09-08-2007, 19:18 | #1 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | N90 problem after flash succeed. this is the log of that phone Quote:
09-09-2007, 20:40 | #2 (permalink) |
Freak Poster Join Date: Jan 2006 Location: South Africa
Member: 227454 Status: Offline Thanks Meter: 48 | This problem is due to the software version that u intstalled on your N90 u must destroy the record of version in the phone by using the downgrade button & then try to reflash the phone ur phone will be back to normal. |
09-10-2007, 08:50 | #3 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | i have use downgrade button to reflash again today but still the same problem when remove from cable i have " V5.06.07.7.3 Test mode Nokia Nokia" when put on with battery but on box work well some say that ut can be problem on power button or ribbon. i'm going to test it. |
09-12-2007, 08:36 | #5 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | ok i flash it with sw 5.06 than 3.05 but the saaame results. i hva make seft test all level passed only 02 not passed concerning Power and cmt ape not passed failed. |
09-12-2007, 08:40 | #6 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | the sef tests give these: all level passed only this 02 failed - ST CMT_APE_WAKE UP _test -NO- not executed - ST_CD SP_GSM_Tx_Power_Test-NO- PN_ST Error:0000 what is the problem, should i modified cable to succeed? |
10-04-2007, 14:59 | #9 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | no phone does not cahrge when use chargers.because when you insert battery and put on phone, it justdisplay test mode. only when itis on ufs that is start normaly. |
5310 problem after flash.Please help for this problem. | caremobiles | Nokia Base Band 5 ( BB-5 ) | 9 | 04-30-2009 15:39 |
d780 flashing problem...after flashing ringer problem | gsm st | SWIFT Platform | 2 | 03-22-2009 22:29 |
N90 problem after flash succeed. | denard | Nokia Base Band 5 ( BB-5 ) | 3 | 09-12-2007 09:09 |
Display problem after flashing t28s | mashco | Old Ericsson Phones & Sony Phones | 1 | 04-22-2001 14:59 |
