Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 04-17-2009, 08:17   #1 (permalink)
Member: 132054
Thanks Meter: 13
Cool 3110c data blk error-perfect soln
mostly on 3110c dead during flashing in hwk...data blk error....i tried n getting good result....in cable 7pin.....just connect 9v via zener diode to 2nd no pin from top(b/c side) n 6th no pin ground...click on extvpp..(attach 9v battery)..n flash.....just do technically perfect by understanding
The Following User Says Thank You to zandoo For This Useful Post:
Old 04-17-2009, 09:18   #2 (permalink)
metals's Avatar
Member: 811779
Thanks Meter: 242
can post here log file..
Old 04-17-2009, 09:21   #3 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,055
Flashing 7 pins, Dual Line should be Check Mate. Its best to use Other Tool using USB cable.
Old 04-17-2009, 09:31   #4 (permalink)
Crazy Poster
Member: 670128
Thanks Meter: 6
how to do this would u please upload the picture for us.......
Old 04-17-2009, 10:33   #5 (permalink)
Member: 132054
Thanks Meter: 13
brother just connect 9v via zener diode...to 2nd pin which is disconnected in 7pin jaf cable n 6th no pin ground....just bring these two wires out from upside of cable n connect 9v battery...click on extvppp...thats all
Old 04-17-2009, 10:54   #6 (permalink)
metals's Avatar
Member: 811779
Thanks Meter: 242
Brother, are you asking about this
is it correct?
br,
The Following User Says Thank You to metals For This Useful Post:
Old 04-28-2009, 12:30   #7 (permalink)
robean's Avatar
Member: 538410
Sonork: 100.1590750
Thanks Meter: 193
plz post any one has tested this solution
Old 07-05-2009, 06:33   #8 (permalink)
Member: 236743
Thanks Meter: 113
thx brother this is 100% tested & working solution, thx again.
The Following User Says Thank You to ashish_1212 For This Useful Post:
Old 02-03-2010, 09:39   #9 (permalink)
Chiran's Avatar
Member: 718059
Sonork: 100.1587605
Thanks Meter: 36
No brother don't do anything just usb flash it via mt or ub. It is 1000% tested solution.
Old 02-03-2010, 15:01   #10 (permalink)
Member: 303868
Thanks Meter: 62
3110c - RX2 flashing error
Flash with - ver 7.21, cable - 8 pin & USB cable
Rehot - CPU, Power IC , Thavo , Memory Ic , many time
present time set complete dead BUT booting 100% ok .
Set also could not convert in to Normal , Local , or Test mode .
Flashing Result - by different box
Jaf - abort at last i select downgrade also.
Mx KEY - RX2 not responding check BSI , cable & pin
Micro - Data BLK error
UB - Through USB - Detecting USB flash device.
Sir any other cable or box solve this solution Pls help me .
Please digramatically see your language i could not follow it
Old 02-03-2010, 15:15   #11 (permalink)
Member: 90733
Thanks Meter: 39
Use JAF with UFS interface I got good results.
Old 02-04-2010, 05:21   #12 (permalink)
Member: 303868
Thanks Meter: 62
see SL1 3110c and guide me please detail about cable
Detail pinout about 3110c
The Following 3 Users Say Thank You to sonu_to88 For This Useful Post:
Old 02-04-2010, 06:02   #13 (permalink)
Member: 303868
Thanks Meter: 62
3110c Data BLK error or RX2 error
This modified cable figure is write or wrong
File Type: jpg 3110c pin out When RX2 error or Data BLK error.JPG (32.5 KB, 690 views)
The Following 2 Users Say Thank You to sonu_to88 For This Useful Post:
Old 02-04-2010, 06:09   #14 (permalink)
Member: 303868
Thanks Meter: 62
Why can i interface between Micro & JAF clear it please.
Old 02-07-2010, 18:36   #15 (permalink)
Member: 775587
Thanks Meter: 29
I have 5ps 3110c with the same probleme, any one have perfect solution.
The Following 2 Users Say Thank You to gautammobile For This Useful Post:
3110 data blk error vinay_sharma HWK 99 08-12-2014 14:10
Nokia 3110c Data blk error logicmobile Nokia Base Band 5 ( BB-5 ) 25 12-04-2011 07:12
3110c data blk error mahesh123 HWK 16 09-04-2010 18:37
3110c data blk error jaysukh HWK 5 11-30-2009 11:16
Bb5 Flashing Data Blk Error kankandeka Nokia Base Band 5 ( BB-5 ) 0 05-18-2008 19:34
Page generated in 0.21589 seconds with 11 queries
