08-25-2009, 12:59 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: New Delhi, India Age: 45
Member: 190823 Status: Offline Sonork: 100.1604079 Thanks Meter: 554 | Nokia 3110c Flashing Problam Still Same After Update HWK v2.0.9.0 Mr. Odia Nokia 3110c Flashing Problam Still Same After Update HWK v2.0.9.0. How can I flash Nokia 3110c from HWK. Regards Rajinder Aggarwal |
08-25-2009, 13:37 | #4 (permalink) |
Member: 190823 Status: Offline Sonork: 100.1604079 Thanks Meter: 554 | @ haji_rahim Brother my cable is prefectly working, Cable is Properly working in JAF, UB, MX-Key. @ lala166 Not hardware Problam only software problam I have flash this phone with JAF & phone is working fine. @ Mr. ODIA I am waiting proper solution. Rajinder Aggarwal |
08-26-2009, 05:00 | #6 (permalink) |
Freak Poster Join Date: Apr 2006 Location: india
Member: 259084 Status: Offline Thanks Meter: 232 | this is cable problem if you use 5 pin cable this problem come i use 7 pin cable and working fine if u have 5 pin cable pls untick on dual line than flash problem solve 100% if you get success pls report here so other user can see |
08-26-2009, 16:17 | #9 (permalink) |
Freak Poster Join Date: May 2008 Location: gujarat ind
Member: 773986 Status: Offline Thanks Meter: 52 | yes sam problam for me........ cable is ok...............Bad support for sarasoft team nokia 3110c not flashing in hwk ............101%.......... my hwk micro not flashing in nokia 3110c . I conect the phone & chek 1st & 2ed boot ok then I flash the the phone ERROR DATA BLK ERROR. I Tray in 10 set nokia 3110c sam problem . data mishmach rx:2 pin not conncyted or use 5 pin cabal |
08-26-2009, 19:32 | #10 (permalink) |
No Life Poster Join Date: Sep 2006 Location: some where in india
Member: 350232 Status: Offline Thanks Meter: 207 | http://rapidshare.com/files/27182147...Team_.rar.html download it and paste in c/program files/nokia/phoniex/ |
08-27-2009, 06:39 | #11 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 811779 Status: Offline Thanks Meter: 242 | Brother , just loaders problum you can check this please another solution untick 1331 then try http://forum.gsmhosting.com/vbb/show...50&postcount=1 br, |
08-27-2009, 07:30 | #12 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
Reinstall HWK Setup as you have mixed loaders. As I see, you have checked 1331 Option but Loader Version 9.17.0 is being used. Br, Shadab Ahmad | |
09-07-2009, 19:10 | #14 (permalink) |
No Life Poster Join Date: Jun 2006 Location: salina cruz, oaxaca, mèxico Age: 59
Member: 296918 Status: Offline Thanks Meter: 122 | I had the same problem with a 5610d, i just uncheked DUAL MODE and SKIP ERASE and flash procedure was ok. my cable is a 7 pin and use saras last version. |
The Following User Says Thank You to foo_men For This Useful Post: |
09-13-2009, 16:56 | #15 (permalink) |
No Life Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 50
Member: 116314 Status: Offline Thanks Meter: 147 | uncheck ext vpp and use only good cabl check local mode test mode on working set to check ur cable , tested on many sets hwk working ok. |
Nokia 3110c flash problam | gsmsaliya | HWK | 7 | 03-18-2010 08:38 |
HWK v2.0.9.0 after uninstalling PKEY of errors in nokia 1208 and 2310 | joaocavalcanti | HWK | 1 | 10-15-2009 21:28 |
error in update hwk v2.0.6.0 for v2.0.7.0 | cariocacelular | HWK | 2 | 03-27-2008 10:13 |
