Universalbox Universalbox Official support area |
06-09-2008, 06:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: INDIA-uttranchal-rishikesh Age: 47
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | nokia start- up failed contect retailer i done formet use area 2-i flash MCU Version: V 05wk07v48.1 Date: 28-08-07 Type: RM-84 (N70) Additional_1: (c) Nokia. PPM Version: V 05wk07v48.1 Date: 28-08-07 Type: RM-84 (N70) Pack: (c) Nokia. Product code: 0539276 Original IMEI: 356294-01-284468-3 Production serial: CTD489165 HW Version: 7003 DSP Version: rolf_05wk07v29p1 LCD Version: 2728220 APE ADSP Version: 16054 SIMLock service: SIMLOCK SERVER VERSION 58 [040900040C16] Invalid codes entered: 0 All locks are open. |
06-09-2008, 06:48 | #3 (permalink) |
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | any mate explain me what is the meaning of this word nokia start- up failed contect retailer how to remove this problem............ sanjay bhatt........... |
06-09-2008, 06:49 | #4 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Where the cash @... Age: 38
Member: 450871 Status: Offline Sonork: 100.1592197 Thanks Meter: 121 | Quote:
06-09-2008, 08:31 | #7 (permalink) |
No Life Poster Join Date: Oct 2004 Location: IRELAND
Member: 87357 Status: Offline Thanks Meter: 9,457 | First Try with Latest Version ,and write Pm with out 308 Value if still same Problem Make Back up first 1:Erase 2:Full Flash 3:Make SX4 auth and write pm without 308 value Note :if You have still same problem Then You need Only Full Flash again Regards F@iSaL |
06-09-2008, 09:38 | #10 (permalink) | |
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | Quote:
I DID FLASH TO =Reading Info... MCU Version: V 05wk07v48.1 Date: 28-08-07 Type: RM-84 (N70) Additional_1: (c) Nokia. PPM Version: V 05wk07v48.1 Date: 28-08-07 Type: RM-84 (N70) Pack: (c I READ FULL AREA PM LILE.... 1- HOW WRITE THIS 1=Pm with out 308 Value?????????? 2-Make SX4 auth and write pm without 308 value .????????/ I HAVE PM FILE ==1-N70_rm-84.pm 2-N70_RM-84_2.pm 3-N70_RM-84_rpl.pm WHICH CAN I WRITE IT...... | |
06-09-2008, 09:48 | #11 (permalink) |
No Life Poster Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | change the ver its work for u many time it happend with me i try wiith latest ver its work if dont work change the box before someday 6630 dont work with jaff fectery setting fail then i try UFSX its work for me |
06-09-2008, 20:21 | #12 (permalink) | |
Member: 87357 Status: Offline Thanks Meter: 9,457 | Quote:
Regards F@iSaL | |
06-10-2008, 07:14 | #15 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Malappuram. INDIA
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | Hello here is the 100% solution for all BB5 start up failed. 1.do pm authentication. 2.write a good pm. it will be ok if after this phone is same condition or phone is local mode failed do following 1.erase phone using 6 erase files one by one in universal box.( also can use jaf or mt ) 2.full flash phone 3.then phone will on but imei will be "12345....?" 4.write rpl in any tool (it will lost credit). set will be again "start up failed....." 5.do pm Authenticaion , and write good pm file set will be ok M A Sabah Malapuram |
Nokia 3650 Start up failed.Contact retailer! | Dido76 | WD2 & APE (Symbian Phones) | 9 | 07-21-2013 11:49 |
nokia n73 start up failed contect retailer | theonly1 | Nokia Hardware & Hardware Repair | 17 | 09-15-2010 11:42 |
6600 phone start up failed contect the retailer | bharatg | Nokia Hardware & Hardware Repair | 20 | 04-01-2008 11:19 |
