08-20-2009, 08:52 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Location: Location:
Member: 751758 Status: Offline Thanks Meter: 113 | Nokia 5800 - just shows Nokia and goes off Please advice me what to do If You need any log just ask. p.s.: jaf, mt, ub, cyclone, hwk etc. are present Last edited by c1rca; 08-20-2009 at 08:57. |
08-20-2009, 09:03 | #3 (permalink) |
Member: 751758 Status: Offline Thanks Meter: 113 | JAF 1.98.64 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V ICPR72_09w20.5 16-06-09 RM-356 (c) Nokia HW version: 1101 PCI version: RFIC version: DSP version: APE SW Core version: V 30.0.011 APE Variant version: V 30.0.011V 30.0.011 V 30.0.011 APE Test version: eno_version Retu version: 16 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 Production serial number: CIP007994 Product code: 0574569 Module code: Basic production code: 0558954 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 354183xxxxxxxxxxx IMEI spare to net: 3A 45 81 xxxxx IMEI SV to net: 3A 45 81 xxxxx LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2343300000000000 Provider: Orange;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23433F Block 2: Lock 1: CLOSED -> Lock Data: 23486F Block 3: Lock 1: CLOSED -> Lock Data: 23433F Block 4: Lock 1: CLOSED -> Lock Data: 23486F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-356.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0574569 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-356\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_11.0.008_prd.core.C00 PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_11.0.008_prd.rofs2.V01 CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_11.0.008_red_prd.rofs3.fpsx APE Variant file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-356\RM-356_11.0.008.udaerase.fpsx Languages in ppm: English,French,German,Italian,Spanish,Portuguese Done! Last edited by c1rca; 08-20-2009 at 09:11. |
08-20-2009, 09:22 | #6 (permalink) |
Member: 751758 Status: Offline Thanks Meter: 113 | LOCK STATUS: CONFIG KEY: 0000000000000000 - this shouldn't be zeroes after RPL is written I guess? PROVIDER KEY: 2343300000000000 Provider: Orange;United Kingdom Key Code count: 0, FBUS Code count: 0 |
08-20-2009, 09:36 | #7 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Quote:
Hi, Write Full pm without 120,308 field, with sx4 auth, use mxkey software, then full flash FW 30.0.011, your ST_SECURITY_TEST failed your problem solve. | |
08-20-2009, 09:42 | #8 (permalink) | |
Member: 751758 Status: Offline Thanks Meter: 113 | Quote:
5300 only nokia and goes off | sameer918 | Nokia Base Band 5 ( BB-5 ) | 43 | 08-20-2009 08:14 |
nokia 2730 hangs and goes off. | Teepat | Nokia Hardware & Hardware Repair | 0 | 01-13-2009 21:04 |
9300 just shows Nokia.. then LCD Goes Blank | bakhshalvi007 | Nokia Hardware & Hardware Repair | 14 | 02-17-2008 11:52 |
e700 just display a quik image showing samsung and power off | patric | SYSOL Platform | 4 | 06-29-2004 22:39 |
