Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Universalbox
Universalbox Universalbox Official support area
Old 02-26-2007, 07:55   #1 (permalink)
Member: 258741
Terminated with error:No available bootloader
Terminated with error:No available bootloader for this ID [0001105A].00011162.00011176.000115E0
Help me, why this
Old 02-26-2007, 08:45   #2 (permalink)
alex12345's Avatar
Member: 152573
Thanks Meter: 58
Help me, why this
hi, can u post the full log and wat phone u trying to flash ??
Regards
alex
Old 12-29-2008, 08:40   #3 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Thanks Meter: 21,659
Please try to use usb,
Old 12-29-2008, 08:46   #4 (permalink)
Member: 199814
Thanks Meter: 1,960
Some times there is issue in data cable faced in N70 while flashing...
Old 12-29-2008, 09:44   #5 (permalink)
honyjee's Avatar
Member: 506989
Sonork: 100.1585406
Thanks Meter: 81
i also facing same prob leam
Old 01-08-2009, 12:48   #6 (permalink)
Member: 132858
Same problem here trying to read certs on E51 and 5220 xm, cables ok. Please fix this bug as soon as possible.
Old 01-08-2009, 15:41   #7 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
thanks for reporting feed back, we'll fix asap, Please try to use USB Cable for Flashing
Old 01-09-2009, 18:21   #8 (permalink)
Member: 132858
6210n with same error, i´m very tired of this box , i´m loosing a lot of money waiting results and nothing, s60 stopped, sl2 stopped, not reading certs..... what else???????????????????????
Old 01-09-2009, 19:06   #9 (permalink)
amralkareem's Avatar
Member: 153397
Sonork: 113032
Thanks Meter: 372
Old 01-10-2009, 13:00   #10 (permalink)
Member: 128018
Thanks Meter: 17
i also facing same prob leam ..........................:con fused:
Old 01-11-2009, 00:22   #11 (permalink)
Member: 197538
Thanks Meter: 97
ub team
PLEASE LISTEN TO OUR COMPLAINS AND RECIPROCATE ATLEAST GIVE US SOME FEEDBACK REGARDING THIS READ CERTIFICATE ISSUE OF 5220 .. IT IS DEFINITELY NOT A CABLE PROBLEM ... WORKS FINE WITH JAF HWK AND SHOULD WORK WITH UB AS WELL ... TEST MODE OK LOCAL MODE OK READ PM OK .. FACTORY SETTINGS OK ... ONLY PROBLEM IS READ CERT UKNOWN ID
AND SINCE THIS IS A COMPLAIN OF MANY PEOPLE WE EXPECT YOU TO ATLEAST ANSWER US AS TO WHAT IS HAPPENING RE THIS BUG ...
THANKS
MIKE
NB: HOW DO U SAVE LOGS IN UB AS I WOULD LIKE TO PASTE HERE THE LOGS .. AS THERE IS NO COPY POSSIBLE NOR IS THERE A FOLDER WHERE LOGS ARE SAVED LIKE IN SMART CLIP YOU HAVE OPTION THAT ASKS YOU SAVE LOG ?
Old 01-11-2009, 03:08   #12 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
about ur question on logs just goto ur drive c:/uni folder and look for the log file and there you will find all process logs and copy paste it here
Old 01-11-2009, 08:10   #13 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
@mike67 already answered in your own thread, please don't try to make again and again new posts about that!!!
Old 01-11-2009, 10:38   #14 (permalink)
Member: 132858
Do you want to see my logs?? All phones that ended on terminate with error no available bootloader??
thanks for answering
Old 01-12-2009, 10:41   #15 (permalink)
Member: 132858
This is my last logs, updated version OK, cable OK, read certs KO!
MCU Nokia Version: 1.126, and up to date.
SMCU Nokia Version: 1.42, and up to date.
Reading Info...
Soft Version: V 08w17.07 Date: 10-06-08 Type: RM-367 (6210S-1 NAVIGATOR) Pack: (c) Nokia
Product code: 0569996
Original IMEI: ******************
Production serial: CIO253739
HW Version: 0701
DSP Version: MPD_pb71_08w21.01_rm367
LCD Version:
APE ADSP Version: 256
SIMLock service: SIMLOCK SERVER [01000407031E]
Profile bits: 0000000000000000
Simlock config: 2140100000000000
Invalid codes entered: 0 / 0
Block: 1; Lock: 1; State: Closed; Data: 21401F
Block: 2; Lock: 1; State: Closed; Data: 21401F
Reading PM values...
Input power: 12,01V OK.
Output power at Line1 3,95V is in range of: 4,00V ±10,0%
Asic ID: 000000010000022600010006400C192101031103
EM Asic ID: 00000295
EM Asic ID: 00000B22
Public ID: 1AC00110536B0052FFCCE27D0E197F3317F6D6DC
Asic Mode ID: 00
Hash: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
Flashing file:
BB5 [BB5 ALGORITHM] MCU File: ReadKeys 0 kB
Speed: [3000k, 3250k, 3250k, 98k] Baud.
Supported Hardwares: [400C192101031103]
Asic Mode ID: 00
TBB5GetKeysThread 2.6.6.1923 finished at: 2009/01/12 10:37:04
Terminated with error: No available bootloader for this ID, probably bad cable [0001105A]
MCU Boot Version: 1.069, and up to date.
SMCU Boot Version: 1.34, and up to date.
Device opened at USB->Universal Box [UBTEST99]
helpsss.. Terminated with error:No device opened (0000001].00004010 teknik_servis Universalbox 4 08-03-2010 18:33
Terminated with error: CSCA service is not available at the moment [00001212] alunecosu_hd Universalbox 5 09-01-2007 16:32
Terminated with error:Not available boot loader guty Universalbox 3 06-23-2006 11:07
"Terminated with error:No avaiable bootloader for this ID[00011224] SicilianBoy Universalbox 3 12-18-2005 13:54
Page generated in 0.21740 seconds with 10 queries
