09-18-2008, 01:20 | #3 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Between Heaven & Hell
Member: 465130 Status: Offline Thanks Meter: 21 | Read this http:///vbb/showpo...01&postcount=1 |
09-18-2008, 01:34 | #4 (permalink) | |
Junior Member Join Date: Oct 2006
Member: 381067 Status: Offline Thanks Meter: 1 | Quote:
09-18-2008, 01:53 | #6 (permalink) |
Member: 381067 Status: Offline Thanks Meter: 1 | DO NOT, perform this process unless you have Box Auth Error 20, update client reports "use Update Firmware to authorise UFS !" or you are advised to do so. 1. Run the update client. 2. Select your language. 3. Click "Next". 4. Wait until the "Update UFS Firmware" button is enabled and then click it. 5. Select req.fbi file, you will need to get this file from the support area. 6. After a few seconds the process will complete and create a file called xxxxxx.req. (where xxxxxx is your UFS serial number) 7. Send this file to your UFS reseller. 8. When you receive xxxxxx.fbi from your UFS reseller, perform steps 1-4 above. 9. Select xxxxxx.fbi 10. After a few seconds your box will be authorised. Your UFS reseller is the only person who can help with this process, do not ask here in the forum, we will not generate xxxxxx.fbi files for you. NOTES:- 1. the xxxxxx.fbi file sent by your UFS reseller is one time use only. 2. once you have made the xxxxxx.req file, do not perform any other steps on the box, since this will cause the xxxxxx.fbi file to be out of sync. Odia. |
09-18-2008, 07:11 | #9 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Uninstall main suite and support suite v2.0.8.0 and restert your pc. Install support suite 2.0.7.0 and then create xxxxx.req file and send it to your Reseller. After you get xxxxx.fbi file again Install support suite v 2.0.8.0 and do full Update Firmware process. I think Version 2.0.8.0 have some problem creating xxxxx.req file, so use v2.0.7.0, however you can use 2.0.8.0 for updating firmware. Hope this problem will be fixed soon for 2.0.8.0. |
aideč moi a resoudre mon problem de nspro | didino6 | NSPRO | 7 | 04-08-2011 22:20 |
problem de l'installation aide moi svp | hilotman | UST Pro II | 0 | 10-07-2006 22:55 |
aide moi probleme code GRUNDING 5201 RDS | nassim-dz | CAR Electronics | 1 | 08-14-2006 01:18 |
