Dct4Direct Solution Under Testing By forum Admins |
11-02-2005, 22:37 | #1 (permalink) |
Junior Member Join Date: Sep 2005 Age: 41
Member: 183723 Status: Offline Thanks Meter: 0 | 7710 no signal after change imei the same problem. is it dctdirect bug or should i do sth els after change imei ?????? Last edited by venizmobile; 11-03-2005 at 14:09. |
11-06-2005, 00:03 | #3 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: No ID Age: 27
Member: 134684 Status: Offline Thanks Meter: 4 | Quote:
maybe is hardware probleme if u say after restoring original probleme u get the same probleme then existed only one explaination try pls with one new phone and post result pls B.R | |
1112 no signals after change imei? | smarty3399 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 01-19-2010 13:25 |
Caution!!! Dtc4 No Signal !! After Change The Imei | mustai | Dct4Direct | 32 | 01-29-2009 18:28 |
5140 no signal after changed flash ic | krdzo | Nokia Hardware & Hardware Repair | 0 | 08-16-2006 14:08 |
3650 no signal after change cpu | nimanima | Nokia Hardware & Hardware Repair | 1 | 04-29-2006 11:41 |
7710 no network after chenge imei whit ub | nimanima | Universalbox | 2 | 03-22-2006 20:40 |
