05-07-2008, 10:44 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Punjab, Pakistan Age: 38
Member: 264520 Status: Offline Thanks Meter: 61 | 1200 after flash contact service Problem: mostly hang in proccess, after reattache battery ok.. Action MCU. rh99_04.510 done!!! PPM. rh99_04.51ia done!!! UI setting (uncheck "Init simLocks") done!!! previous flash version is V. 3.44 after flash is showing "contac service" 've a any solution to flash+ full ui setting 100% wid ufs??? 1200, 1208 same problem... rply urgent.... |
The Following 3 Users Say Thank You to asrar For This Useful Post: |
05-07-2008, 11:49 | #3 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
flash like this mcu+ppm+image unlock (if ufs not supported then you have to use another tool for unlocking) problem will be solve. | |
05-07-2008, 12:16 | #6 (permalink) | |
Freak Poster Join Date: Feb 2007
Member: 444805 Status: Offline Thanks Meter: 45 | Quote:
use SELF TEST to see or to detect the problem of your phone UFS+HWK is tested 100% in 1200 and 1208, i tried many many many times br Silenthawk | |
05-07-2008, 14:36 | #12 (permalink) |
Member: 264520 Status: Offline Thanks Meter: 61 | thanks to all friends for sharing ur knowladge... after flashing wid JAF "contact service" remove , and fone become normal but my second quastion.. can we flash and unlock 100% with ufs...? if yes then how? if NO then why? |
05-07-2008, 15:05 | #13 (permalink) |
Freak Poster Join Date: Apr 2007 Location: malaysia
Member: 483720 Status: Offline Thanks Meter: 117 | << any solution to flash DCT4+ with ufs 100% test >> after flash is showing "contac service" rh105v372_part1 rh105v400_part1 rh105v411_part1 rh105v451_part1 rh105v506_part1 N1208_RH-105 http://www.4shared.com/file/46125452...ified=c8a522e8 Last edited by ptnetwork; 05-07-2008 at 15:11. |
1200 after unlock contact service | nimanima | Universalbox | 37 | 01-26-2009 08:19 |
1200 After Flashing Contact Service | kumar_pvj | Nokia Hardware & Hardware Repair | 8 | 05-15-2008 14:47 |
1200 after flash Contact Service!! | Wais777 | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 04-09-2008 05:17 |
2100 after flashing contact service and not connnecting with mbus,problem solved | monti_908 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 21 | 03-05-2004 10:10 |
