![]() | #46 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2005 Location: India ( Punjab ) / China Age: 38
Member: 154749 Status: Offline Sonork: 100.92483 Thanks Meter: 1,048 | Quote:
welll only problem you get without Diego install i have tested today and after clean pc manualy just install deigo then phoniex no problem at alll i test and i got this slution just and just problem without diego WBR mr999 | |
![]() | #48 (permalink) |
Junior Member ![]() Join Date: May 2006
Member: 277400 Status: Offline Thanks Meter: 0 | I don't know how many times I tried but once I had followed word to word the tutorial to instal Pheonix, the screen just keeps saying RETRY. I was fast enought to click the Crack but it still going on with RETRY. I can't install Pheonix at all, I have tried on my friend computer, it still can't not install at all. PLEASE HELP ME. I NEED TO REMOVE VODAFONE FIRMWARE AS ITS NOT ALLOW ME TO INSTALL ANY SOFTWARE ON MY NOKIA 6630 |
![]() | #49 (permalink) | |
Major Poster ![]() ![]() Join Date: May 2006
Member: 272275 Status: Offline Thanks Meter: 0 | Quote:
Here a solution: Put "phoenix crack all" on c:\windows\system32 folder NOT c:\windows\system, immidiately press Retry on phoenix installation dialog box button. It work for me. And remember to put crack "phoenix 2006" in your phoenix folder. By default on XP english version is c:\program files\nokia\phoenix BUT IN MY COMPUTER DEFAULT FOLDER IS c:\programmi\nokia\phoenix. Ok? These ways rox for me. | |
![]() | #50 (permalink) | |
Member: 277400 Status: Offline Thanks Meter: 0 | Quote:
However, I have put "phoenix crack all" into c:\windows\system32 folder but once I click install Phoenix, the problem is still "RETRY" keep annoying. | |
![]() | #51 (permalink) |
Junior Member Join Date: Oct 2006
Member: 367905 Status: Offline Thanks Meter: 0 | well i try to install it Phoenix but do i need a dongle it says please insert dongle and click retry i install cracks but it doesnt work can anyone help plz thank u if i need one which is the best one to get thanks |
![]() | #52 (permalink) | |
(over c:\windows\system32) ONLY AFTER PRESS RETRY!!!! BUT DO IT IMMIDIATELY! Don't wait more than 1 or 2 seconds! When installation done, install crack_dongle_phoenix_2006 on your phoenix folder.(folder where is located your phoenix .exe file) Then don't start phoenix. First REBOOT YOUR COMPUTER!. It's easy. PS remeber to install Diego 307sp2 before install Phoenix 2006. | |
![]() | #53 (permalink) | |
![]() | #55 (permalink) | |
but its works... ![]() WBR Mr999 | |
![]() | #56 (permalink) |
Junior Member ![]() ![]() Join Date: Sep 2006 Location: cebu Age: 42
Member: 347580 Status: Offline Thanks Meter: 1 | Hi Mr999 after i installed the phoenix it will prompt me to restart the computer so i click on restart after the phoenix will try to register all components. after the registration it display an error message registration failed. And when i tried to run the phoenix it gives an error message........ Error loading component HRESULT 0x800401f3 (-2147221005) This means: Invalid class string Component ID "NMP.Cmn.connectionfn.ConnectionManager" is not registered;Phoenix Component Manager=0x80070057 CreateComponentInstance() - Could not obtain a CLSID from the given string "NMP.Cmn.connectionfn.ConnectionManager";Phoen ix Component Manager=0x800401f3 parsing action string 10005;Phoenix Menu Extension Manager=0x800401f3 Registering cmnconnectionfn.dll failed: Error msg: DllRegisterServer in C:\Program Files\Nokia\Phoenix\Framework\cmnconnectionfn.dll failed. - Registering displaytest.dll failed: Error msg: DllRegisterServer in C:\Program Files\Nokia\Phoenix\displaytest.dll failed. Pls help!!!!!!!! tnx!!!!!!! |
![]() | #57 (permalink) | |
uninstall all applications about nokia from Installed applications panel of Windows XP.(like phoenix, fls4, dk2, sw update, connectivity drivers, diego, pc suite etc) Now use a registry cleaner to clear your system's registry from invalids keys. (make a registry backup first) After that reboot your computer and retry to install diego 307sp2 first and phoenix 2006 after! This way works great. | |
![]() | #59 (permalink) | |
Plug in phone's DC cable and make sure to have battery 100%load. Plug USB cable in your pc and phone to USB cable. Wait for Windows XP to recognize phone's hardware. Open Phoenix. Go to Manage connections. Select "New connection", then "USB connection" and make "Automatic USB confuguration". Now if Phoenix has correctly identified your phone, in the bottom bar you can see phone's model and firmware versions. If it didn't identify your phone, try to restart phoenix or press "Scan product" over File menu. Now go on Tools->Options->Product Polling and select "Automatic polling". This is an useful function to avoid Phoenix lost connection with phone. Now surf over "Flashing" menu and select "SW Update". Let Phoenix to identify your Model and "Product Code". Now it will select all needed files for you.(only two files are needed for unbranded euro models) Usually you would have to only change "PPM File".(Where are stored languages, settings etc) Select a "PPM File" containing your language. Do not change "Image File" or "Product Code" if u can't understand what you are doing. Select only correct "Image File" and "PPM File". Be sure that "Image File" and "PPM File" are from same Firmware version or your phone will be unable to boot. Press "Start" and quietly wait for the end. If Phoenix 2006_34_2_56 quit without errors during firmware update, don't worry. Restart Phoenix, make it reidentify your phone that was in upgrade mode. It will ask to you for complete upgrate. This a simple guide. Nobody help me to learn. I learn by myself. So take it easy. If you encounter some problems buy JAF or use Nokia Centers Assistance, if you are not are able to use it. I make some errors to learn and i spent a lot of money over phones to learn. Well i think you can just "try" at your own risk before to be sure have learned. Ok? PS Sorry for my poor english! | |
![]() | #60 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2003 Age: 49
Member: 41760 Status: Offline Thanks Meter: 16 | Quote:
Have any way to install cracked app to iphone 3G 3.0 ??? | svchost | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 06-25-2009 00:34 |
have any way to install applications to iphone with usb cable without wifi??? | svchost | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 02-16-2009 13:00 |
some one told me the way to install totalmoto | kikoman | TotalMoto | 7 | 01-15-2005 20:36 |
step by step way to install usb drivers??? | infogsm | Motorola P2k | 4 | 08-18-2003 12:51 |
A way to install Phone Data Package without installing Phoenix | BufferMess | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 01-10-2003 12:09 |
