08-02-2005, 08:37 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Saudi Arabia - Jeddah
Member: 145783 Status: Offline Thanks Meter: 36 | Phone Start-up Failed - PHONE IS NOKIA 6630 After Installation The Java Games Pink Panther And Tom & Jerry, I Restarted The Phone But The Message Is Coming "phone Start-up Failed. Contact The Retailer" Please Help Me To Start My Phone............... |
The Following 2 Users Say Thank You to nshkw For This Useful Post: |
08-02-2005, 08:41 | #3 (permalink) | |
Member: 145783 Status: Offline Thanks Meter: 36 | Quote:
Appreciating your early response. Regards NSHKW | |
The Following User Says Thank You to nshkw For This Useful Post: |
08-02-2005, 08:47 | #4 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 41
Member: 78673 Status: Offline Thanks Meter: 1,253 | @nshkw The Same also happend to my 6630, after installing many Appz like Talks_s60 etc...Try Removing the Battery and then turn oyur Phone ON, if this doesn't works then Try Hard resetting your Device by Press & Holding the 3 Buttons (Green Dial Button, no.3 Button, and the * Button) until the 'NOKIA' Logo comes on the Screen and becomes still for 2-3 min. |
08-02-2005, 08:59 | #5 (permalink) | |
Upon your instruction, I removed the battery and then restart the phone the message still the same "Phone Start-up Failed" now should I press the Green Dial and 3 and * buttons now or switch off the phone and press or switch on the phone then apply your instruction. Please advise NSHKW | |
08-02-2005, 09:06 | #7 (permalink) | |
REGARDS NSHKW | |
08-02-2005, 09:16 | #8 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Sofia Age: 43
Member: 77941 Status: Offline Thanks Meter: 120 | can you read? 1.turn phone off 2.press Green+3+*+power on 3.still hold them to see "formating" 4.if not formated use JAF or PBB for format user area end regards |
The Following User Says Thank You to tostefo For This Useful Post: |
08-02-2005, 10:41 | #10 (permalink) | |
Freak Poster Join Date: Jan 2004 Age: 57
Member: 50105 Status: Offline Thanks Meter: 8 | Quote:
u can use griffin box to make format user area i try it more and more time and make it ok | |
The Following User Says Thank You to emad1999 For This Useful Post: |
08-25-2005, 14:21 | #12 (permalink) |
Member: 145783 Status: Offline Thanks Meter: 36 | I am revising this thread again this problem is coming oftenly in 6630, because today I had the same and I applied the button as mentioned by HuBMOBILE and then now working well. |
06-28-2006, 18:52 | #14 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Tanzania but U cant see me !!! Age: 43
Member: 228601 Status: Offline Thanks Meter: 56 | Hi ineed real solution for 6630 phone start- up failed. contact the retailer ive finished flash with jaf with mcu 5.050321 bt still same problem need realy help |
Phone Start-up Failed - PHONE IS NOKIA 7610 | jbbasha | WD2 & APE (Symbian Phones) | 25 | 07-28-2009 05:38 |
6630 phone start-up failed cotact the retailer | ashrafcell | Nokia Hardware & Hardware Repair | 13 | 09-11-2007 08:39 |
6630 phone start up failed Help..... | sbcomyap | Nokia Base Band 5 ( BB-5 ) | 3 | 05-23-2006 11:42 |
6630, Phone start-up Fail | Yashaka | MT-BOX | 12 | 02-09-2006 12:09 |
