12-27-2009, 04:10 | #1 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Living with mobile phones
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | Help me!!!Nokia 6070 dead Quote:
12-27-2009, 16:01 | #3 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | Write Error: hDat 14, at: 0x01000000:08 case in this fone many times solved by dry/re-fix flash chip |
The Following User Says Thank You to neilthirumuttam For This Useful Post: |
12-27-2009, 16:25 | #5 (permalink) |
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | [QUOTE=neilthirumuttam;5189349]Write Error: hDat 14, at: 0x01000000:08 case in this fone many times solved by dry/re-fix flash chip[/QUOTE yeah its flashchip problem after replace new flashchip Mobile is working finely |
12-27-2009, 16:25 | #6 (permalink) |
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | Unstable voltage v flash may also cause Error: hDat 14 but that voltage originate fro uem. so concentrate on flash chip . it is easy. flash chip from other fone my couse imei problem just correct it thanks for ur fast response keep it up regards NEIL |
12-27-2009, 19:52 | #7 (permalink) |
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | This Nokia 6070 While dialling call it shows Battery low then automatically switch off i think its PA problem share ur suggestion here |
12-28-2009, 04:26 | #8 (permalink) | |
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | Quote:
this problem better to discussed in nokia hardware post there with full history of symptom, works done&present condition. because I think it out of subject of UFS | |
12-30-2009, 04:14 | #11 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 811779 Status: Offline Thanks Meter: 242 | i think it was my mistake because i read just last post to check pa is very easy and it is common fault specialy china mobiles |
The Following User Says Thank You to metals For This Useful Post: |
Pls. Help Me Nokia 5200 Dead,UFS is Showing... | amit123 | Nokia Hardware & Hardware Repair | 3 | 02-16-2011 22:50 |
Help me!!!Nokia 3110c Dead | ..::MOBILES::.. | HWK | 17 | 01-26-2010 09:27 |
Help me!!!NOKIA 6070 Battery low problem | ..::MOBILES::.. | Nokia Digital Core Technology 4 ( DCT-4 ) | 8 | 01-03-2010 01:46 |
Help me!!!Nokia 7610 dead | ..::MOBILES::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 12-15-2009 13:51 |
Help me, Nokia 6070 dead.... | hossnemamun | Nokia Hardware & Hardware Repair | 2 | 02-09-2009 18:15 |
