03-02-2009, 16:07 | #1 (permalink) |
Major Poster Join Date: Oct 2006
Member: 372620 Status: Offline Thanks Meter: 38 | Err: Cmt flash write d_blk 000000000000000910000000b172 Pls make solution for this , as with MT 10 pin it works fine. Changing cable set is expensive. |
03-03-2009, 09:03 | #3 (permalink) |
Member: 372620 Status: Offline Thanks Meter: 38 | while uncheck dual line flashing not started ' use dual line message box comes ' . This problem is coming with latest ver phones say 7.21 ver 7.01 works ok . MT 10 pin flashes ver 7.21 smoothly but hwk says D_Block_____ error Product Supporters pls make clear this issue. What i had observed is true or any thing wrong i have done Regards |
03-03-2009, 12:51 | #4 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Odia. | |
The Following User Says Thank You to Odia The Ultimate For This Useful Post: |
03-04-2009, 10:54 | #5 (permalink) |
Member: 372620 Status: Offline Thanks Meter: 38 | Kind attn Mr Odia Sir i am using 7 pin cable and the set is 3110c. Same time i am flashing a set 3110c older ver7.01 flashing is ok and while flashing a new 3110c ver 7.21 D_Block___ error comes. Dual line is check and when doing dual line uncheck no result. Now this new ver. set flashed ok with MT 10 pin Regards |
03-06-2009, 14:10 | #7 (permalink) | |
Banned Join Date: Dec 2006 Location: inside of infinity best tool
Member: 411831 Status: Offline Thanks Meter: 215 | Quote:
i face this problem many times. i have 2 hwk, one show error(like that) & other one flash ok by same set,same cable. i think this is ufs firmware & confrigation fault. | |
11-07-2009, 06:10 | #8 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Everywere Age: 46
Member: 18057 Status: Offline Thanks Meter: 64 | yes bro.. u rught... many many times they understand this pro.... but they say cable pro.... this is completly wrong.. ans...... in many n73 unchecked dual line.. & flash it.. whn going to writing.. hwk says this boot loade does not support 5 pin cable use 7 pin cable.. or jaf flashed phone ok... so where is prob.... ? maybe they r working with new update to fix this issue... |
11-13-2009, 06:09 | #10 (permalink) |
Registered User Join Date: Jan 2008 Location: Where never ends.
Member: 669673 Status: Offline Thanks Meter: 301 | first to sorry my english brother this is cable prolem if u want fix this problem u must use 9 pin cable 7pin cable connect board and other 2 pin( + , - ) connected repido 9v bettery now open hwk 2.0.9.0 and untick use ini setting and tick ext. vpp now u can flash. this is 1000% tested solution |
04-06-2010, 10:52 | #13 (permalink) | |
Banned Join Date: May 2007 Location: In your Heart
Member: 503816 Status: Offline Thanks Meter: 224 | Quote:
05-18-2010, 03:54 | #15 (permalink) | |
Freak Poster Join Date: Nov 2006
Member: 387696 Status: Offline Thanks Meter: 161 | Quote:
this big problem mane 3110c but temprary solution tested many time 100%% working marking skip erase option http://forum.gsmhosting.com/vbb/f299...-100-a-980216/ | |
3110c big problem..........ERR: CMT FLASH WRITE D_BLK | MOURAD™ | HWK | 20 | 05-05-2010 05:46 |
Err: Ape flash write d_blk 000000000000000910000000b172 | johnmene | HWK | 5 | 02-21-2010 09:04 |
ERR: CNT FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x004000 | msantar | HWK | 1 | 06-15-2009 17:18 |
