06-22-2006, 10:35 | #1 (permalink) |
Junior Member Join Date: Jun 2005 Age: 55
Member: 150145 Status: Offline Thanks Meter: 0 | Nokia 6630 SIM card Registration failed I flash Nokia 6630 with N-box very thing went ok. But when I power on the phone, I get this: SIM card Registration failed. Please what can I do? Nokia 6630 SIM card Registration failed |
06-22-2006, 11:43 | #2 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 48
Member: 53791 Status: Offline Thanks Meter: 17 | It means that the GSM network will not let you in. There are 2 options.. 1. The card is not allowed to access the network because the operatør has not activated the card number in their database. 2. If the card works in another phone it could be because the phone is barred...(Read : Reported stolen).. Twisterfan |
06-22-2006, 17:34 | #5 (permalink) |
Member: 150145 Status: Offline Thanks Meter: 0 | Thank for your reply, its not a stolen phone because I know the owner and he have the receipt and he have been using it almost one year. The sim card work in another phone. I am to fix the phone problem, please friend what can I do? I have flash the phone with image file. Its the same problem ( SIM Card Registration Failed ) Please help. Thank in advance |
06-22-2006, 17:42 | #6 (permalink) | |
Freak Poster Join Date: Apr 2000 Location: hongkong Age: 55
Member: 1269 Status: Offline Thanks Meter: 485 | Can Also Be Hardware Problems Quote:
AS U CAN SEE MY FREIND HERE MENTIONING DIFFRENT OPTION BUT SOME PHONE WHICH HAVE COME TO REPAIR IN NOKIA SERVICE CENTRE IN INDIA HAVE BEEN REPORTED FOR HARDWARE PROBLEMS THE HAGGER IC SEEMS TO BE FAULTY BUT NOT SURE EXACTLY NEEDED CHECK THE HANDSETS ALSO KNOWELEGE IS KNOWBODY WEALTH NARRY | |
06-22-2006, 18:32 | #7 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Quote:
It could also be that the sim card you are trying has been disconnected! Last edited by Odia The Ultimate; 06-22-2006 at 18:53. | |
06-23-2006, 06:09 | #8 (permalink) |
Member: 150145 Status: Offline Thanks Meter: 0 | Thank all for your enfforce and advice. Its not SIM card, I am sure 100%, I try SIM card from 4 different service provider, and I did not used is own SIM card because I think those are the phone giving by one company and they didn't want any othe SIM card to work on the phone. When I flash the new images file, I tested it at offline mode the Fade and battery are ok. The below are the image file which I used, (I download it from N-box web site) COR := RM1_5.050308.COR PPM := RM1_5.050308ME_5.V01 the phone work normal, but now the SIM card Registration failed? The phone problem record are below, 1) SIM card Registration Failed, (the owner bring it for repair) 2) I flash it with Image files COR := RM1_5.050308.VO1 PPM := RM1_5.050308ME_5.V01 Then Nokia name was blinking and it did not power on (wrong images files) 3) COR := RM1_5.050308.COR PPM := RM1_5.050308ME_5.V01 the phone work normal, but now the SIM card Registration failed? (good right image files, but some thing need to be done, which I don't know) It may be hardware, but which hardware? Hardware is not easy to be change, I don't want to damage the phone because I dont have the money to pay back. I sill believe, it's software problem or something more need to be done I need your help friend SIM card Registration failed Last edited by baba70; 06-23-2006 at 06:29. |
06-23-2006, 08:54 | #12 (permalink) |
Insane Poster Join Date: Jun 2005 Location: Australia Age: 50
Member: 152102 Status: Offline Thanks Meter: 2 | Sim card registration failure can occur when two phones with the same IMEI are trying to access the same network, If you chance IMEI numbers on phone keep track of the ones you use and don't double up. |
06-23-2006, 09:39 | #13 (permalink) |
Member: 150145 Status: Offline Thanks Meter: 0 | Thank for coming in Did you do it before or you are forecasting? Sorry UEM IC is for power IC, but I don't have power problem because every thing on the phone is working apart from network. If UEM or any componet is corrupte, it mean some code is missing from the componet, and its software system not hardware. For example if windows system is curropted, it doesn't mean you should change the processor or hardisk, you only need to format the system and restall it again. If UEM is currupted it doesn't mean you should replace. The phone problem is "SIM card Registration failed" Thank a1120028 I did not change any IMEI. No two phone with the same IMEI. We talk about IMEI, because UPPWDE advice me to check it and I check it, there is no problem with it. |
06-23-2006, 11:35 | #14 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Town City Age: 54
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | Look for another 6630. AND TRY TO READ VALUES OF THE SIMREADER POINTS(WAYS) You can short your meter to ground or to eachother point of simreader and COMPARE.I think problem is in simreader points.(Forecast ofcourse). |
nokia 7610 sim card registration failed | nomi | Nokia Hardware & Hardware Repair | 7 | 08-13-2009 19:02 |
nokia 7610 sim card registration failed | alamgarh | Nokia Hardware & Hardware Repair | 6 | 02-14-2009 13:39 |
Nokia E60 Sim card registration failed | nyk2005 | Nokia Hardware & Hardware Repair | 0 | 02-20-2007 13:25 |
nokia 6610 sim card registration failed | armico596 | Nokia Hardware & Hardware Repair | 2 | 10-15-2006 15:09 |
nokia 5210 - sim card registration failed | umr_khan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-29-2006 10:42 |
