09-12-2005, 10:13 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Bosnia and Herzegovina RS Age: 53
Member: 94109 Status: Offline Thanks Meter: 0 | ODIA please help, HWK not attached |
09-12-2005, 11:44 | #2 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: UK
Member: 90865 Status: Offline Thanks Meter: 1 | Quote:
UFS Suite 2.0 fixes this if you are using older program versions. -- WolfMan | |
09-27-2005, 08:46 | #5 (permalink) |
Freak Poster Join Date: Sep 2005
Member: 184630 Status: Offline Thanks Meter: 0 | Im having the exact same problem w my HWK, only had it 2 hrs and hwk not attached comes out on sw. can you walk me through the soldering details step by step. what is ATMEGA pin? thank you |
09-27-2005, 22:53 | #7 (permalink) |
No Life Poster Join Date: Jun 2002 Location: UK/Espaņa Age: 54
Member: 12578 Status: Offline Thanks Meter: 60 | Just do a reflow on the pcb and that normally gets them working again, unless you have not soldered the HWK directly into the UFS box, in which case you will 100% get NOT FOUND!! If you also have the equipment, check the soldering of the legs on the ATMega as already suggested because some are not made very well WBR 2 ALL yeldar |
09-28-2005, 00:25 | #8 (permalink) |
Member: 184630 Status: Offline Thanks Meter: 0 | i still don't understand which parts im supposed to solder to what. the hardware key i purchased slides right in to the 16 needles on the tornado box with a perfect fit and i don't see any area i need to solder. please help w more details. thank you |
09-29-2005, 18:08 | #11 (permalink) | |
-- WolfMan | |
09-30-2005, 20:36 | #12 (permalink) |
Insane Poster Join Date: Feb 2005 Age: 48
Member: 119993 Status: Offline Thanks Meter: 2 | Dear brother WolfMan,,,,, Thanks you very much for your help. I resoldered 28 pins of ATMEGA8L CPU socket. I removed ATMEGA8L and refixed. 16 pins of HWK are connected very well with my Powerflasher PCB. May I know the remaining area which I need to check. Thanks you very much again.... Please help me. . . Yours Lovelysupercat |
09-30-2005, 20:51 | #13 (permalink) | |
I originally could not get mine to work (Twister as UFS base hardware) but it was actually due to early software and HWK module resets not happening because of it. Can you try the HWK in another UFS box? -- WolfMan | |
10-01-2005, 09:55 | #14 (permalink) |
Member: 119993 Status: Offline Thanks Meter: 2 | Dear brother WolfMan,,,, Thanks you so much. I think " HWK not attached " problem is not our ( our means customer ) falt. This is may be production error. These things and boxes are without quality check. ( may be ) Now most of the UFS user are getting problem. Sarasoft shall support service manual or repairing hints for UFS box and HWK I think. Because shopkeeper could not support very well. They don't know which one has falt. ( UFS or HWK ) And they don't want to give money back. After sale HWK, shopkeeper shut their *****. As for me, very difficult to resend to shopkeeper. I live in Myanmar and I bought it in Thailand. And I have only one Powerflasher box. I have no chance to test with other UFS box. Sarasoft made me alot of crying day. I trust them and I bought their things. Now I could not solve and they did not try to solve product error. They did not support very well to customers. Sarasoft shall announce how to solve "HWK not attached" problem. If you have other way, please may I know.. Have a nice everything Yours Lovelysupercat |
Odia Please Help - "HWK NOT AUTHORISED, PLEASE USE UPDATE TOOL" !!! | Unlocker_001 | HWK | 10 | 02-18-2008 15:52 |
Why X160 can not be flashed? Odia Please Help!!! | ecsike | HWK | 2 | 01-30-2007 18:42 |
nbox+hwk program says hwk not attached | henryco | HWK | 10 | 10-21-2005 19:34 |
