10-28-2009, 17:37 | #1 (permalink) |
Major Poster Join Date: Mar 2008
Member: 722214 Status: Offline Thanks Meter: 8 | Self Test Definitions SIM_CLK_LOOP check clock SIM cards SIM_IO_CTRL_LOOP check the flow of data on your SIM card SLEEP_X_LOOP checking standby UEM_CBUS_IF_CBUS_IF data bus UEM module KEYBOARD_STUCK test chip ESD protection of the keyboard. CAMERA_IF checking data bus from the camera to the processor BACKUP_BATT check backup battery voltage. LPRF_AUDIO_LINES check LPF sound CURRENT_CONS checking current sensor RADIO radio test unit BACKLIGHT check lights SIM_LOCK checking the status of SIM locks SECURITY SECURITY checking the status of the zone. BT_WAKEUP verification module Bluetooth. HOOKINT checking power on the microphone TAHVOINT TAHVOINT check with chip TAHVO SLEEPCLK_FREQ check CPU clock in the standby mode. BTEMP check battery temperature sensor BT_SLEEP_CLK check standby Bluetooth module. CDSP_RF_BB_IF verification data bus from the main unit to the radio unit BaseBand RF CDSP_RF_SUPPLY Check Your power radio unit RF CDSP_TX_IQ check modulating signal transmitter. CDSP_TXC_DATA test transmitter control. CDSP_RX_PLL_PHASE_LOCK check capture heterodyne receiver. CDSP_TX_PLL_PHASE_LOCK check capture heterodyne transmitter. CDSP_RX_IQ_LOOP_BACK check the output signals of the receiver. CDSP_GSM_TX_POWER check the transmitter power IRDA_LED_STRESS testing infrared AUX_DA_LOOP check the definition of external accessories TX_IDP_LOOP test transmitter control. TX_IQ_DP_LOOP check modulating signal transmitter. MBUS_RX_TX_LOOP check contact phone programming WARRANTY test data safeguards PPM_VALIDITY match version to version MCU PPM FLASH_CHECKSUM using checksum program your phone. EXT_RAM_DATA_BUS verification data bus to the RAM EXT_RAM_ADDR_BUS check the address bus to the RAM IR_IF testing infrared |
self test definition progrsm | sanathpeiris | Nokia Base Band 5 ( BB-5 ) | 0 | 10-28-2009 18:00 |
Self test on 8310 give this error. | Pandemonio100 | Nokia Hardware & Hardware Repair | 5 | 07-13-2004 12:00 |
2110 - self test failed | Coronator | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-23-2003 15:53 |
Contact Service and Self Tests | epilog | GSM Programming & Reverse Engineering | 2 | 08-20-2002 19:28 |
