Universalbox Universalbox Official support area |
07-21-2008, 21:14 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: IRELAND
Member: 87357 Status: Offline Thanks Meter: 9,457 | Successful Unlocked Via Tp With UB Just Post Here Model,Version,Screen shot & Log File Regards F@iSaL Last edited by MobilesDoctor; 08-01-2008 at 16:14. |
The Following User Says Thank You to MobilesDoctor For This Useful Post: |
07-23-2008, 04:58 | #2 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Philippines
Member: 257511 Status: Offline Thanks Meter: 69 | Successful Unlocked Via Tp With UB 3110C TBB5TPUnlockThread started at: 2008/07/22 21:47:59 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.056, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3.97V is in range of: 4.00V ±10.0% Auto power-on mode set. Please turn on phone! Phone powered Initializing phone... Output power at Line1 3.97V is in range of: 4.00V ±10.0% Initializing phone... Output power at Line1 3.97V is in range of: 4.00V ±10.0% Phone powered. Reading Info... MCU Version: V 04.91 Date: 03-04-07 Type: RM-237 (Unknown) Additional_1: (c) Nokia. PPM Version: V 04.91 Date: 03-04-07 Type: RM-237 (Unknown) Pack: (c) Nokia. Product code: 0551904 Original IMEI: ****************** Production serial: 7F0699639 HW Version: 2000 DSP Version: pb06w14v44 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] Profile bits: 0000000000000000 Simlock config: 5150200000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 51502F Block: 2; Lock: 1; State: Closed; Data: 51502F Saving PM field... Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Restoring lock info... Reading Info... MCU Version: V 04.91 Date: 03-04-07 Type: RM-237 (Unknown) Additional_1: (c) Nokia. PPM Version: V 04.91 Date: 03-04-07 Type: RM-237 (Unknown) Pack: (c) Nokia. Product code: 0551904 Original IMEI: ****************** Production serial: 7F0699639 HW Version: 2000 DSP Version: pb06w14v44 LCD Version: APE ADSP Version: -------------------------------------------------------------------------------- TBB5TPUnlockThread finished at: 2008/07/22 21:52:30 TBB5TPUnlockThread started at: 2008/07/22 21:54:07 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.056, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3.97V is in range of: 4.00V ±10.0% Auto power-on mode set. Please turn on phone! Phone powered Reading Info... MCU Version: V 04.91 Date: 03-04-07 Type: RM-237 (Unknown) Additional_1: (c) Nokia. PPM Version: V 04.91 Date: 03-04-07 Type: RM-237 (Unknown) Pack: (c) Nokia. Product code: 0551904 Original IMEI: ****************** Production serial: 7F0699639 HW Version: 2000 DSP Version: pb06w14v44 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] Profile bits: 0000000000000000 Simlock config: 5150200000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 51502F Block: 2; Lock: 1; State: Closed; Data: 51502F Backup already saved Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock done Reading Info... MCU Version: V 04.91 Date: 03-04-07 Type: RM-237 (Unknown) Additional_1: (c) Nokia. PPM Version: V 04.91 Date: 03-04-07 Type: RM-237 (Unknown) Pack: (c) Nokia. Product code: 0551904 Original IMEI: ****************** Production serial: 7F0699639 HW Version: 2000 DSP Version: pb06w14v44 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] -------------------------------------------------------------------------------- TBB5TPUnlockThread finished at: 2008/07/22 21:54:43 Done. TBB5ReadInfoThread started at: 2008/07/22 21:55:10 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Reading Info... MCU Version: V 04.91 Date: 03-04-07 Type: RM-237 (Unknown) Additional_1: (c) Nokia. PPM Version: V 04.91 Date: 03-04-07 Type: RM-237 (Unknown) Pack: (c) Nokia. Product code: 0551904 Original IMEI: ****************** Production serial: 7F0699639 HW Version: 2000 DSP Version: pb06w14v44 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] Profile bits: 0000000000000000 Simlock config: 5150200000000000 Invalid codes entered: 0 / 0 All locks are open. -------------------------------------------------------------------------------- TBB5ReadInfoThread finished at: 2008/07/22 21:55:13 Last edited by universalbox; 07-23-2008 at 20:06. |
The Following 16 Users Say Thank You to Brod Aries For This Useful Post: |
07-23-2008, 15:36 | #3 (permalink) |
Member: 257511 Status: Offline Thanks Meter: 69 | N71 again tested... TBB5TPUnlockThread started at: 2008/07/23 03:59:59 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.056, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3.97V is in range of: 4.00V ±10.0% Auto power-on mode set. Please turn on phone! Phone powered Reading Info... MCU Version: V 05wk33v23.5 Date: 04-04-06 Type: RM-67 (N71) Additional_1: (c) Nokia. PPM Version: V 05wk33v23.5 Date: 04-04-06 Type: RM-67 (N71) Pack: (c) Nokia. Product code: 0526660 Original IMEI: ****************** Production serial: CHE973391 HW Version: 9330 DSP Version: isetta05wk32v26 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 62 [040A0105071B] Profile bits: 0000000000000000 Simlock config: 4402000000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 44020F Block: 1; Lock: 2; State: Closed; Data: FFFFF00FFFFFFFFF Block: 1; Lock: 3; State: Closed; Data: FFFFF49FFFFFFFFF Block: 2; Lock: 1; State: Closed; Data: 44020F Block: 2; Lock: 2; State: Closed; Data: FFFFF00FFFFFFFFF Block: 2; Lock: 3; State: Closed; Data: FFFFF49FFFFFFFFF Backup already saved Connect TP cables and press button! Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [0C] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [0C] Restoring lock info... Reading Info... MCU Version: V 05wk33v23.5 Date: 04-04-06 Type: RM-67 (N71) Additional_1: (c) Nokia. PPM Version: V 05wk33v23.5 Date: 04-04-06 Type: RM-67 (N71) Pack: (c) Nokia. Product code: 0526660 Original IMEI: ****************** Production serial: CHE973391 HW Version: 9330 DSP Version: isetta05wk32v26 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER VERSION 62 [040A0105071B] Profile bits: 0000000000000000 Simlock config: 4402000000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 44020F Block: 1; Lock: 2; State: Closed; Data: FFFFF00FFFFFFFFF Block: 1; Lock: 3; State: Closed; Data: FFFFF49FFFFFFFFF Block: 2; Lock: 1; State: Closed; Data: 44020F Block: 2; Lock: 2; State: Closed; Data: FFFFF00FFFFFFFFF Block: 2; Lock: 3; State: Closed; Data: FFFFF49FFFFFFFFF Connect TP cables and press button! Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [0C] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [0C] Restoring lock info... Reading Info... MCU Version: V 05wk33v23.5 Date: 04-04-06 Type: RM-67 (N71) Additional_1: (c) Nokia. PPM Version: V 05wk33v23.5 Date: 04-04-06 Type: RM-67 (N71) Pack: (c) Nokia. Product code: 0526660 Original IMEI: ****************** Production serial: CHE973391 HW Version: 9330 DSP Version: isetta05wk32v26 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER VERSION 62 [040A0105071B] Profile bits: 0000000000000000 Simlock config: 4402000000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 44020F Block: 1; Lock: 2; State: Closed; Data: FFFFF00FFFFFFFFF Block: 1; Lock: 3; State: Closed; Data: FFFFF49FFFFFFFFF Block: 2; Lock: 1; State: Closed; Data: 44020F Block: 2; Lock: 2; State: Closed; Data: FFFFF00FFFFFFFFF Block: 2; Lock: 3; State: Closed; Data: FFFFF49FFFFFFFFF Connect TP cables and press button! Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [0C] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [08] Unlock try failed [0C] Restoring lock info... Reading Info... MCU Version: V 05wk33v23.5 Date: 04-04-06 Type: RM-67 (N71) Additional_1: (c) Nokia. PPM Version: V 05wk33v23.5 Date: 04-04-06 Type: RM-67 (N71) Pack: (c) Nokia. Product code: 0526660 Original IMEI: ****************** Production serial: CHE973391 HW Version: 9330 DSP Version: isetta05wk32v26 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER VERSION 62 [040A0105071B] Profile bits: 0000000000000000 Simlock config: 4402000000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 44020F Block: 1; Lock: 2; State: Closed; Data: FFFFF00FFFFFFFFF Block: 1; Lock: 3; State: Closed; Data: FFFFF49FFFFFFFFF Block: 2; Lock: 1; State: Closed; Data: 44020F Block: 2; Lock: 2; State: Closed; Data: FFFFF00FFFFFFFFF Block: 2; Lock: 3; State: Closed; Data: FFFFF49FFFFFFFFF Connect TP cables and press button! Unlock done Reading Info... MCU Version: V 05wk33v23.5 Date: 04-04-06 Type: RM-67 (N71) Additional_1: (c) Nokia. PPM Version: V 05wk33v23.5 Date: 04-04-06 Type: RM-67 (N71) Pack: (c) Nokia. Product code: 0526660 Original IMEI: ****************** Production serial: CHE973391 HW Version: 9330 DSP Version: isetta05wk32v26 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER VERSION 62 [040A0105071B] Profile bits: 0000000000000000 Simlock config: 4402000000000000 Invalid codes entered: 0 / 0 All locks are open. -------------------------------------------------------------------------------- TBB5TPUnlockThread finished at: 2008/07/23 04:02:34 Done. |
The Following 3 Users Say Thank You to Brod Aries For This Useful Post: |
07-24-2008, 13:22 | #4 (permalink) |
No Life Poster Join Date: Jan 2004 Location: United States
Member: 51453 Status: Offline Thanks Meter: 729 | 5200 unlock by UB for refference Just tested 5200 unlock by Universal box in just couple of mins.. info unlock br |
The Following 11 Users Say Thank You to shawgsm For This Useful Post: |
08-07-2008, 17:05 | #6 (permalink) |
Insane Poster Join Date: Jan 2006
Member: 227293 Status: Offline Thanks Meter: 1 | what is wrong ? can't unlock MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.058, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3.95V is in range of: 4.00V ?0.0% Auto power-on mode set. Please turn on phone! Phone powered Reading Info... MCU Version: V 05.50 Date: 14-08-07 Type: RM-217 (Unknown) Additional_1: (c) Nokia. PPM Version: V 05.50 Date: 14-08-07 Type: RM-217 (Unknown) Pack: (c) Nokia. Product code: 0546425 Original IMEI: ****************** Production serial: DQA252538 HW Version: 1000 DSP Version: 06w14pb_07w32 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] Profile bits: FFFFFFFFFFFFFFFF Simlock config: FFFFFFFFFFFFFFFF Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 00101F Backup already saved Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Unlock try failed [07] Connect TP cables! Aborting process... -------------------------------------------------------------------------------- |
08-07-2008, 17:18 | #7 (permalink) | |
Insane Poster Join Date: Aug 2007 Location: WORLDWIDE
Member: 564518 Status: Offline Thanks Meter: 24 | Quote:
this phone need rpl before unlock | |
08-08-2008, 15:44 | #8 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: Argentina Age: 69
Member: 91019 Status: Offline Thanks Meter: 62 | Nokia 6131 v06.10 rm-115 Sucessfully unlock with ub tp Quote:
08-17-2008, 05:17 | #9 (permalink) |
Member: 94224 Status: Offline Thanks Meter: 27 | n73 unlocked my n73 successfully unlocked MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Authenticating software... Device opened at USB->Universal Box [UBEDFX0Z] TBB5TPUnlockThread started at: 2008/08/17 09:28:48 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.058, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3.93V is in range of: 4.00V ±10.0% Auto power-on mode set. Please turn on phone! Phone powered Reading Info... MCU Version: V 05wk47v38.1 Date: 19-01-07 Type: RM-133 (N73) Additional_1: (c) Nokia. PPM Version: V 05wk47v38.1 Date: 19-01-07 Type: RM-133 (N73) Pack: (c) Nokia. Product code: 0546349 Original IMEI: ****************** Production serial: SAN203816 HW Version: 6020 DSP Version: scarfe_05wk46v41 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: 0000000000000000 Simlock config: 2343300000000000 Invalid codes entered: 3 / 0 Block: 1; Lock: 1; State: Closed; Data: 23433F Block: 2; Lock: 1; State: Closed; Data: 23486F Block: 3; Lock: 1; State: Closed; Data: 23433F Block: 4; Lock: 1; State: Closed; Data: 23486F Backup already saved Connect TP cables! Unlock try failed [0C] Connect TP cables! Unlock try failed [FF] -------------------------------------------------------------------------------- TBB5TPUnlockThread finished at: 2008/08/17 09:29:22 Terminated with error: 00010071.00019290.0000040D.00000101.0000020C.00010 091 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBEDFX0Z] TBB5TPUnlockThread started at: 2008/08/17 09:29:56 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.058, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3.93V is in range of: 4.00V ±10.0% Auto power-on mode set. Please turn on phone! Phone powered Reading Info... MCU Version: V 05wk47v38.1 Date: 19-01-07 Type: RM-133 (N73) Additional_1: (c) Nokia. PPM Version: V 05wk47v38.1 Date: 19-01-07 Type: RM-133 (N73) Pack: (c) Nokia. Product code: 0546349 Original IMEI: ****************** Production serial: SAN203816 HW Version: 6020 DSP Version: scarfe_05wk46v41 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: 0000000000000000 Simlock config: 2343300000000000 Invalid codes entered: 3 / 0 Block: 1; Lock: 1; State: Closed; Data: 23433F Block: 2; Lock: 1; State: Closed; Data: 23486F Block: 3; Lock: 1; State: Closed; Data: 23433F Block: 4; Lock: 1; State: Closed; Data: 23486F Backup already saved Connect TP cables! Unlock try failed [0C] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Restoring lock info... Reading Info... MCU Version: V 05wk47v38.1 Date: 19-01-07 Type: RM-133 (N73) Additional_1: (c) Nokia. PPM Version: V 05wk47v38.1 Date: 19-01-07 Type: RM-133 (N73) Pack: (c) Nokia. Product code: 0546349 Original IMEI: ****************** Production serial: SAN203816 HW Version: 6020 DSP Version: scarfe_05wk46v41 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: 0000000000000000 Simlock config: 2343300000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 23433F Block: 2; Lock: 1; State: Closed; Data: 23486F Block: 3; Lock: 1; State: Closed; Data: 23433F Block: 4; Lock: 1; State: Closed; Data: 23486F Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Restoring lock info... Reading Info... MCU Version: V 05wk47v38.1 Date: 19-01-07 Type: RM-133 (N73) Additional_1: (c) Nokia. PPM Version: V 05wk47v38.1 Date: 19-01-07 Type: RM-133 (N73) Pack: (c) Nokia. Product code: 0546349 Original IMEI: ****************** Production serial: SAN203816 HW Version: 6020 DSP Version: scarfe_05wk46v41 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: 0000000000000000 Simlock config: 2343300000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 23433F Block: 2; Lock: 1; State: Closed; Data: 23486F Block: 3; Lock: 1; State: Closed; Data: 23433F Block: 4; Lock: 1; State: Closed; Data: 23486F Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Restoring lock info... Reading Info... MCU Version: V 05wk47v38.1 Date: 19-01-07 Type: RM-133 (N73) Additional_1: (c) Nokia. PPM Version: V 05wk47v38.1 Date: 19-01-07 Type: RM-133 (N73) Pack: (c) Nokia. Product code: 0546349 Original IMEI: ****************** Production serial: SAN203816 HW Version: 6020 DSP Version: scarfe_05wk46v41 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: 0000000000000000 Simlock config: 2343300000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 23433F Block: 2; Lock: 1; State: Closed; Data: 23486F Block: 3; Lock: 1; State: Closed; Data: 23433F Block: 4; Lock: 1; State: Closed; Data: 23486F Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [0C] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock done Reading Info... MCU Version: V 05wk47v38.1 Date: 19-01-07 Type: RM-133 (N73) Additional_1: (c) Nokia. PPM Version: V 05wk47v38.1 Date: 19-01-07 Type: RM-133 (N73) Pack: (c) Nokia. Product code: 0546349 Original IMEI: ****************** Production serial: SAN203816 HW Version: 6020 DSP Version: scarfe_05wk46v41 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: 0000000000000000 Simlock config: 2343300000000000 Invalid codes entered: 0 / 0 All locks are open. -------------------------------------------------------------------------------- TBB5TPUnlockThread finished at: 2008/08/17 09:32:43 Done. thanks to universalbox best regards |
08-18-2008, 07:43 | #11 (permalink) |
Junior Member Join Date: Aug 2008 Location: www.GsmDiscovery.com Age: 48
Member: 837780 Status: Offline Sonork: 100.107029 Thanks Meter: 1 | hi friend all ok you need -adapter+ tp bb5 for UB -activation funtion bb5 (300 logg,only a one-time) then the process is the same with any tool support through TP B,R; EMIGSM |
08-19-2008, 13:46 | #12 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | Succes unlock 6300 see the log TBB5TPUnlockThread started at: 2008/08/19 18:51:39 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.056, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3.97V is in range of: 4.00V ±10.0% Auto power-on mode set. Please turn on phone! Phone powered Reading Info... MCU Version: V 05.00 Date: 27-04-07 Type: RM-217 (Unknown) Additional_1: (c) Nokia. PPM Version: V 05.00 Date: 27-04-07 Type: RM-217 (Unknown) Pack: (c) Nokia. Product code: 0547991 Original IMEI: ****************** Production serial: DJI865003 HW Version: 1007 DSP Version: pb06w14v51 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] Profile bits: 0000000000000000 Simlock config: 5050200000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 50502F Block: 2; Lock: 1; State: Closed; Data: 50502F Saving PM field... -------------------------------------------------------------------------------- TBB5TPUnlockThread finished at: 2008/08/19 18:52:35 Done. TBB5TPUnlockThread started at: 2008/08/19 18:53:15 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.056, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3.97V is in range of: 4.00V ±10.0% Auto power-on mode set. Reading Info... MCU Version: V 05.00 Date: 27-04-07 Type: RM-217 (Unknown) Additional_1: (c) Nokia. PPM Version: V 05.00 Date: 27-04-07 Type: RM-217 (Unknown) Pack: (c) Nokia. Product code: 0547991 Original IMEI: ****************** Production serial: DJI865003 HW Version: 1007 DSP Version: pb06w14v51 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] Profile bits: 0000000000000000 Simlock config: 5050200000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 50502F Block: 2; Lock: 1; State: Closed; Data: 50502F Backup already saved Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock done Reading Info... MCU Version: V 05.00 Date: 27-04-07 Type: RM-217 (Unknown) Additional_1: (c) Nokia. PPM Version: V 05.00 Date: 27-04-07 Type: RM-217 (Unknown) Pack: (c) Nokia. Product code: 0547991 Original IMEI: ****************** Production serial: DJI865003 HW Version: 1007 DSP Version: pb06w14v51 LCD Version: APE ADSP Version: -------------------------------------------------------------------------------- TBB5TPUnlockThread finished at: 2008/08/19 18:54:34 Done. TBB5ReadInfoThread started at: 2008/08/19 18:54:54 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Reading Info... MCU Version: V 05.00 Date: 27-04-07 Type: RM-217 (Unknown) Additional_1: (c) Nokia. PPM Version: V 05.00 Date: 27-04-07 Type: RM-217 (Unknown) Pack: (c) Nokia. Product code: 0547991 Original IMEI: ****************** Production serial: DJI865003 HW Version: 1007 DSP Version: pb06w14v51 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A08060118] Profile bits: 0000000000000000 Simlock config: 5050200000000000 Invalid codes entered: 0 / 0 All locks are open. -------------------------------------------------------------------------------- TBB5ReadInfoThread finished at: 2008/08/19 18:54:57 THANK'S UB TEAM FOR EASY TESTPOINT, hove in future UB can unlock all BB5 ... sorry bad english WBR notgood |
08-24-2008, 15:37 | #13 (permalink) |
No Life Poster Join Date: Apr 2006 Location: IRAN
Member: 258290 Status: Offline Thanks Meter: 383 | N73 unlocked Hi n73 unlock log MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.058, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3.99V is in range of: 4.00V ±10.0% Auto power-on mode set. Please turn on phone! Phone powered Reading Info... MCU Version: V 05wk47v51.5 Date: 29-08-07 Type: RM-133 (N73) Additional_1: (c) Nokia. PPM Version: V 05wk47v51.5 Date: 29-08-07 Type: RM-133 (N73) Pack: (c) Nokia. Product code: Original IMEI: ****************** Production serial: HW Version: DSP Version: scarfe_05wk46v50 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: 0000000000000000 Simlock config: 2343000000000000 Invalid codes entered: 3 / 6 Block: 1; Lock: 1; State: Closed; Data: 23430F Block: 2; Lock: 1; State: Closed; Data: 23430F Backup already saved Connect TP cables! Unlock try failed [0C] Connect TP cables! Unlock done Reading Info... MCU Version: V 05wk47v51.5 Date: 29-08-07 Type: RM-133 (N73) Additional_1: (c) Nokia. PPM Version: V 05wk47v51.5 Date: 29-08-07 Type: RM-133 (N73) Pack: (c) Nokia. Product code: Original IMEI: ****************** Production serial: HW Version: DSP Version: scarfe_05wk46v50 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] log after unlock: MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. MCU BB5TP Version: 1.058, and up to date. SMCU BB5TP Version: 1.14, and up to date. Output power at Line1 3.97V is in range of: 4.00V ±10.0% Auto power-on mode set. Please turn on phone! Phone powered Reading Info... MCU Version: V 05wk47v51.5 Date: 29-08-07 Type: RM-133 (N73) Additional_1: (c) Nokia. PPM Version: V 05wk47v51.5 Date: 29-08-07 Type: RM-133 (N73) Pack: (c) Nokia. Product code: Original IMEI: ****************** Production serial: HW Version: DSP Version: scarfe_05wk46v50 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: 0000000000000000 Simlock config: 2343000000000000 Invalid codes entered: 0 / 0 All locks are open. No locks are closed, no need to unlock BR Pars-GSM |
The Following 3 Users Say Thank You to BANDAD-HAMID For This Useful Post: |
08-25-2008, 13:23 | #14 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Devon, England
Member: 55766 Status: Offline Thanks Meter: 333 | 6280 Reading Info... MCU Version: V 06.43 Date: 30-03-07 Type: RM-78 (6280) Additional_1: (c) Nokia PPM Version: V 06.43 Date: 30-03-07 Type: RM-78 (6280) Pack: (c) Nokia Product code: 0530052 Original IMEI: ****************** Production serial: SDF701377 HW Version: 1002 DSP Version: pb05w46v49 LCD Version: SEIKO APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: 8000000000000006 Simlock config: 2342000000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 23420F Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock try failed [08] Connect TP cables! Unlock done Reading Info... MCU Version: V 06.43 Date: 30-03-07 Type: RM-78 (6280) Additional_1: (c) Nokia PPM Version: V 06.43 Date: 30-03-07 Type: RM-78 (6280) Pack: (c) Nokia Product code: 0530052 Original IMEI: ****************** Production serial: SDF701377 HW Version: 1002 DSP Version: pb05w46v49 LCD Version: SEIKO APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] -------------------------------------------------------------------------------- TBB5TPUnlockThread finished at: 2008/08/16 20:42:51 Terminated with error: 00010071.00011870.00011839.0000040D.00000101.00000 20C.00010091 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBCC3540] TBB5ReadInfoThread started at: 2008/08/16 20:43:12 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Initializing phone... Output power at Line1 3.90V is in range of: 4.00V ±10.0% Reading Info... MCU Version: V 06.43 Date: 30-03-07 Type: RM-78 (6280) Additional_1: (c) Nokia PPM Version: V 06.43 Date: 30-03-07 Type: RM-78 (6280) Pack: (c) Nokia Product code: 0530052 Original IMEI: ****************** Production serial: SDF701377 HW Version: 1002 DSP Version: pb05w46v49 LCD Version: SEIKO APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: 8000000000000006 Simlock config: 2342000000000000 Invalid codes entered: 0 / 0 All locks are open. -------------------------------------------------------------------------------- |
Successful Unlocked Via Tp... | delax2006 | Universalbox | 20 | 08-09-2008 15:24 |
V3t T-Mobile bootload A.52 unlocked via tp with smartmoto 3.12 | alfox | Smart-Clip | 8 | 04-04-2008 03:28 |
v3r at&t unlocked via TP with smartmoto[reference] | alfox | Smart-Clip | 0 | 02-15-2008 09:24 |
