08-21-2006, 17:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: USA
Member: 197538 Status: Offline Thanks Meter: 97 | k600I dead AFTER FLASHING WITH hwk SOMEONE PLEASE HELP .. I HAVE A K600i THAT WAS BRINGING PROBLEM AND WAS FREEZING SO I DECIDED TO FLASH IT WITH HWK AND NOW PHONE IS DEAD ODIA AND OTHERS PLEASE HELP I DOWNLOADED FLASH FILES FROM HWK SITE AND TRIED BASICALLY ALL FILES .. PHONE IS K600i 36 RED IT WAS ORIGINALLY EMEA 6 AND EVERYTIME I TRY TO FLASH IT PHONE DOES NOT COMPLETE GIVING ME ERRORS HERE IS THE SCREENSHOT PLEASE TELL ME WHERE AM I GOING WRONG ..I ALSO TRIED IT WITH SEMC TOOL BUT SAME PROBLEM I FLASH THE 2 MCU FILES AND FS FILE AND ALL GOOD BUT REFUSES TO LOAD CS LOADER AND TO CUSTOMISE NOW PHONE IS DEAD I HAVE THE SECURITY BACKUP TOO OF THE PHONE WHEN IT WAS WORKING AND I ALSO READ THE GDFS McuId: 71000301FFFFFF, CID: 36, 4 (Red) Mcert: A1_DB2000_36_RED Baud Rate: 460800 Trying: CXC1325414_050331_1652_R3U{0101020401}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 050207 0939 MATCXC1325414_FLASHLOADER R3U, Ok IMEI : 356572-00-017551-0, CID: 36, CDT: 1 0 1 (Red) FlId0: 200D, ST M30L0R8000T0 FlashImage: X_K600_CXC1250079_CHINA_R2G001.bin (36_RED) FlashImage Certificate Accepted MCU Part_1 Flashing Done, Time: 09:24 FlashImage: X_K600_CXC1250017_APAC1_R2G002.bin (36_RED) FlashImage Certificate Accepted MCU Part_2 Flashing Done, Time: 03:07 IMEI : 356572-00-017551-0, CID: 36, CDT: 1 0 1 (Red) FlId0: 200D, ST M30L0R8000T0 OTP_F: 920E372D69225026 - Locked OTP_U: 1480DC7005F04804 - Locked FlId1: 200E OTP_F: 8E122C3669223426 - Locked OTP_U: 1480DC7005F04804 - Locked 050430 1714 MATCXC1327363_SEMC_CS_LOADER_1_R4B Customization Info Err_08.5: Bad Resp Hdr 06, McuId: 71000301FFFFFF, CID: 36, 4 (Red) Mcert: A1_DB2000_36_RED Baud Rate: 460800 Trying: CXC1325414_050331_1652_R3U{0101020401}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 050207 0939 MATCXC1325414_FLASHLOADER R3U, Ok IMEI : 356572-00-017551-0, CID: 36, CDT: 1 0 1 (Red) FlId0: 200D, ST M30L0R8000T0 OTP_F: 920E372D69225026 - Locked OTP_U: 1480DC7005F04804 - Locked FlId1: 200E OTP_F: 8E122C3669223426 - Locked OTP_U: 1480DC7005F04804 - Locked BLK_0: 0x21F00000 IMEI : 356572-00-017551-0 OTP CID: 36, GDFS CID: 36 ULCK : 0000 - Off NCK : Open [5-5] NSCK : Open [5-5] SPCK : Open [5-5] CCK : Open [5-5] PCK : Open [5-5] ESLK : Open [5-5] Flags : 01FFFFFFFFFFFFFFFFFF [UMTS] Security Backup: K600_35657200017551_21082006_74201.sim Warning: Main Digest Calc Fails Security Initialization Done, Time: 00:07 All Done, Total Time: 13:18 PLEASE HELP URGENT THANKS AK |
08-22-2006, 12:04 | #3 (permalink) |
Member: 197538 Status: Offline Thanks Meter: 97 | Odia thanks for replying ..believe me i have searched many forums and this one too and some tell me to Put a new GDFS file which i did with SEMC tool but now even worst i guess ,, also phone is dead .. and there is No GDFS file for K600i RED 36 for HWK ... Can u please help me revive this phone much will be appreciatted man .. thanks anytime u r free let me know // my email address is [email protected] and same goes for MSN Just need a lil guidance or maybe right files from you ...I hope u will help me just revive this phone so i can give it back to customer ,, thanks Mike |
08-22-2006, 13:50 | #4 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Restore main certificate A1_DB2000_36_RED, full flash the phone 2 x MCU and Cust/FS. Change certificate to brown Init SB and then change back to red. Why you are worried about the GDFS, you said you made a backup, also you have the important GDFS values in the security backup. Odia. |
08-22-2006, 14:49 | #5 (permalink) |
Member: 197538 Status: Offline Thanks Meter: 97 | Thanks Odia ... I have restored the DB2000 RED 36.BIP although there were 2 1 was DB2000 RED 36 EROM.bip and the other was the above file ..so i restored the non erom file and now its flashing 2 MCU and FS lets see what happens ..will give u feedback thanks again for your prompt reply highly appreciatted Mike |
08-22-2006, 16:31 | #6 (permalink) |
Member: 197538 Status: Offline Thanks Meter: 97 | Hi Odia ,, Still same problem ... FS getting customisation error .. i did as u told me // Maybe i am not doing something right so please help me boss thanks <ike |
08-22-2006, 18:32 | #7 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | Try to flash 2 x MCU and then STOP, disconnect the phone from the cable, remove battery and then connect phone to cable and software then try to the the Cust/FS on its own. If that does not work please write here the version of the flash files your using or the file names. Odia. |
08-22-2006, 21:30 | #8 (permalink) |
Member: 197538 Status: Offline Thanks Meter: 97 | Odia Thanks a lot for your help .. Actually i was restoring the D2000 RED 36.bip file but than i restored the d2000 red 36 Erom.bip and flashed the files and all was ok .. 100% good and working .,, Once again thanks a lot buddy and thanks for the support Also i have a Z1010 that is flashing and customising ok ..but No network after unlocking and the unlock was done by someone else so i do not have any backup of this phone ,, when u insert the sim card phone freezes on searching and no keys work ,, but its not hardware for sure ,,, if i remove sim card all keys work good ,,, so definitely wrong unlocking ,,, Can u help me on this phone bro ... Thanks a lot again for the K600i ..definitely learnt a lot today and also your post with GCT helped me revive my W550i as well ,,, so i hope u can help me with this Z1010 cuz i saw someone else in the forum after searching with the same problem but No solution found ... Z1010 RED 16 Thanks Mike |
08-25-2006, 17:20 | #11 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Quote:
08-25-2006, 17:34 | #12 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,043 | You will get this message (note I said message, its a warning only not an error) with EVERY unlock of >=36 RED, it not possible to calculate the main digest with a RED certificate, you need to paint to brown first, I have told you this before on sonork. Odia. |
08-25-2006, 17:36 | #13 (permalink) | ||
Sorry man, ive slept since then, but do remember you saying it now! Will you be on sonork later tonight? Havent seen you online for a while! | ||
08-25-2006, 17:46 | #14 (permalink) |
Junior Member Join Date: Jan 2006
Member: 227034 Status: Offline Thanks Meter: 5 | Whene i try to flash the cu/fs i get this error messege: McuId: 71000301FFFFFF, CID: 36, 4 (Red) Mcert: A1_DB2000_36_RED Baud Rate: 460800 Trying: CXC1325414_050331_1652_R3U{0101020401}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 050207 0939 MATCXC1325414_FLASHLOADER R3U, Ok IMEI : 356572-00-141981-0, CID: 36, CDT: 1 0 1 (Red) FlId0: 890D, Intel RD38F4050L0YT OTP_F: 070133306642289A - Locked OTP_U: 1480DC7005D0A922 - Locked FlId1: 8910 OTP_F: 070133306642C0BE - Locked OTP_U: 1480DC7005D0A922 - Locked 050430 1714 MATCXC1327363_SEMC_CS_LOADER_1_R4B Customization Info Err_08.5: Bad Resp Hdr 06, And whene i try to flash the gdfs i get this error messege McuId: 71000301FFFFFF, CID: 36, 4 (Red) Mcert: A1_DB2000_36_RED Baud Rate: 460800 Trying: CXC1325414_050331_1652_R3U{0101020401}.bin PayLoader Certificate Accepted Prolgue Ok PayLoader: 050207 0939 MATCXC1325414_FLASHLOADER R3U, Ok IMEI : 356572-00-141981-0, CID: 36, CDT: 1 0 1 (Red) FlId0: 890D, Intel RD38F4050L0YT OTP_F: 070133306642289A - Locked OTP_U: 1480DC7005D0A922 - Locked FlId1: 8910 OTP_F: 070133306642C0BE - Locked OTP_U: 1480DC7005D0A922 - Locked 050430 1714 MATCXC1327363_SEMC_CS_LOADER_1_R4B Customization Info Err_08.5: Bad Resp Hdr 06, GDFS Write Failed, Time: 0:30 Whe i flash only the mcu it give succesfull messege Can someone tell me what ik have to do thanks Last edited by vormworks; 08-25-2006 at 18:28. |
08-25-2006, 18:50 | #15 (permalink) |
Member: 197538 Status: Offline Thanks Meter: 97 | Man read this thread from the begining and u will find the solution ,, dont be lazy bro ... read the whole thread and u will know ..ODIA has given perfect solution and tutorial in here ,,, first use the restore button than go to KZF folder and special folder and restore D2000 RED 36 EROM.bip than flash both files everything will be ok ..dont forget to init SB Are u sure this phone is CID 36 RED ? be sure before u do this Mike |
C200 Dead after flash with HWK.... | Gr8SightMan | HWK | 4 | 07-03-2008 13:58 |
7373 - RM209, dead after flash with HWK | vmobil | HWK | 2 | 10-11-2007 15:22 |
7373-RM209 dead after flash with HWK | vmobil | HWK | 2 | 10-11-2007 14:44 |
v800 dead after flash with hwk | nader06 | Sony Ericsson | 0 | 03-28-2007 16:24 |
k600I dead AFTER FLASHING WITH hwk | mike67 | Trash | 7 | 08-22-2006 21:30 |
