HOW to erase nokia 5800.and sl3 ?on hwk HOW to erase nokia 5800.and sl3 ? |
if you do a delete any bb5 imei going to hurt you is corrupt imei 123456789 |
bro first create backup then select 5800 erase but imei 1234567890. |
if you backup all certificates & then restore in the end will the imei still be 1234567.....? |
but why you want to erase? what problem you are facing? after erasing you will damage its imei |
i now after erasing will damage its imei 123? i have full back up . just tell me how to erase nokia 5800 ? i use hwk. |
you said (i now after erasing will damage its imei 123) that's mean you have erased !! so now you must restore backup....... good luck, |
just tell me how to erase nokia 5800 ? it's possible ? |
use 256mb erase file by kashi4gul , try to search in forum u'll able to find d erse file. place that erase file on ppm & flash ur phone, it will erase d complete flash of d mobile. post result |
HWK can not erase 5800 Some time ago i was try to do it with different ways - but FAILURE! |
Hi. i dont have a phone that needs erasing of the flash but i would like to know for future reference if i do get 1 that needs erasing. IF you erase bb5 flash with hwk can the imei be restored back to original thanks for your advice |
if you erase a died phone with only backup cert without backuping PM (specially field 308 and 120 if exist) you will lost your simlock validity and also your superdongle but dont worry ;);) you can repair superdongle for all phone models (PA_SL1+ PA_SL2 + PA_SL3) for simlock you can repair it only for PA_SL1+ PA_SL2 but with other tools. if you have an nokia (PA SL1 + PA SL2 ) so you can with any problem erase ........flash, write eno file if exist write backup pm and cert. if you have an Nokia PA_SL3 i will not advice you to make erase operation even if you have full backup imei and PM. hope all clear now for you good luck |
Code: YES I agree nice info thanks but i many time try 1st make full backup rpl and simlock pm then nokia 5130 sl3 after Full erase operation imei 123? just resort all ok but simlock not resort .why i have full back up hwk in Rm-495_xxxxxxxxxxx_25201030407_HWCCmt Rm-495_xxxxxxxxxxxx_25201030407_CCCCmt Rm-495_xxxxxxxxxxxx_25201030407_RDCmt Rm-495_xxxxxxxxxxxxx_25201030407_NPCCmt Rm-495_xxxxxxxxxxxxxx_25201030407.ask and full pm after wr cert hi is sitll 123? imei and contact service.. why? |
maybe i can help you but one other question: what is the state of phone first time you maked your backup? maybe imei was damaged since the beginning. |
and one other request: post also product code for your phone you can see it under battery. good luck |
