Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 03-02-2009, 16:07   #1 (permalink)
rry
Member: 372620
Thanks Meter: 38
Err: Cmt flash write d_blk 000000000000000910000000b172
ERR: CMT FLASH WRITE D_BLK 000000000000000910000000B172
Pls make solution for this , as with MT 10 pin it works fine. Changing cable set is expensive.
Old 03-02-2009, 17:37   #2 (permalink)
mohammed-anis's Avatar
Member: 751223
Sonork: mobilecenter88
Thanks Meter: 538
bro just untick dual line mode & use ini setting
Old 03-03-2009, 09:03   #3 (permalink)
rry
Member: 372620
Thanks Meter: 38
while uncheck dual line flashing not started ' use dual line message box comes ' . This problem is coming with latest ver phones say 7.21 ver 7.01 works ok . MT 10 pin flashes ver 7.21 smoothly but hwk says D_Block_____ error
Product Supporters pls make clear this issue. What i had observed is true or any thing wrong i have done
Regards
Old 03-03-2009, 12:51   #4 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
The issue is a cable problem and has been covered many many times, either you are using a 5 pin cable when a 7 pin is required or your 7 pin cable is not correctly wired.
Odia.
The Following User Says Thank You to Odia The Ultimate For This Useful Post:
Old 03-04-2009, 10:54   #5 (permalink)
rry
Member: 372620
Thanks Meter: 38
Kind attn Mr Odia
Sir i am using 7 pin cable and the set is 3110c. Same time i am flashing a set 3110c older ver7.01 flashing is ok and while flashing a new 3110c ver 7.21 D_Block___ error comes. Dual line is check and when doing dual line uncheck no result. Now this new ver. set flashed ok with MT 10 pin
Regards
Old 03-05-2009, 18:15   #6 (permalink)
Member: 302843
Thanks Meter: 111
flash whit jaf 100% ok
The Following User Says Thank You to mahesh123 For This Useful Post:
Old 03-06-2009, 14:10   #7 (permalink)
Member: 411831
Thanks Meter: 215
Odia.
sorry 4 my comment
i face this problem many times.
i have 2 hwk, one show error(like that) & other one flash ok by same set,same cable.
i think this is ufs firmware & confrigation fault.
Old 11-07-2009, 06:10   #8 (permalink)
Member: 18057
Thanks Meter: 64
yes bro.. u rught... many many times they understand this pro.... but they say cable pro.... this is completly wrong.. ans...... in many n73 unchecked dual line.. & flash it.. whn going to writing.. hwk says this boot loade does not support 5 pin cable use 7 pin cable.. or jaf flashed phone ok... so where is prob.... ? maybe they r working with new update to fix this issue...
Old 11-13-2009, 02:34   #9 (permalink)
Member: 733840
Thanks Meter: 11
I flash 6500c-rm265 same problem use 7cable
Old 11-13-2009, 06:09   #10 (permalink)
Registered User
Member: 669673
Thanks Meter: 301
first to sorry my english
brother this is cable prolem if u want fix this problem u must use 9 pin cable 7pin cable connect board and other 2 pin( + , - ) connected repido 9v bettery now open hwk 2.0.9.0 and untick use ini setting and tick ext. vpp now u can flash. this is 1000% tested solution
Old 11-13-2009, 10:33   #11 (permalink)
Member: 870664
Sonork: 100.1614707
Thanks Meter: 56
change your cable brother, try to use 6300 cable work fine for me, otherwise check your phone if it has hardware problem
Old 02-15-2010, 11:38   #12 (permalink)
Registered User
Member: 751390
Thanks Meter: 18
yeaahhh JAF ok for flashing,
but it does not LOKAL MODE...
how is it??
Old 04-06-2010, 10:52   #13 (permalink)
Member: 503816
Thanks Meter: 224
thanx alot my dear my problem is solved 100%3
Old 05-18-2010, 03:02   #14 (permalink)
Member: 1304916
Brother can you give me schematic of this cable connection for use external 9V power adaptor
Old 05-18-2010, 03:54   #15 (permalink)
sandhu36's Avatar
Member: 387696
Thanks Meter: 161
this err phone not usb flashing
this big problem mane 3110c but temprary solution
tested many time 100%% working marking skip erase option
http://forum.gsmhosting.com/vbb/f299...-100-a-980216/
3110c big problem..........ERR: CMT FLASH WRITE D_BLK MOURAD™ HWK 20 05-05-2010 05:46
Err: Ape flash write d_blk 000000000000000910000000b172 johnmene HWK 5 02-21-2010 09:04
ERR: CNT FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x004000 msantar HWK 1 06-15-2009 17:18
Page generated in 0.22466 seconds with 10 queries
