6124c unlocking successfully MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Detecting BB5 USB device... Reading Info... MCU Version: V 04.34 Date: 05-03-08 Type: RM-422 (6124C-1) Additional_1: (c) Nokia [Nokia 6124C-1] PPM Version: V 04.34 Date: 05-03-08 Type: RM-422 (6124C-1) Pack: (c) Nokia Product code: 0565106 Original IMEI: ****************** Production serial: KLL534776 HW Version: 0851 DSP Version: ICPR71_08w08 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [01000407031E] Profile bits: 8000000000000000 Simlock config: 2320100000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 23201F You should install the following application to the phone: s60_3_1_app_trk_2_8_6.sisx, or s60_3_1_app_trk_2_8_9.sisx from path C:\Uni\Files\Nokia\BB5\ using Nokia PCSuite. After installing please start the TRK application, and set the Connection to USB in the Options/Settings menu and connect it to your computer by selecting the Options/Connect menu Detecting BB5 USB device... Uploading application... Application installed, please press on phone "Options" => "Hello" Calculating code... Connecting to server: US3 Credits: xxxx Credits Left: xxxx Unlocking phone... Unlock done Detecting BB5 USB device... Reading Info... MCU Version: V 04.34 Date: 05-03-08 Type: RM-422 (6124C-1) Additional_1: (c) Nokia [Nokia 6124C-1] PPM Version: V 04.34 Date: 05-03-08 Type: RM-422 (6124C-1) Pack: (c) Nokia Product code: 0565106 Original IMEI: ****************** Production serial: KLL534776 HW Version: 0851 DSP Version: ICPR71_08w08 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [01000407031E] Profile bits: 8000000000000000 Simlock config: 2320100000000000 Invalid codes entered: 0 / 0 All locks are open.:) good solution from ub team thx |
hi thanxx for sharing man ...............really ub on fire............wbr varun |
thx bro really UB is best box in the world gooood update enjoy |
6120c unlocking successfully too!!!! TBB5OnlineS60UnlockThread started at: 2008/11/03 11:23:31 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Detecting BB5 USB device... Reading Info... MCU Version: V 05.11 Date: 21-04-08 Type: RM-243 (6120C-1 CLASSIC) Additional_1: (c) Nokia [Nokia 6120C-1 CLASSIC CABLE 5500/6120] PPM Version: V 05.11 Date: 21-04-08 Type: RM-243 (6120C-1 CLASSIC) Pack: (c) Nokia Product code: 0546339 Original IMEI: ****************** Production serial: MXG394269 HW Version: 0602 DSP Version: 06w41pb_08w08.0.1_rm243 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 8000000000000000 Simlock config: 2342000000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 23420F Block: 2; Lock: 1; State: Closed; Data: 23594F Security code: 12345 You should install the following application to the phone: s60_3_1_app_trk_2_8_6.sisx, or s60_3_1_app_trk_2_8_9.sisx from path C:\Uni\Files\Nokia\BB5\ using Nokia PCSuite. After installing please start the TRK application, and set the Connection to USB in the Options/Settings menu and connect it to your computer by selecting the Options/Connect menu Detecting BB5 USB device... Uploading application... Application installed, please press on phone "Options" => "Hello" Calculating code... Connecting to server: US3 Credits: 6230 Credits Left: 6130 Unlocking phone... Unlock done Detecting BB5 USB device... Reading Info... MCU Version: V 05.11 Date: 21-04-08 Type: RM-243 (6120C-1 CLASSIC) Additional_1: (c) Nokia [Nokia 6120C-1 CLASSIC CABLE 5500/6120] PPM Version: V 05.11 Date: 21-04-08 Type: RM-243 (6120C-1 CLASSIC) Pack: (c) Nokia Product code: 0546339 Original IMEI: ****************** Production serial: MXG394269 HW Version: 0602 DSP Version: 06w41pb_08w08.0.1_rm243 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 8000000000000000 Simlock config: 2342000000000000 Invalid codes entered: 0 / 0 All locks are open. Security code: 12345 -------------------------------------------------------------------------------- TBB5OnlineS60UnlockThread finished at: 2008/11/03 11:27:16 Done.:):):):):) |
help me please .... step by step install s60_3_1_app_trk_2_8_6.sisx to phone .... because can't install in myphone |
Please Try to Factory Reset and Format your Phone and try again, if still not solve Please make new thread with all necessary details how you try to unlock bla bla |
6120c 3g unlock successfully MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Detecting BB5 USB device... Reading Info... MCU Version: V 03.70 Date: 25-05-07 Type: RM-243 (6120C-1 CLASSIC) Additional_1: (c) Nokia [Nokia 6120C-1 CLASSIC CABLE 5500/6120] PPM Version: V 03.70 Date: 25-05-07 Type: RM-243 (6120C-1 CLASSIC) Pack: (c) Nokia Product code: 0552203 Original IMEI: ****************** Production serial: MMI618602 HW Version: 0801 DSP Version: pb06w41v31.1_rm243 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 8000000000000000 Simlock config: 2342000000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 23420F Block: 2; Lock: 1; State: Closed; Data: 23594F You should install the following application to the phone: s60_3_1_app_trk_2_8_6.sisx, or s60_3_1_app_trk_2_8_9.sisx from path C:\Uni\Files\Nokia\BB5\ using Nokia PCSuite. After installing please start the TRK application, and set the Connection to USB in the Options/Settings menu and connect it to your computer by selecting the Options/Connect menu Detecting BB5 USB device... Uploading application... Application installed, please press on phone "Options" => "Hello" Calculating code... Connecting to server: US3 Credits: xxxx Credits Left: xxxx Unlocking phone... Unlock done Detecting BB5 USB device... Reading Info... MCU Version: V 03.70 Date: 25-05-07 Type: RM-243 (6120C-1 CLASSIC) Additional_1: (c) Nokia [Nokia 6120C-1 CLASSIC CABLE 5500/6120] PPM Version: V 03.70 Date: 25-05-07 Type: RM-243 (6120C-1 CLASSIC) Pack: (c) Nokia Product code: 0552203 Original IMEI: ****************** Production serial: MMI618602 HW Version: 0801 DSP Version: pb06w41v31.1_rm243 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 8000000000000000 Simlock config: 2342000000000000 Invalid codes entered: 0 / 0 All locks are open. |
Ub on peak hi thanxx for sharing man ...............really ub on fire............wbr varun |
how many credits it will coast on 6120c unlocking can u con vate in usd its how much . |
n81 unlock successfully MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Detecting BB5 USB device... Reading Info... MCU Version: V 06wk41v56.1 Date: 18-04-08 Type: RM-223 (N81-3) Additional_1: (c) Nokia [Nokia N81-3 CABLE N81] PPM Version: V 06wk41v56.1 Date: 18-04-08 Type: RM-223 (N81-3) Pack: (c) Nokia Product code: 0563536 Original IMEI: ****************** Production serial: CMF953829 HW Version: 0542 DSP Version: bruce_mc.ICPR62_08w15 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 0000000000000000 Simlock config: 2140100000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 21401F Block: 2; Lock: 1; State: Closed; Data: 21401F Security code: 12345 -------------------------------------------------------------------------------- TBB5OnlineS60UnlockThread finished at: 2004/01/01 03:06:15 Terminated with error: No COM port found [00012211] MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBOYRSRM] TBB5OnlineS60UnlockThread started at: 2004/01/01 03:06:20 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Detecting BB5 USB device... Reading Info... MCU Version: V 06wk41v56.1 Date: 18-04-08 Type: RM-223 (N81-3) Additional_1: (c) Nokia [Nokia N81-3 CABLE N81] PPM Version: V 06wk41v56.1 Date: 18-04-08 Type: RM-223 (N81-3) Pack: (c) Nokia Product code: 0563536 Original IMEI: ****************** Production serial: CMF953829 HW Version: 0542 DSP Version: bruce_mc.ICPR62_08w15 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 0000000000000000 Simlock config: 2140100000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 21401F Block: 2; Lock: 1; State: Closed; Data: 21401F Security code: 12345 You should install the following application to the phone: s60_3_1_app_trk_2_8_6.sisx, or s60_3_1_app_trk_2_8_9.sisx from path C:\Uni\Files\Nokia\BB5\ using Nokia PCSuite. After installing please start the TRK application, and set the Connection to USB in the Options/Settings menu and connect it to your computer by selecting the Options/Connect menu Detecting BB5 USB device... Uploading application... Application installed, please press on phone "Options" => "Hello" Calculating code... Connecting to server: US3 Credits: xxxx Credits Left: xxxx Unlocking phone... Unlock done Detecting BB5 USB device... Reading Info... MCU Version: V 06wk41v56.1 Date: 18-04-08 Type: RM-223 (N81-3) Additional_1: (c) Nokia [Nokia N81-3 CABLE N81] PPM Version: V 06wk41v56.1 Date: 18-04-08 Type: RM-223 (N81-3) Pack: (c) Nokia Product code: 0563536 Original IMEI: ****************** Production serial: CMF953829 HW Version: 0542 DSP Version: bruce_mc.ICPR62_08w15 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 0000000000000000 Simlock config: 2140100000000000 Invalid codes entered: 0 / 0 All locks are open. Security code: 12345 |
6120 85 credits its very very expansive crazy thing my custumers call me a thief I can not charge a price as high as is the world crisis everybody is with less money but the heads of UB are not worried about it Either way good job of UB |
very Good info keep it up |
