02-01-2008, 10:59 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | MR odia sonyericsson j220i is supported by hwk or not Last edited by f164; 02-01-2008 at 11:09. |
02-01-2008, 11:12 | #2 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Quote:
1) 1st of All you shld have original HWK. 2) 2nd must have latest software version v2.0.6. 3) 3rd Bettery Should be Fully Charged. 4) Remove Bettery from Fone, and Re-attach it. 5) Connect Software (ATRz, KZF, RTP) with your UFS. 6) Press GO (sometime need to press RSA to remove RSA). 7) Attach Cable with Fone Connnector Firmly. 8) Phone will start Booting. if any Problem Remove and Re-Attach Bettery don't Unplug Cable. You Phone will Successfully Boot. Take Care ENJOY | |
02-01-2008, 14:42 | #4 (permalink) |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | It could be RAM(FlashIC) problem but do one thing before you open the fone just uncheck "High Speed Flashing Option" in ATRz and try againt to boot fone because i also get same problem with 2~3 fones and when i uncheck "High Speed Flashing" Fone connect properly, Unlocked Successfully, Flashed Successfully. Take Care ENJOY |
02-01-2008, 15:07 | #6 (permalink) | |
Member: 184351 Status: Offline Thanks Meter: 263 | Quote:
02-01-2008, 15:12 | #7 (permalink) | |
02-02-2008, 07:31 | #9 (permalink) |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | i think j220 it realy a problem for boot. i face this the same problem with j220i to unlock after many try, i can't boot phone and suspect my cable but wrong.i tested 02 cables without succeed. finaly, i unlock the phone with cruiser easily. may be something wrong with boot of that phone in soft. please may saras check this. |
02-02-2008, 10:38 | #10 (permalink) | |
after i ticked high speed flashing option and pressed boot the phone booted normally i don't know what was the problem ? | |
02-02-2008, 18:19 | #12 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Odia. | |
02-12-2008, 11:00 | #13 (permalink) |
Crazy Poster Join Date: Oct 2005
Member: 188545 Status: Offline Thanks Meter: 8 | Mr Odia, I Do every thing i mean every thing but can not conecct the J220 J230 with ufshwk 2.06.000 .My devic is 100% origional TWISTER & Origional Hwk Upgrade with no error .Still facing error ( Ram Loader Failed ) .I have another Tornado Flasher with origional hwk & 3.03.00 setup . Set coneccted and flashed successfully .Sir how solve problum . Thanks , ChMumtaz |
03-12-2008, 14:35 | #14 (permalink) |
Freak Poster Join Date: Dec 2007 Location: algerie
Member: 643285 Status: Offline Thanks Meter: 11 | j220i inser sim correct j220i show inser carte sim correct and counter blocked is supported by HWK tested tru this procedure http://rapidshare.com/files/98237167...C_Balt_Rus.zip http://rapidshare.com/files/98239883/J220_R5C_HK.zip use one of these firmwares with hwk flash MCU part 1 and MCU part 2 unlock phone enter code manually ENJOY |
Is 6600s supported by ub or not | gagan_o5 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 09-27-2009 12:08 |
Is 6600s supported by ub or not | gagan_o5 | Universalbox | 4 | 09-26-2009 13:05 |
Is 6600s and 3600s supported by ub or not | keeran | Universalbox | 5 | 09-17-2009 10:16 |
is alcatel OT-S320 supported by multibox or not | f164 | Multi-box LITE | 3 | 09-30-2008 12:07 |
Is ku250 supported by EUB or not yet ? | beneto | Easy-Unlocker | 5 | 06-02-2008 16:23 |
