Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 08-13-2012, 08:07   #1 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
Samsung Champ delux Duos C3312 Flashing Success with HWK.
Flashing procedure.
1.Got Sky/Inf
2. Seclect C3560 Model
3. Select five file
4. Select USB0
5. Press Write flash
6. Press Volum down + Lock key insert USB cable
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., S/n: 132072
HID: F90B967F4160004A
HWK: A1.04-PRO1
Licence: True
LogFile: .\_!_LOG\132072_81320121_20659_LOG.txt
Loaded Settings from: Sams.ini
Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK
Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr )
Release : 2012 February Rev: 1
Insert USB Cable to Switched Off Phone
IF_USB: XGOLD21x
IF_SBL: XGOLD215, Ok
IF_EBL: 2150_OD_KJ2_3.1 3.1, Mode: BB
FL_ID : EC003000, Samsung K5W1Gxxxx 1024+32Mb
Erase Area: 0x00000000 - 0x0FFFFFFD, Erased: 00:00
C3312XXLB1_psi.fls FLASH BUNDLE:
Flash File: psi.fls
Write Area: 0x00090000 - 0x000AF87E, Written: 00:00
C3312XXLB1_slb.fls FLASH BUNDLE:
Flash File: slb.fls
Write Area: 0x60000000 - 0x60046042, Written: 00:00
C3312XXLB1_CDS.fls FLASH BUNDLE:
Flash File: CATFISH.fls
Write Area: 0x63F60000 - 0x63FB845A, Written: 00:00
C3312OXELA5_CSC.dffs FLASH BUNDLE:
Flash File: temp_GT-C3312_OXE.dffs
Write Area: 0x44160000 - 0x4714444E, Written: 01:12
MSL Patched OK: 00:00
C3312XXLB1_BSY.fls FLASH BUNDLE:
Write Area: 0x63200000 - 0x6386A97A, Written: 00:07
Write Area: 0x66000000 - 0x67BD0C5E, Written: 00:32
ShutDown Done
All Done, Time: 02:14
Make [Reset MMI] or Use *2767*3855# at First Start !
MobileLife
Gulbarga
The Following 2 Users Say Thank You to .:MobileLife:. For This Useful Post:
Old 01-05-2013, 12:24   #2 (permalink)
Member: 583627
Sonork: 100.1624187
Thanks Meter: 19
no need to Press Volum down + Lock key
The Following User Says Thank You to nirmaljain For This Useful Post:
Old 04-09-2013, 13:12   #3 (permalink)
Member: 890328
Thanks Meter: 50
it worked thanks,
what about rex60
Old 04-12-2013, 09:46   #4 (permalink)
nksonu_jobner's Avatar
Member: 379001
Sonork: 100.1606686
Thanks Meter: 494
Talking good bro
Originally Posted by .:mobilelife:. View Post
flashing procedure.
1.got sky/inf
2. Seclect c3560 model
3. Select five file
4. Select usb0
5. Press write flash
6. Press volum down + lock key insert usb cable
ufxboot v2.2 (c) sarassoft 2003., id: 62 cf 1 10
ufs_usb v2.8 (c) sarassoft 2007., s/n: 132072
hid: F90b967f4160004a
hwk: A1.04-pro1
licence: True
logfile: .\_!_log\132072_81320121_20659_log.txt
loaded settings from: Sams.ini
regions : Austria,benelux,france,germany,hungary,italy,spain ,uk
language: De,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr )
release : 2012 february rev: 1
insert usb cable to switched off phone
if_usb: Xgold21x
if_sbl: Xgold215, ok
if_ebl: 2150_od_kj2_3.1 3.1, mode: Bb
fl_id : Ec003000, samsung k5w1gxxxx 1024+32mb
erase area: 0x00000000 - 0x0ffffffd, erased: 00:00
c3312xxlb1_psi.fls flash bundle:
Flash file: Psi.fls
write area: 0x00090000 - 0x000af87e, written: 00:00
c3312xxlb1_slb.fls flash bundle:
Flash file: Slb.fls
write area: 0x60000000 - 0x60046042, written: 00:00
c3312xxlb1_cds.fls flash bundle:
Flash file: Catfish.fls
write area: 0x63f60000 - 0x63fb845a, written: 00:00
c3312oxela5_csc.dffs flash bundle:
Flash file: Temp_gt-c3312_oxe.dffs
write area: 0x44160000 - 0x4714444e, written: 01:12
msl patched ok: 00:00
c3312xxlb1_bsy.fls flash bundle:
write area: 0x63200000 - 0x6386a97a, written: 00:07
write area: 0x66000000 - 0x67bd0c5e, written: 00:32
shutdown done
all done, time: 02:14
make [reset mmi] or use *2767*3855# at first start !
mobilelife
gulbarga
nice job and i try and my set is ok now
thanks
wbr
nksonu
The Following 2 Users Say Thank You to nksonu_jobner For This Useful Post:
Old 04-19-2013, 13:36   #5 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
congrats sir by the way you can post here in proper post see this http://forum.gsmhosting.com/vbb/f311...es-hwk-798344/
Old 04-21-2013, 11:49   #6 (permalink)
gsmcrazy1's Avatar
Member: 897524
Sonork: 100,1609543
Thanks Meter: 172
Thanx
working to me with c3300k uart cabel
Best Regards
GSMcrazy1
Old 04-30-2013, 09:09   #7 (permalink)
u2k
Member: 853470
Sonork: KSMGSMLAB
Which files pls cos no neither 3312 nor 3560 file in ufs.
So share the links pls
Old 04-30-2013, 11:08   #8 (permalink)
ABUU YUUNUS's Avatar
Member: 319112
Thanks Meter: 164
Selecting another model name to flash a particular phone is not dignifying to hwk as a flasher and to the supporting team in particular. The team ought to have worked on releasing update that would cater for this.
The Following User Says Thank You to ABUU YUUNUS For This Useful Post:
Old 05-04-2013, 15:27   #9 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
This is right section Bro. b,coz this is unsupported model flashing done by HWK box this is information for others. hope you are understand.
.:MobileLife:.
S. Siddeque
Old 05-12-2013, 07:20   #10 (permalink)
Member: 500429
C 3312 sim lock unlock successfully
Unlock Samsung champ c3312 sim lock done with hwk by selecting C3560 Model
its work,
Old 05-26-2013, 06:58   #11 (permalink)
Member: 824935
Thanks Meter: 11
its work,
can you tell us how to use it bro..?
Old 05-26-2013, 07:06   #12 (permalink)
.:Sanjh Phoenix:.'s Avatar
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
Originally Posted by Gouda786 View Post
good job brother
thank you
Try and post result
Same Method Applicable
With C3312R
Old 06-29-2013, 13:39   #13 (permalink)
ram garlapati's Avatar
Member: 1109437
Sonork: 100.1614597
Thanks Meter: 10
mobilelif.....bro thanks for your solution... c3312 flash
Old 07-04-2013, 16:13   #14 (permalink)
.::Mustafa::.'s Avatar
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
Originally Posted by .:MobileLife:. View Post
Flashing procedure.
1.Got Sky/Inf
3. Select five file
4. Select USB0
HWK: A1.04-PRO1
Licence: True
IF_USB: XGOLD21x
Flash File: psi.fls
Flash File: slb.fls
ShutDown Done
MobileLife
Gulbarga
brother i need flash files this model plz upload on media fire thanks in advance
Old 11-06-2013, 18:28   #15 (permalink)
joshvimalraj88's Avatar
Member: 1625194
Thanks Meter: 30
bro but my mobile is dead after falsh
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.27400 seconds with 9 queries
