Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
09-20-2000, 04:41 | #1 (permalink) |
Freak Poster Join Date: Jun 2000
Member: 1623 Status: Offline Thanks Meter: 1 | Urgently help !!! A1018s is dead... I had a A1018s 00W18 version.My friend has been used wrong software.Phone doesn't work with any software.I tried to load EEPROM with bartek or ATXEE program.Never success. ER2000,ER2001,Saras 2.2,Datex 2.2,Ne-tool 121,RSSPY and a lot of flasher didn't flash the phone. First time, in ER2001 ,it didn't advance second press (after selecting flash file name) no button.Then i used eeprom load program.But they didn't give any response.After some uploading,they give an error. Then i opened the phone and desoldered the 24C256 (under chip it writes 4256W...) eeprom.And using Ponyprog i read the contents of eeprom.I was suprised.In the eeprom it gives an exe file header and the other ( This program reqires Microsoft Windows...). Then i used any other version A1018 eeprom and write to this eeprom.After beginning flash again , Until Erase flash section , there was no problem.But every programs don't erase flash. How can i erase flash or repair this phone ? And also i need 00W18 eeprom bin file. Thanks in advance and Best regards... |
09-20-2000, 11:11 | #3 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | Hello, I used to have 4 dead A1018s, all were 00W09, there must be somehardware bug in this version. Anyway, I fixed it using process below: 1. Open unit and use EEPROM Hardware to Load valid EEPROM dump from a working unit. 2. Run Saras 2.2 soft (cracked) Put IMEI After you turn on the phone, you will get insert correct card... 3. Run Ericsson 2000 by Deezle and use the default bin file for A1018. After flashing you will still get insert correct card... 4. Now unlock the phone using RS SPY by Superdupond. The phone will be unlocked! Problems: 1 out of the 4 A1018s automatically restarts everytime I try to send an SMS. I can still use the phone to call. Does anyone know how to fix this? I already tried all bin files found in the net for a1018 but still none worked. Maybe this is hardware problem. Best Regards, X-Shadow |
09-23-2000, 12:07 | #5 (permalink) |
Guest
Posts: n/a
Member: | Hi, (repair 1018) 1.You must desolder the eeprom and programming it correct bin file (PonyProg). 2.Put eeprom in to the phone. 3.Flach phone (CXC 125119 R5A 000114 1514). 4.Press phone "ON" phone says corect "INSERT SIM CARD". After this procedure phone is working successful but is locked. *************************************** (corect you must unlock your phone!!!) If you need corect bin or flach mail my Best regards Juozas |
please is urgent help me iphone dead | ABI-GSM | iPhone 2 / iPhone 3G / iPhone 3GS | 6 | 06-20-2008 17:53 |
My erisccon A1018s is dead | demianas | Old Ericsson Phones & Sony Phones | 1 | 12-10-2001 09:42 |
HELP -- A1018s is 00w11 -- HELP | Svetli | Old Ericsson Phones & Sony Phones | 3 | 05-06-2000 16:12 |
HELP -- A1018s is 00w11 -- HELP | Svetli | Old Ericsson Phones & Sony Phones | 1 | 05-04-2000 03:04 |
