Universalbox Universalbox Official support area |
11-03-2008, 07:32 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mobile Phone Repairing
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | 6124c unlocking successfully SMCU Nokia Version: 1.42, and up to date. Detecting BB5 USB device... Reading Info... MCU Version: V 04.34 Date: 05-03-08 Type: RM-422 (6124C-1) Additional_1: (c) Nokia [Nokia 6124C-1] PPM Version: V 04.34 Date: 05-03-08 Type: RM-422 (6124C-1) Pack: (c) Nokia Product code: 0565106 Original IMEI: ****************** Production serial: KLL534776 HW Version: 0851 DSP Version: ICPR71_08w08 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [01000407031E] Profile bits: 8000000000000000 Simlock config: 2320100000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 23201F You should install the following application to the phone: s60_3_1_app_trk_2_8_6.sisx, or s60_3_1_app_trk_2_8_9.sisx from path C:\Uni\Files\Nokia\BB5\ using Nokia PCSuite. After installing please start the TRK application, and set the Connection to USB in the Options/Settings menu and connect it to your computer by selecting the Options/Connect menu Detecting BB5 USB device... Uploading application... Application installed, please press on phone "Options" => "Hello" Calculating code... Connecting to server: US3 Credits: xxxx Credits Left: xxxx Unlocking phone... Unlock done Detecting BB5 USB device... Reading Info... MCU Version: V 04.34 Date: 05-03-08 Type: RM-422 (6124C-1) Additional_1: (c) Nokia [Nokia 6124C-1] PPM Version: V 04.34 Date: 05-03-08 Type: RM-422 (6124C-1) Pack: (c) Nokia Product code: 0565106 Original IMEI: ****************** Production serial: KLL534776 HW Version: 0851 DSP Version: ICPR71_08w08 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [01000407031E] Profile bits: 8000000000000000 Simlock config: 2320100000000000 Invalid codes entered: 0 / 0 All locks are open. good solution from ub team thx |
The Following 12 Users Say Thank You to rajeshbahri For This Useful Post: |
11-03-2008, 10:54 | #4 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Bulgaria/Germany Age: 47
Member: 104573 Status: Offline Thanks Meter: 35 | 6120c unlocking successfully too!!!! TBB5OnlineS60UnlockThread started at: 2008/11/03 11:23:31 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Detecting BB5 USB device... Reading Info... MCU Version: V 05.11 Date: 21-04-08 Type: RM-243 (6120C-1 CLASSIC) Additional_1: (c) Nokia [Nokia 6120C-1 CLASSIC CABLE 5500/6120] PPM Version: V 05.11 Date: 21-04-08 Type: RM-243 (6120C-1 CLASSIC) Pack: (c) Nokia Product code: 0546339 Original IMEI: ****************** Production serial: MXG394269 HW Version: 0602 DSP Version: 06w41pb_08w08.0.1_rm243 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 8000000000000000 Simlock config: 2342000000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 23420F Block: 2; Lock: 1; State: Closed; Data: 23594F Security code: 12345 You should install the following application to the phone: s60_3_1_app_trk_2_8_6.sisx, or s60_3_1_app_trk_2_8_9.sisx from path C:\Uni\Files\Nokia\BB5\ using Nokia PCSuite. After installing please start the TRK application, and set the Connection to USB in the Options/Settings menu and connect it to your computer by selecting the Options/Connect menu Detecting BB5 USB device... Uploading application... Application installed, please press on phone "Options" => "Hello" Calculating code... Connecting to server: US3 Credits: 6230 Credits Left: 6130 Unlocking phone... Unlock done Detecting BB5 USB device... Reading Info... MCU Version: V 05.11 Date: 21-04-08 Type: RM-243 (6120C-1 CLASSIC) Additional_1: (c) Nokia [Nokia 6120C-1 CLASSIC CABLE 5500/6120] PPM Version: V 05.11 Date: 21-04-08 Type: RM-243 (6120C-1 CLASSIC) Pack: (c) Nokia Product code: 0546339 Original IMEI: ****************** Production serial: MXG394269 HW Version: 0602 DSP Version: 06w41pb_08w08.0.1_rm243 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 8000000000000000 Simlock config: 2342000000000000 Invalid codes entered: 0 / 0 All locks are open. Security code: 12345 -------------------------------------------------------------------------------- TBB5OnlineS60UnlockThread finished at: 2008/11/03 11:27:16 Done. |
The Following User Says Thank You to bachgoro For This Useful Post: |
11-03-2008, 23:36 | #6 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Aunlock Age: 43
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | Please Try to Factory Reset and Format your Phone and try again, if still not solve Please make new thread with all necessary details how you try to unlock bla bla |
11-04-2008, 07:30 | #7 (permalink) |
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | 6120c 3g unlock successfully MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Detecting BB5 USB device... Reading Info... MCU Version: V 03.70 Date: 25-05-07 Type: RM-243 (6120C-1 CLASSIC) Additional_1: (c) Nokia [Nokia 6120C-1 CLASSIC CABLE 5500/6120] PPM Version: V 03.70 Date: 25-05-07 Type: RM-243 (6120C-1 CLASSIC) Pack: (c) Nokia Product code: 0552203 Original IMEI: ****************** Production serial: MMI618602 HW Version: 0801 DSP Version: pb06w41v31.1_rm243 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 8000000000000000 Simlock config: 2342000000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 23420F Block: 2; Lock: 1; State: Closed; Data: 23594F You should install the following application to the phone: s60_3_1_app_trk_2_8_6.sisx, or s60_3_1_app_trk_2_8_9.sisx from path C:\Uni\Files\Nokia\BB5\ using Nokia PCSuite. After installing please start the TRK application, and set the Connection to USB in the Options/Settings menu and connect it to your computer by selecting the Options/Connect menu Detecting BB5 USB device... Uploading application... Application installed, please press on phone "Options" => "Hello" Calculating code... Connecting to server: US3 Credits: xxxx Credits Left: xxxx Unlocking phone... Unlock done Detecting BB5 USB device... Reading Info... MCU Version: V 03.70 Date: 25-05-07 Type: RM-243 (6120C-1 CLASSIC) Additional_1: (c) Nokia [Nokia 6120C-1 CLASSIC CABLE 5500/6120] PPM Version: V 03.70 Date: 25-05-07 Type: RM-243 (6120C-1 CLASSIC) Pack: (c) Nokia Product code: 0552203 Original IMEI: ****************** Production serial: MMI618602 HW Version: 0801 DSP Version: pb06w41v31.1_rm243 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 8000000000000000 Simlock config: 2342000000000000 Invalid codes entered: 0 / 0 All locks are open. |
11-07-2008, 09:00 | #11 (permalink) |
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | n81 unlock successfully MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Detecting BB5 USB device... Reading Info... MCU Version: V 06wk41v56.1 Date: 18-04-08 Type: RM-223 (N81-3) Additional_1: (c) Nokia [Nokia N81-3 CABLE N81] PPM Version: V 06wk41v56.1 Date: 18-04-08 Type: RM-223 (N81-3) Pack: (c) Nokia Product code: 0563536 Original IMEI: ****************** Production serial: CMF953829 HW Version: 0542 DSP Version: bruce_mc.ICPR62_08w15 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 0000000000000000 Simlock config: 2140100000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 21401F Block: 2; Lock: 1; State: Closed; Data: 21401F Security code: 12345 -------------------------------------------------------------------------------- TBB5OnlineS60UnlockThread finished at: 2004/01/01 03:06:15 Terminated with error: No COM port found [00012211] MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBOYRSRM] TBB5OnlineS60UnlockThread started at: 2004/01/01 03:06:20 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Detecting BB5 USB device... Reading Info... MCU Version: V 06wk41v56.1 Date: 18-04-08 Type: RM-223 (N81-3) Additional_1: (c) Nokia [Nokia N81-3 CABLE N81] PPM Version: V 06wk41v56.1 Date: 18-04-08 Type: RM-223 (N81-3) Pack: (c) Nokia Product code: 0563536 Original IMEI: ****************** Production serial: CMF953829 HW Version: 0542 DSP Version: bruce_mc.ICPR62_08w15 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 0000000000000000 Simlock config: 2140100000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 21401F Block: 2; Lock: 1; State: Closed; Data: 21401F Security code: 12345 You should install the following application to the phone: s60_3_1_app_trk_2_8_6.sisx, or s60_3_1_app_trk_2_8_9.sisx from path C:\Uni\Files\Nokia\BB5\ using Nokia PCSuite. After installing please start the TRK application, and set the Connection to USB in the Options/Settings menu and connect it to your computer by selecting the Options/Connect menu Detecting BB5 USB device... Uploading application... Application installed, please press on phone "Options" => "Hello" Calculating code... Connecting to server: US3 Credits: xxxx Credits Left: xxxx Unlocking phone... Unlock done Detecting BB5 USB device... Reading Info... MCU Version: V 06wk41v56.1 Date: 18-04-08 Type: RM-223 (N81-3) Additional_1: (c) Nokia [Nokia N81-3 CABLE N81] PPM Version: V 06wk41v56.1 Date: 18-04-08 Type: RM-223 (N81-3) Pack: (c) Nokia Product code: 0563536 Original IMEI: ****************** Production serial: CMF953829 HW Version: 0542 DSP Version: bruce_mc.ICPR62_08w15 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [010000060C08] Profile bits: 0000000000000000 Simlock config: 2140100000000000 Invalid codes entered: 0 / 0 All locks are open. Security code: 12345 |
11-07-2008, 15:54 | #12 (permalink) |
Junior Member Join Date: Sep 2004 Location: Brasil Age: 52
Member: 82113 Status: Offline Thanks Meter: 11 | 6120 85 credits its very very expansive crazy thing my custumers call me a thief I can not charge a price as high as is the world crisis everybody is with less money but the heads of UB are not worried about it Either way good job of UB |
6124c unlocking problem | CHAUDHRAY ARSHAD | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 03-20-2010 09:35 |
6124c unlock universalbox | shahid41 | Universalbox | 1 | 06-15-2009 09:50 |
6124c Unlocked Smoothly | Mr.3. | Cyclonebox | 1 | 05-27-2009 10:23 |
6124c unlock successfull | ahmadge | Nokia Base Band 5 ( BB-5 ) | 0 | 04-26-2009 14:35 |
