11-15-2007, 12:46 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Spain Age: 42
Member: 72515 Status: Offline Thanks Meter: 27 | How to can unlock Se T610 with 4 Locks Closed? I have the codes that RTP of HWK give me, but the mobile donīt accept the codes Please Connect Cable to Switched-Off Mobile Mcu_Id: 5B 08 02 01 FF FF FF FF Secure Boot Ok, Time: 1:45 Fl_Id : 00898864 Intel 28F640W18T {2} Blk_0 : A60000 IMEI : 353989-00-108005-7 ULock : Factory_Off : 0000 NCK : 82110220 NSCK : 70985399 CCK : 80152156 SPCK : 59993314 LockSt: Sim_Locks Open, Mcc+Mnc: 214-01, AAAA AA Whatīs the solution to unlocked it? I have HWK -RTP 2..06 Regards |
11-15-2007, 16:16 | #2 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Quote:
Did u not see that? Ok, put the engineer code in ( on keypad press > * < < * < * [left and right being used on joystick]) enter service menu, and view lock state, if all are locked, you will need to either fully flash the phone again and maybe write gdfs, or for quickness sake, flash patched file to it, and write imei same as on phone! I think thats the procedure anyway, its been a while since ive done one tbh! Anyway, let us know how you get on! | |
11-15-2007, 18:30 | #4 (permalink) |
Member: 72515 Status: Offline Thanks Meter: 27 | Info I flashed it: Mcu, Modem and GDFS, with files of HWK Support But the mobile not accept the codes, and if I can Restore Security Block of GDFS, software give me this message: "GDFS Security Block 0 not Exists, Rewrite Full GDFS" Please, say me what must I make. I flashed the phone ok, but not work to unlock all locks Regards |
11-15-2007, 19:29 | #5 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Java Age: 46
Member: 166000 Status: Offline Thanks Meter: 26 | What's the condition now? if it's life : 1. try " init secblk " 2. if failed flash gdfs ( with uncheck protect SA ) ---> resore SA ----> then init secblk |
11-16-2007, 11:31 | #6 (permalink) |
Member: 72515 Status: Offline Thanks Meter: 27 | Info Phone itīs Life I restore SA and I init secblk but the phone have too 4 Locks Closed and Not accept put in codes I donīt know if my Gdfs have uncheck Rsa Have you a Gdfs with uncheck Rda to flash phone? Regards |
11-18-2007, 07:31 | #7 (permalink) | |
Member: 166000 Status: Offline Thanks Meter: 26 | Quote:
u reflash gdfs with option " marked uncheck protect SA" ( see at upper side menu ), after flash gdfs do restore SA ( from the same phone, look at info window, find file with same name with backup file ****.SIM ) then INIT SECBLK. | |
11-18-2007, 11:20 | #8 (permalink) | |
or download a 'bypass otp imei' flash from support, flash the phone, change imei to orginal, and then everything will be all good for you! | |
The Following User Says Thank You to .:GSM International:. For This Useful Post: |
Problem SE Z 300 4 locks closed??? | Unlocker AL | Cruiser Suite | 1 | 07-12-2008 12:05 |
how much does it cost to unlock P990 CID49 with 1 lock closed???? | tsarkh | Universalbox | 1 | 09-16-2007 20:50 |
Can unlock SE t610 with sonics? | rikimaer | Sonics Box | 0 | 11-03-2005 11:47 |
t610 r1L 4 lock closed help me | hmof | Sony Ericsson | 3 | 08-31-2003 22:07 |
3310 with 4 locks closed- help | ABSYS | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 08-27-2001 17:01 |
