. 5824 kB/s)
Flashing cmt-mcusw... done.
Sending kernel image (1704 kB)...
100% (1704 of 0 kB, avg. 1704 kB/s)
Flashing kernel... done.
Sending and flashing rootfs image (153344 kB)...
100% (153344 of 0 kB, avg. 153344 kB/s)
Finishing flashing... done
CMT flashed successfully
finished product
The Following 51 Users Say Thank You to professor linux For This Useful Post:
Old 01-17-2010, 09:26   #2 (permalink)
Member: 311880
Thanks Meter: 13
You thing n900 have thai language?
The Following 2 Users Say Thank You to VASUVAT For This Useful Post:
Old 01-27-2010, 07:04   #3 (permalink)
trustunna's Avatar
Member: 63279
Thanks Meter: 8
Hello guys
Somebody should pls upload files; as above links are not working for now.
Thanx
Old 01-27-2010, 07:41   #4 (permalink)
aiyon_861's Avatar
Member: 586707
Thanks Meter: 129
Originally Posted by trustunna View Post
Hello guys
Thanx
check here maemo SW
http://tablets-dev.nokia.com/maemo-d...-downloads.php
http://tablets-dev.nokia.com/nokia_N900.php
The Following User Says Thank You to aiyon_861 For This Useful Post:
Old 02-01-2010, 23:49   #5 (permalink)
Member: 152547
Sonork: 100.1586021
Thanks Meter: 143
this is incredible.....................
Old 02-06-2010, 10:02   #6 (permalink)
Member: 924746
Thanks Meter: 7
something is not working with me
these are my logs
C:\Documents and Settings\user-_>cd "c:\Program Files\maemo\flasher-3.5"
C:\Program Files\maemo\flasher-3.5>flasher-3.5.exe -F RX-51_2009SE_1.2009.42-11_
PR_COMBINED_MR0_ARM.bin -f -R
RX-51_2009SE_1.2009.42-11_PR_COMBINED_MR0_ARM.bin: %m
plllllllzz help
Old 03-08-2010, 15:59   #7 (permalink)
Member: 313953
the flash finish successfully but my phone not power on. press power and the phone show me the nokia logo for 5 sec and after reboot and off.
WHY ?? please help me !!!
The Following User Says Thank You to galactob For This Useful Post:
Old 04-15-2010, 11:51   #8 (permalink)
Crazy Poster
Member: 947508
Thanks Meter: 2
Red face Pls what can i do to my N900
Pls help me solve this problem for me,I got a Nokia N900 phone but to my greatest suprise i can dial the * and hash button on my phone,in my country we use the * and the hash button to load a recharge card.whenever i try it it tells me wrong input.Pls help
Old 04-17-2010, 17:09   #9 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
This problem is fixed in new version, just update.
The Following User Says Thank You to nasirahmed For This Useful Post:
Old 06-26-2010, 17:07   #10 (permalink)
Member: 159411
Thanks Meter: 8
flasher is not starting
C:\Program Files\maemo\flasher-3.5>flasher.exe -f RX-51_2009SE_1.2009.42-11.002_
PR_COMBINED_002_ARM.bin -f -r
flasher.exe: option requires an argument -- r
Usage: flasher [OPTIONS]
Options:
-F, --fiasco=ARG Location of a FIASCO image
-k, --kernel=ARG Location of kernel image
-n, --initfs=ARG Location of initfs image
-r, --rootfs=ARG Location of root JFFS2 image
--cmt-2nd=ARG Location of CMT FIASCO 2nd image
--cmt-algo=ARG Location of CMT FIASCO algorithm image
--cmt-mcusw=ARG Location of CMT FIASCO MCUSW image
--cmt-no-verify Disable verification of CMT programming
-x, --xloader=ARG Location of X-Loader image
-s, --secondary=ARG Location of NOLO secondary bootloader image
-2, --2nd=ARG Location of NOLO cold flasher ("2nd") image
-u, --unpack[=ARG] Unpack a FIASCO image
-f, --flash Load and flash all supplied images
-l, --load Only load all supplied images
-b, --boot[=ARG] Boot the kernel with optional cmdline
-R, --reboot Reboot the board (e.g. after flashing NOLO)
-i, --read-device-id Print out the device type
-S, --serial-port=ARG Serial port used for cold flashing or "usb"
-I, --init-port Only initialize the serial port
-c, --cold-flash "Cold flash" the device
-h, --hw-revision=ARG Specify product code and HW revision
--enable-rd-mode Enable R&D mode on the device
--disable-rd-mode Disable R&D mode on the device
--set-rd-flags[=ARG] Set R&D mode flags on the device
--clear-rd-flags[=ARG] Clear R&D mode flags on the device
--query-rd-mode Query the device R&D mode status and flags
--set-hw-revision[=ARG] Set HW revision override on device
--flash-only=ARG Flash only certain components
-U, --usb-device=ARG Specify USB device to use (bus:device address)
what is wrong ı need help
Old 06-26-2010, 22:30   #11 (permalink)
Member: 171888
Thanks Meter: 16
thanks brother good wrong
Old 10-14-2010, 17:18   #12 (permalink)
saeed ahmed's Avatar
Member: 997212
Sonork: 100.1590912
Thanks Meter: 42
these are my logs
plllllllzz help
same problem here how to solv
Old 10-19-2010, 05:38   #13 (permalink)
rajeshchiyyan's Avatar
Member: 1347585
Sonork: 100.1596390
Thanks Meter: 467
Thumbs up wait i will post soon ......
these are my logs
plllllllzz help
wait i fasing nw same problem i will post the result how to solve .,., soon .
Old 10-19-2010, 07:00   #14 (permalink)
shahabuddin's Avatar
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
for better help u need to check the two links for n900 of all flashing problem
http://forum.gsmhosting.com/vbb/f609...3/#post5986780
the second link is from mx-key
http://forum.gsmhosting.com/vbb/f550...1/#post6025709
The Following 3 Users Say Thank You to shahabuddin For This Useful Post:
Old 10-19-2010, 08:19   #15 (permalink)
Member: 1347585
Sonork: 100.1596390
Thanks Meter: 467
Thumbs up yes here is the solution brother .....
@shaeed ahmed and khawaja16
these are my logs
plllllllzz help
these are my logs
plllllllzz help
this problem is version of file or damaged files problem .,.,.
i have yesterday to the same problem .,
done the problem by using this file
Deposit Files
and open the cmd .,
set this or pase it to cmd > cd "c:\Program Files\maemo\flasher-3.5"
then hit enter
then
agin u paste this like >flasher-3.5.exe -F RX-51_2009SE_2.2009.51-1.003_PR_F5_003_ARM.bin -f -R
then hit enter
when u hit enter u will see like this
then u need press and hold the u buttorn on the device then insert usb ., the flashing start it's take 4 to 5 mins ..............
The Following 3 Users Say Thank You to rajeshchiyyan For This Useful Post:
:: Maemo Flasher 3.5_2.5.2.2 :: Gabiunlock Universal GSM Software 4 06-09-2011 10:34
N900 maemo flasher 3.5 problem ahmad5175 Nokia Windows & MeaMo/MeeGo based 8 03-29-2011 09:33
06/05/2008 New update MicroBox LG_cr1.4.3.5 midou01 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 1 05-06-2008 09:56
Bad update for BB5BOX ( 3.5 )!!!!!!!!!! PLEASE SOLVE THE PROBLEM migsacho BB5BOX 34 01-30-2008 21:57
DISCUSSION: BB5BOX Update BB5 v0.0.3.5 - added 2 unlock methods shahzaadbutt BB5BOX 90 01-27-2008 18:55
Page generated in 0.31155 seconds with 10 queries
