Universalbox Universalbox Official support area |
06-30-2011, 13:38 | #166 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 647 | <<<< unİversalbox n900 flashİng ok>>>> SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device Waiting for USB device... Sending programming image... done. Sending secondary (109440 bytes)... done. Cold flashing successful, doing warm flash. Device requires reset. Device reset. Sending xloader image (14 kB)... Sending secondary image (106 kB)... Flashing bootloader... done. Sending cmt-2nd image (79 kB)... Sending cmt-algo image (507 kB)... Sending cmt-mcusw image (5826 kB)... Flashing cmt-mcusw... done. Sending kernel image (1705 kB)... Flashing kernel... done. Sending and flashing rootfs image (185856 kB)... Finishing flashing... done Erasing CMT (7360 kB)... Programming CMT (5826 kB)... CMT flashed successfully MCUSW file (c:\program files\nokia\phoenix\products\RX-51\RX-51_2009SE_20.2010.36-2.002_PR_COMBINED_002_ARM.bin) flashed successfully Device requires reset. Device reset. Waiting for phone to come online max 120 seconds... Loading default data to phone Getting Data Package Reading product state Backup sub-procedure started: mode change post delay Backup data item started: EmergencyNumbers, version: 1.0 Backup/restore result: 1 out of 1 items were not backed up -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.3.2824 finished at: 2011.06.30 15:37:48 Done. THANX UNİVERSALBOX TEAM |
06-30-2011, 13:47 | #167 (permalink) |
Member: 706822 Status: Offline Thanks Meter: 647 | << unİversalbox n900 flashİng ok>> MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device Waiting for USB device... Sending programming image... done. Sending secondary (109440 bytes)... done. Cold flashing successful, doing warm flash. Device requires reset. Device reset. Sending xloader image (14 kB)... Sending secondary image (106 kB)... Flashing bootloader... done. Sending cmt-2nd image (79 kB)... Sending cmt-algo image (507 kB)... Sending cmt-mcusw image (5826 kB)... Flashing cmt-mcusw... done. Sending kernel image (1705 kB)... Flashing kernel... done. Sending and flashing rootfs image (185856 kB)... Finishing flashing... done Erasing CMT (7360 kB)... Programming CMT (5826 kB)... CMT flashed successfully MCUSW file (c:\program files\nokia\phoenix\products\RX-51\RX-51_2009SE_20.2010.36-2.002_PR_COMBINED_002_ARM.bin) flashed successfully Device requires reset. Device reset. Waiting for phone to come online max 120 seconds... Loading default data to phone Getting Data Package Reading product state Backup sub-procedure started: mode change post delay Backup data item started: EmergencyNumbers, version: 1.0 Backup/restore result: 1 out of 1 items were not backed up -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.3.2824 finished at: 2011.06.30 15:37:48 Done. thanx universalbox team |
07-04-2011, 08:52 | #168 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1050365 Status: Offline Thanks Meter: 210 | Nokia 6120c flashed TBB5USBFlashThread 2.9.3.2824 with filepack 7.78 started at: 2011/07/04 13:03:41 -------------------------------------------------------------------------------- MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device Loading secondary boot code: 15296 bytes Secondary boot loaded Loading update server code: 2164525 bytes Update server loaded Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Error sending ADL_LDR_GET_MS_INFO_REQ Error parsing MS info data. Attempting to continue flashing Flashing SingleAsic device... Asic CMT: Start programming 65443 KB... Asic CMT: Erasing rm243_07.20_prd_core.fpsx Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Partitioning rm243_07.20_prd_core.fpsx Asic CMT: Partitioning area 1... Asic CMT: Erasing rm243_07.20_prd_vEM09_01_elisa_fi.fpsx Asic CMT: Erasing area 1... Asic CMT: Erasing rm243_07.20_prd_uda_erase.fpsx Asic CMT: Erasing area 1... Asic CMT: Programming rm243_07.20_prd_core.fpsx Asic CMT: Programming rm243_07.20_prd_vEM09_01_elisa_fi.fpsx Finished Flashing Rebooting to RFS Mode Asic CMT: Verifying communication to device... Loading default data to phone Getting Data Package Reading product state Backup sub-procedure started: data item pre-delay Backup data item started: ProductProfile, version: 1.0 Backup sub-procedure started: data item post-delay Backup/restore result: 0 out of 1 items were not backed up -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.3.2824 finished at: 2011/07/04 13:07:43 |
07-07-2011, 15:26 | #170 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,709 | C6-01 flashed successfully with uni hi every body know the new nokia phone C6-01.RM-718...so,this phone had been pawned successfully with uni box,here is the log: Code: Dcp: E:\Uni\Files\Nokia\BB5\C6-01.RM-718\14.2\RM718_059C3Z2_014.002_004.dcp Binary Mcu: E:\Uni\Files\Nokia\BB5\C6-01.RM-718\14.2\RM-718_014.002_79.92_prd.core.fpsx Binary Ppm: E:\Uni\Files\Nokia\BB5\C6-01.RM-718\14.2\RM-718_014.002_08.01_Hebrew_79.92_prd.rofs2.fpsx Binary Ppm: E:\Uni\Files\Nokia\BB5\C6-01.RM-718\14.2\RM-718_014.002_00.01_79.92_prd.rofs3.fpsx Signature: E:\Uni\Files\Nokia\BB5\C6-01.RM-718\14.2\RM718_059C3Z2_014.002_004_signature.bin Languages: English, Arabic, French, Hebrew, Russian TBB5USBFlashThread 2.9.3.2824 with filepack 7.78 started at: 2011/07/05 19:37:25 -------------------------------------------------------------------------------- MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device Waiting for USB device... Loading secondary boot code: 15168 bytes Secondary boot loaded BB Asic Index is: 00 Asic ID is: 000000030000022600010007600C192102031104 BB Asic Index is: 00 EM Asic ID is: 00001040 BB Asic Index is: 00 EM Asic ID is: 00001030 BB Asic Index is: 00 Public ID is: 17E0000D82D45840E6518CE6643E9198023A8925 BB Asic Index is: 00 Asic Mode ID: 00 BB Asic Index is: 00 Hash: 916F75217F32081248B15C38DFC8E81B BB Asic Index is: 00 ROM ID: E693EF0DAC22615B BB Asic Index is: 00 Device type is: 05 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 04 Device Index is: 00 Manufacturer code: FFFF Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 01 Manufacturer code: 0000 Device ID: 0001 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 03 Device Index is: 00 Manufacturer code: 00EC Device ID: 0060 Extended device ID: 0000 Revision ID: 0032 Loading update server code: 812904 bytes Update server loaded Asic CMT: Start programming 157153 KB... Programming complete Asic CMT: Verifying communication to device... Loading default data to phone Getting Data Package Reading product state Backup sub-procedure started: data item pre-delay Backup data item started: ProductProfile, version: 1.1 Backup sub-procedure started: data item post-delay Backup/restore result: 0 out of 1 items were not backed up -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.3.2824 finished at: 2011/07/05 19:39:24 Done. |
07-08-2011, 07:48 | #171 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 785041 Status: Offline Thanks Meter: 27 | N96-1 RM-247 alived by UB THX UB Team MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... 1. Make sure USB cable, Battery and charger are removed from device. Waiting for USB device... Waiting for USB device... 3. Insert Battery to device 4. Insert Charger to device Loading secondary boot code: 39104 bytes Secondary boot loaded BB Asic Index is: 01 Asic ID is: 008815D3 BB Asic Index is: 01 EM Asic ID is: 000001B2 BB Asic Index is: 01 EM Asic ID is: 000001B3 BB Asic Index is: 01 Public ID is: 2FE28E22835A3CA329C4F5367D2B144B6B461435 BB Asic Index is: 01 Asic Mode ID: 00 BB Asic Index is: 01 Hash: 0BBC4203E2D3B82504C75CB65E906A35 BB Asic Index is: 01 ROM ID: 137A9A3B33259D2C BB Asic Index is: 01 Device type is: 05 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 01 Device type is: 04 Device Index is: 00 Manufacturer code: FFFF Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 01 Device type is: 03 Device Index is: 00 Manufacturer code: 0020 Device ID: 00B1 Extended device ID: 0000 Revision ID: 0000 Loading update server code: 377373 bytes Update server loaded Loading slave secondary boot code: 15232 bytes Slave secondary boot code loaded BB Asic Index is: 00 Asic ID is: 000000010000022600010006400C192101031103 BB Asic Index is: 00 EM Asic ID is: 00000295 BB Asic Index is: 00 EM Asic ID is: 00000B22 BB Asic Index is: 00 Public ID is: 0C50000651710052EA2D8D145A274C22ED292F5B BB Asic Index is: 00 Asic Mode ID: 00 BB Asic Index is: 00 Hash: CAEEBB65D3C48E6DC73B49DC5063A2EE BB Asic Index is: 00 ROM ID: 4B9B75103E691FF8 BB Asic Index is: 00 Device type is: 05 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 04 Device Index is: 00 Manufacturer code: FFFF Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 00 Manufacturer code: 0001 Device ID: 2C7E Extended device ID: 0000 Revision ID: 6921 BB Asic Index is: 00 Device type is: 00 Device Index is: 01 Manufacturer code: 0000 Device ID: 0001 Extended device ID: 0000 Revision ID: 0000 Loading slave update server code: 555471 bytes Slave update server loaded Asic CMT: Start programming 5968 KB... Asic APE: Start programming 129427 KB... Programming complete Asic CMT: Verifying communication to device... Waiting for phone to reconnect Waiting for phone to reconnect Loading default data to phone Getting Data Package Reading product state Backup sub-procedure started: mode change post delay Backup data item started: ProductProfile, version: 1.1 Backup sub-procedure started: data item post-delay Backup sub-procedure started: Mode change Backup/restore result: 0 out of 1 items were not backed up -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.3.2824 finished at: 2011/07/08 09:32:33 Done. -------------------------------------------------------------------------------- TUniversalForm 2.9.3.2824 finished at: 2011/07/08 09:46:50 |
07-25-2011, 08:41 | #173 (permalink) |
Member: 1050365 Status: Offline Thanks Meter: 210 | Nokia X-3 flashed TBB5USBFlashThread 2.9.3.2824 with filepack 7.81 started at: 2011/07/25 11:52:54 -------------------------------------------------------------------------------- MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device 4. Insert Charger to device Loading secondary boot code: 15040 bytes Secondary boot loaded BB Asic Index is: 00 Asic ID is: 000000010000022600000001020C192102054100 BB Asic Index is: 00 EM Asic ID is: 00001040 BB Asic Index is: 00 EM Asic ID is: 00001030 BB Asic Index is: 00 Public ID is: 20600113AA3E00496CAE45ED9ED0D169F5BD3FCA BB Asic Index is: 00 Asic Mode ID: 00 BB Asic Index is: 00 Hash: 7B045400E1752022F9EB80B0DEA9C65D BB Asic Index is: 00 ROM ID: 67E82268F29CEA60 BB Asic Index is: 00 Device type is: 05 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 04 Device Index is: 00 Manufacturer code: FFFF Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 01 Manufacturer code: 0000 Device ID: 0001 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 03 Device Index is: 00 Manufacturer code: 00EC Device ID: 0030 Extended device ID: 0000 Revision ID: 0321 Loading update server code: 597010 bytes Update server loaded Asic CMT: Start programming 50210 KB... Programming complete Asic CMT: Verifying communication to device... Loading default data to phone Getting Data Package Reading product state Backup sub-procedure started: data item pre-delay Backup data item started: ProductProfile, version: 1.1 Backup sub-procedure started: data item post-delay Backup sub-procedure started: data item pre-delay Backup data item started: ISSVariantActivator, version: 1.0 Backup sub-procedure started: data item post-delay Backup sub-procedure started: data item pre-delay Backup data item started: DateTimeSettings, version: 1.0 Backup sub-procedure started: data item post-delay Backup/restore result: 0 out of 3 items were not backed up -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.3.2824 finished at: 2011/07/25 11:55:16 |
07-30-2011, 19:08 | #176 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,709 | n900 blank imei repaired by usb flashing by uni box hi to all here is the log of successfull flashing for N900: Code: TBB5USBFlashThread 2.9.4.2851 with filepack 7.82 started at: 2011/07/30 18:35:12 -------------------------------------------------------------------------------- MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device Waiting for USB device... Sending programming image... done. Sending secondary (109440 bytes)... done. Cold flashing successful, doing warm flash. Device requires reset. Device reset. Sending xloader image (14 kB)... Sending secondary image (106 kB)... Flashing bootloader... done. Sending cmt-2nd image (79 kB)... Sending cmt-algo image (507 kB)... Sending cmt-mcusw image (5826 kB)... Flashing cmt-mcusw... done. Sending kernel image (1705 kB)... Flashing kernel... done. Sending and flashing rootfs image (185856 kB)... Finishing flashing... done Erasing CMT (7360 kB)... Programming CMT (5826 kB)... CMT flashed successfully MCUSW file (h:\program files\sarassoft\ufs\ufs_dctxbb5\products\RX-51\RX-51_2009SE_20.2010.36-2.003_PR_COMBINED_003_ARM.bin) flashed successfully Device requires reset. Device reset. Waiting for phone to come online max 120 seconds... Loading default data to phone Getting Data Package Reading product state Backup sub-procedure started: mode change post delay Backup data item started: EmergencyNumbers, version: 1.0 Backup/restore result: 1 out of 1 items were not backed up -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.4.2851 finished at: 2011/07/30 18:38:40 Done. -------------------------------------------------------------------------------- TUniversalForm 2.9.4.2851 finished at: 2011/07/30 18:41:27 |
08-04-2011, 13:21 | #177 (permalink) | |
Freak Poster Join Date: Feb 2011
Member: 1508914 Status: Offline Thanks Meter: 21 | N8 Successfully unlocked: Quote:
08-05-2011, 12:06 | #178 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Great India
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 760 | nokia E5 usb flashing done MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device Waiting for USB device... Loading secondary boot code: 15168 bytes Secondary boot loaded BB Asic Index is: 00 Asic ID is: 000000030000022600010007600C192102031104 BB Asic Index is: 00 EM Asic ID is: 00000C35 BB Asic Index is: 00 EM Asic ID is: 00000C30 BB Asic Index is: 00 Public ID is: 27F0001190E35840C25FB30EC5F2BA589D1A5B51 BB Asic Index is: 00 Asic Mode ID: 00 BB Asic Index is: 00 Hash: 916F75217F32081248B15C38DFC8E81B BB Asic Index is: 00 ROM ID: E693EF0DAC22615B BB Asic Index is: 00 Device type is: 05 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 04 Device Index is: 00 Manufacturer code: FFFF Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 00 Manufacturer code: 0020 Device ID: 0050 Extended device ID: 0000 Revision ID: 0031 BB Asic Index is: 00 Device type is: 00 Device Index is: 01 Manufacturer code: 0000 Device ID: 0001 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 03 Device Index is: 00 Manufacturer code: 0020 Device ID: 0050 Extended device ID: 0000 Revision ID: 0031 Loading update server code: 812904 bytes Update server loaded Asic CMT: Start programming 191082 KB... Programming complete Asic CMT: Verifying communication to device... Loading default data to phone Getting Data Package Reading product state Backup sub-procedure started: data item pre-delay Backup data item started: ProductProfile, version: 1.1 Backup sub-procedure started: data item post-delay Backup/restore result: 0 out of 1 items were not backed up -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.5.2861 finished at: 2011/08/05 13:02:17 Done. |
08-05-2011, 12:14 | #179 (permalink) |
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 760 | nokia E71 successfully done dead usb flashing MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device Waiting for USB device... Loading secondary boot code: 14592 bytes Secondary boot loaded Loading update server code: 2080457 bytes Update server loaded Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Error sending ADL_LDR_GET_MS_INFO_REQ Error parsing MS info data. Attempting to continue flashing Flashing SingleAsic device... Asic CMT: Start programming 108972 KB... Asic CMT: Erasing rm346_510.21.009_prd.c00 Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Partitioning rm346_510.21.009_prd.c00 Asic CMT: Partitioning area 1... Asic CMT: Erasing rm346_510.21.009_prd.v28 Asic CMT: Erasing area 1... Asic CMT: Erasing rm346_510.21.009.08U Asic CMT: Erasing RM346_ENO_0741.10_08wk42.a36.fpsx Asic CMT: Erasing leevi_erase_y_drive.fpsx Asic CMT: Erasing area 1... Asic CMT: Programming rm346_510.21.009_prd.c00 Asic CMT: Programming rm346_510.21.009_prd.v28 Asic CMT: Programming rm346_510.21.009.08U Asic CMT: Programming RM346_ENO_0741.10_08wk42.a36.fpsx Finished Flashing Rebooting to RFS Mode Asic CMT: Verifying communication to device... Loading default data to phone Getting Data Package Reading product state Backup sub-procedure started: data item pre-delay Backup data item started: ProductProfile, version: 1.0 Backup sub-procedure started: data item post-delay Backup/restore result: 0 out of 1 items were not backed up -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.5.2861 finished at: 2011/08/05 11:35:55 Done. |
08-05-2011, 12:24 | #180 (permalink) |
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 760 | nokia E72 dead usb successfully flashing done MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device Scanning image files... Waiting for USB device... Loading secondary boot code: 15168 bytes Secondary boot loaded BB Asic Index is: 00 Asic ID is: 000000030000022600010007600C192102011104 BB Asic Index is: 00 EM Asic ID is: 00001040 BB Asic Index is: 00 EM Asic ID is: 00001030 BB Asic Index is: 00 Public ID is: 03D0011928D90344F5B26F717FE856E1036EF997 BB Asic Index is: 00 Asic Mode ID: 00 BB Asic Index is: 00 Hash: 25B977A055BE9B5DEC0C38A2A279C695 BB Asic Index is: 00 ROM ID: 3E273BF637BE26FA BB Asic Index is: 00 Device type is: 05 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 04 Device Index is: 00 Manufacturer code: FFFF Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 01 Manufacturer code: 0000 Device ID: 0001 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 03 Device Index is: 00 Manufacturer code: 00EC Device ID: 0058 Extended device ID: 0000 Revision ID: 0121 Loading update server code: 812904 bytes Update server loaded Asic CMT: Start programming 188083 KB... Programming complete Asic CMT: Verifying communication to device... Loading default data to phone Getting Data Package Reading product state Backup sub-procedure started: data item pre-delay Backup data item started: ProductProfile, version: 1.1 Backup sub-procedure started: data item post-delay Backup/restore result: 0 out of 1 items were not backed up -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.5.2861 finished at: 2011/08/05 14:20:33 Done. |
