05-17-2006, 14:35 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | SST and C75 i hope Flash it for add French language phone conet ( using test point methode) when SSt begin Write Flash stay on 0% and don't begin !!! 2pcs same problem using sst 7.31 Thx |
05-18-2006, 12:26 | #2 (permalink) |
No Life Poster Join Date: Sep 2003
Member: 38795 Status: Offline Thanks Meter: 106 | Please use Boot password method and getcodes Midlet instead of TP where it is available. Try at lower speeds if there are errors or hangings on high speads. For example try at 920k if not flashing at 1,2M or at 460k if not working at 920k. If the PC serial or virtual port is plock chnge the cable to another port or restart PC |
05-18-2006, 15:43 | #3 (permalink) |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | i use matrtech for chnage language and Flash work fine but i have now soime pcs of C75 dead by free soft SDT can't write Flash , but with martech yes i still have 2 or 3pcs if you have suggestion , just teleme for fixing this bug |
05-18-2006, 18:04 | #4 (permalink) | |
Member: 38795 Status: Offline Thanks Meter: 106 | Quote:
Currently all flash files should be supported. | |
05-18-2006, 22:25 | #5 (permalink) |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | Phone model changed to: C75 Please connect the needle to Test-point Flash Chip : 0089880D (Intel) Bootcore IMEI 356272009058046 FIRMWARE PHONE MODEL: C75 FIRMWARE VERSION: 11 LANGUAGE GROUP: lg4 this all information about C75 but i din't suuced to Flash it using USB cablealwase stop on writing 0% i use comcable writinng Flash a100% but phone still dead!! |
05-19-2006, 11:41 | #6 (permalink) | |
For the problem wit USB cable. It may be a driver problem! please install the drivers from SST directory. Before doing this report to us your USB2Serial driver version | |
05-19-2006, 14:36 | #7 (permalink) |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | for USB cable or driver ther is no problem cose i Flash evrey day seimense and alwase use usb cable , like nowi Flash 5 pcs M55 work perfect without any problme but on C75 never begin write i hope you try to find c75 to test and you will see this problem |
06-10-2006, 08:45 | #8 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | Quote:
BR. | |
cx75 and c75 problem | SkyMobile05 | DreamBox | 2 | 09-05-2008 23:34 |
DCA 510 and C75 problems | 3aTmr | S-Gold Based Phones | 7 | 12-19-2005 23:45 |
sst kill c75 by unlock | lutechua | SST-Dongle | 5 | 11-15-2005 20:07 |
I need a date code for AX75,A75 and C75 | Steal-Man | E-Gold Based Phones | 3 | 11-12-2005 19:08 |
problem with SST and cx65 | zicotte | S-Gold Based Phones | 2 | 07-07-2005 17:33 |
