Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 03-28-2010, 07:40   #1 (permalink)
md.nazmul's Avatar
Member: 648428
Thanks Meter: 846
nokia 5530 When Make calls the mobile power off
When Make calls the mobile power off plz any one help me
The Following 2 Users Say Thank You to md.nazmul For This Useful Post:
Old 03-28-2010, 07:47   #2 (permalink)
Member: 978854
Thanks Meter: 33
Any Solution pls i have also same problem.......
The Following 2 Users Say Thank You to Waseem-y For This Useful Post:
Old 03-28-2010, 07:49   #3 (permalink)
jabed_net's Avatar
Member: 538824
Thanks Meter: 274
i have also same problem pls help,,,,,,,,,,,,,,,,,,,,,
Old 03-28-2010, 07:52   #4 (permalink)
selimphone's Avatar
Member: 362328
Sonork: 100.1592511
Thanks Meter: 715
1st chack ear sp 2nd softwere
Old 03-28-2010, 07:53   #5 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
first check with software
if there is any damage in super dongle
if software is ok
then change ear piece
if not ok then it will be pfo
Old 03-28-2010, 08:13   #6 (permalink)
vertex777's Avatar
Member: 746552
Sonork: 100.1594844
Thanks Meter: 110
for nokia 5530 I faced same problem..after many work my phone had complited,
if phone are make restart in both time incoming or outgoing. for solve you can try by software.
if faced this problem when making call you can try to solve this problem by hardware.
you should open the phone and cheque by different way,,,, such as,,,mother board *******, short, lcd attaching etc.
by this way I think you will be able to solve your problem.
Old 03-28-2010, 08:27   #7 (permalink)
vertex777's Avatar
Member: 746552
Sonork: 100.1594844
Thanks Meter: 110
try this way ........ I think your problem will be solved
you should open the phone and cheque by different way,,,, such as,,,mother board ******** , short, lcd attaching etc.
The Following User Says Thank You to vertex777 For This Useful Post:
Old 03-28-2010, 08:30   #8 (permalink)
transpirit's Avatar
Member: 950964
Thanks Meter: 161
i have same problem with 5130 but not solved every thing i tried but unsucceed
Old 03-28-2010, 09:06   #9 (permalink)
Registered User
Member: 493205
Sonork: 100.1581647
Thanks Meter: 526
here solution sir
The Following 12 Users Say Thank You to yarra For This Useful Post:
Old 03-28-2010, 09:46   #10 (permalink)
Member: 231600
Thanks Meter: 44
Cover or change speaker cable ! Work 100% .Tested by me
Old 03-28-2010, 09:57   #11 (permalink)
Member: 145234
Thanks Meter: 34
@yarra
Where is that capacitor?
The Following 3 Users Say Thank You to ....adolf.... For This Useful Post:
Old 03-28-2010, 11:50   #12 (permalink)
md.nazmul's Avatar
Member: 648428
Thanks Meter: 846
Originally Posted by yarra View Post
here solution sir
yes 100% working solution tested by me
The Following 5 Users Say Thank You to md.nazmul For This Useful Post:
Old 03-28-2010, 19:13   #13 (permalink)
jabed_net's Avatar
Member: 538824
Thanks Meter: 274
thanks for your information..............
The Following 5 Users Say Thank You to jabed_net For This Useful Post:
Old 03-28-2010, 19:19   #14 (permalink)
Member: 890856
Thanks Meter: 135
thanx for advance info....
The Following User Says Thank You to dipak9331331333 For This Useful Post:
Old 03-28-2010, 19:20   #15 (permalink)
Member: 1091160
Sonork: 12345
Thanks Meter: 8
nokia 5530 auto off when making call vertex777 Nokia Base Band 5 ( BB-5 ) 13 03-01-2012 11:05
5530 rm-504 Off when making Calls,Flash Ok --Same. blaiseid Nokia Base Band 5 ( BB-5 ) 43 07-10-2010 00:19
5530 Make calls the mobile power off 100% tested solution md.nazmul Nokia Base Band 5 ( BB-5 ) 11 05-22-2010 09:01
motorolla auto power off when making call HITGSM2001 Motorola Hardware Repair 4 06-17-2002 05:43
Page generated in 0.23129 seconds with 10 queries
