04-17-2009, 08:17 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 47
Member: 132054 Status: Offline Thanks Meter: 13 | 3110c data blk error-perfect soln Last edited by zandoo; 04-17-2009 at 08:26. |
The Following User Says Thank You to zandoo For This Useful Post: |
04-17-2009, 09:31 | #4 (permalink) | |
Crazy Poster Join Date: Jan 2008
Member: 670128 Status: Offline Thanks Meter: 6 | Quote:
04-17-2009, 10:33 | #5 (permalink) |
Member: 132054 Status: Offline Thanks Meter: 13 | brother just connect 9v via zener diode...to 2nd pin which is disconnected in 7pin jaf cable n 6th no pin ground....just bring these two wires out from upside of cable n connect 9v battery...click on extvppp...thats all |
04-17-2009, 10:54 | #6 (permalink) | |
No Life Poster Join Date: Jul 2008
Member: 811779 Status: Offline Thanks Meter: 242 | Quote:
is it correct? br, | |
The Following User Says Thank You to metals For This Useful Post: |
07-05-2009, 06:33 | #8 (permalink) | |
Freak Poster Join Date: Feb 2006
Member: 236743 Status: Offline Thanks Meter: 113 | Quote:
The Following User Says Thank You to ashish_1212 For This Useful Post: |
02-03-2010, 15:01 | #10 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 303868 Status: Offline Thanks Meter: 62 | 3110c - RX2 flashing error Flash with - ver 7.21, cable - 8 pin & USB cable Rehot - CPU, Power IC , Thavo , Memory Ic , many time present time set complete dead BUT booting 100% ok . Set also could not convert in to Normal , Local , or Test mode . Flashing Result - by different box Jaf - abort at last i select downgrade also. Mx KEY - RX2 not responding check BSI , cable & pin Micro - Data BLK error UB - Through USB - Detecting USB flash device. Sir any other cable or box solve this solution Pls help me . Please digramatically see your language i could not follow it |
3110 data blk error | vinay_sharma | HWK | 99 | 08-12-2014 14:10 |
Nokia 3110c Data blk error | logicmobile | Nokia Base Band 5 ( BB-5 ) | 25 | 12-04-2011 07:12 |
3110c data blk error | mahesh123 | HWK | 16 | 09-04-2010 18:37 |
3110c data blk error | jaysukh | HWK | 5 | 11-30-2009 11:16 |
Bb5 Flashing Data Blk Error | kankandeka | Nokia Base Band 5 ( BB-5 ) | 0 | 05-18-2008 19:34 |
