Nokia 3110c Flashing Problam Still Same After Update HWK v2.0.9.0 1 Attachment(s) Hi Mr. Odia Nokia 3110c Flashing Problam Still Same After Update HWK v2.0.9.0. How can I flash Nokia 3110c from HWK. Regards Rajinder Aggarwal |
bro after updating working fine with 3110c .........u have cable problem |
Rehot or reball flash ic ! 100% work bro! |
@ haji_rahim Brother my cable is prefectly working, Cable is Properly working in JAF, UB, MX-Key. @ lala166 Not hardware Problam only software problam I have flash this phone with JAF & phone is working fine. @ Mr. ODIA I am waiting proper solution. Rajinder Aggarwal |
your cable problme use universel cable |
this is cable problem if you use 5 pin cable this problem come i use 7 pin cable and working fine if u have 5 pin cable pls untick on dual line than flash problem solve 100% if you get success pls report here so other user can see |
try to uncheck dual line mode........... |
yes sam problam for me........ cable is ok...............Bad support for sarasoft team nokia 3110c not flashing in hwk ............101%.......... my hwk micro not flashing in nokia 3110c . I conect the phone & chek 1st & 2ed boot ok then I flash the the phone ERROR DATA BLK ERROR. I Tray in 10 set nokia 3110c sam problem . data mishmach rx:2 pin not conncyted or use 5 pin cabal |
http://rapidshare.com/files/27182147...Team_.rar.html download it and paste in c/program files/nokia/phoniex/ |
Brother , just loaders problum you can check this please another solution untick 1331 then try http://forum.gsmhosting.com/vbb/show...50&postcount=1 br, |
Reinstall HWK Setup as you have mixed loaders. As I see, you have checked 1331 Option but Loader Version 9.17.0 is being used. Br, Shadab Ahmad |
100000000000% work just chenge ppm and cnt version tray to ppm_p version |
I had the same problem with a 5610d, i just uncheked DUAL MODE and SKIP ERASE and flash procedure was ok. my cable is a 7 pin and use saras last version. |
uncheck ext vpp and use only good cabl check local mode test mode on working set to check ur cable , tested on many sets hwk working ok. |
