01-16-2008, 14:50 | #1 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 470292 Status: Offline Thanks Meter: 147 | 6230i Flash error?? 1st Boot Ok, TIKU, UPP: 1052 Fl0: 0x00000000-0x00FFFFFF,00000000, UNKNOWN CHIP ! Fl1: 0x02000000-0x02FFFFFF,FFF7FFF7, UNKNOWN CHIP ! FLASH DEVICE NOT SUPPORTED Check Product, Use newer Flash Update Pack Bad Algorithm File: u_intel.fia Rebooting Mobile When I press flash it gives this log. 1st Boot Ok, TIKU, UPP: 1052 Fl0: 0x00000000-0x00FFFFFF,03B768E3, UNKNOWN CHIP ! Fl1: 0x02000000-0x02FFFFFF,FFF7FFF7, UNKNOWN CHIP ! FLASH DEVICE NOT SUPPORTED Check Product, Use newer Flash Update Pack Bad Algorithm File: u_intel.fia 2nd Boot Error: Error Data1: 00000000: 9F 01 04 00 B7 03 E3 68 00 00 43 C9 00 00 02 F7 .......h..C..... 00000010: FF F7 FF 00 00 00 00 00 00 04 00 00 01 00 00 00 ................ 00000020: 00 00 00 00 06 00 00 01 00 00 00 00 00 00 00 00 ................ 00000030: 00 00 00 10 F0 97 E5 10 F0 97 E5 10 F0 97 E5 7B ...............{ Error Data2: 00000000: 11 11 11 11 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000010: 00 00 00 00 00 00 04 00 00 01 00 00 00 00 00 00 ................ 00000020: 00 06 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ................ 00000030: 10 F0 97 E5 10 F0 97 E5 10 F0 97 E5 7B D3 72 00 ............{.r. Before taking screenshot, expand this window ! Process Failed, Repowering Mobile |
01-16-2008, 14:58 | #2 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: E G Y P T Age: 48
Member: 102762 Status: Offline Sonork: 1583079 Thanks Meter: 186 | Quote:
01-16-2008, 16:24 | #3 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Also the flash ID is changing on read, so it maybe a faulty or bad quality cable. Odia. | |
01-16-2008, 16:56 | #4 (permalink) | |
01-21-2008, 13:01 | #6 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 268287 Status: Offline Thanks Meter: 1 | this what is displayed for a 3100 with contact service pliiz have you any idea how to fix this?: 1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x017FFFFF,00EC22FA,Sam K8S6415ETA FLASH DEVICE NOT SUPPORTED Check Product, Use newer Flash Update Pack Bad Algorithm File: u_amd.fia 2nd Boot Error: Error Data1: 00000000: 9B 01 02 01 00 EC 22 FA 00 00 28 11 02 00 00 00 ......"...(..... 00000010: 01 00 00 00 00 AD 7E B6 1A 1B BE 0B E2 7D 58 6B ......~......}Xk 00000020: E4 DB EE 65 14 90 00 00 00 00 00 00 00 00 00 00 ...e............ 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Error Data2: 00000000: 11 11 11 11 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000010: 00 00 AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE ...~......}Xk... 00000020: 65 14 90 D3 72 00 00 00 00 00 00 00 00 00 00 00 e...r........... 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Before taking screenshot, expand this window ! Process Failed, Repowering Mobile |
03-19-2008, 08:44 | #7 (permalink) |
Insane Poster Join Date: Sep 2004 Location: KENYA
Member: 83870 Status: Offline Thanks Meter: 13 | halo i have 6230 contact service even after flashing the contact service is still there,any body has an i dea what to be done MCU ID: 0x1052 FLASH ID0: EC00F822 -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EC003900 -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00000100 -> NOT USED Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.00 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.40 18-04-05 RH-12 GSM P1.1 (c) NMP. HW version: 0600 PCI version: UEM version: 288 UPP version: 4178 RFIC version: p 10ff11ff0203 DSP version: p B0435T_04w46 LCD version: SEIKO PPM version: V 05.40 18-04-05 RH12_28_- GSM P1.1 A BT MCM version: 0380 ADSP version: MATRIX_04_w35_prod_w46 Production serial number: Product code: Module code: Basic production code: 0509076 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 352953007395290 IMEI spare to net: 3A 25 59 03 70 93 25 09 IMEI SV to net: 33 25 59 03 70 93 25 19 F5 Master Code: 0604115600 Phone type: RH-12, Software version: 05.40, Language Pack: A User code: 12345 Block 1: Lock 1: CLOSED -> Lock Data: 00101F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-12.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.40 18-04-05 RH-12 GSM P1.1 (c) NMP. HW version: 0600 PCI version: UEM version: 288 UPP version: 4178 RFIC version: p 10ff11ff0203 DSP version: p B0435T_04w46 LCD version: SEIKO PPM version: V 05.40 18-04-05 RH12_28_- GSM P1.1 A BT MCM version: 0380 ADSP version: MATRIX_04_w35_prod_w46 Production serial number: Product code: Module code: Basic production code: 0509076 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 352953007395290 IMEI spare to net: 3A 25 59 03 70 93 25 09 IMEI SV to net: 33 25 59 03 70 93 25 19 F5 Master Code: 0604115600 Phone type: RH-12, Software version: 05.40, Language Pack: A User code: 12345 |
03-18-2010, 08:54 | #11 (permalink) | |
Freak Poster Join Date: Sep 2007
Member: 581888 Status: Offline Thanks Meter: 74 | Quote:
Nokia 6230i flashing error | Tadiwa | Twisterflasher | 6 | 11-22-2005 06:55 |
6230i flashing error | usernome | Griffin | 3 | 09-04-2005 10:38 |
6230i flashing error | usernome | Twisterflasher | 17 | 08-29-2005 18:17 |
