09-15-2007, 20:37 | #1 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 90869 Status: Offline Thanks Meter: 3 | Samsung E250 after unlock or flashing, no network on 900 or 1800Mhz I did 2 pieces, first unlock, and than when I saw limited network on 1800 mhz ( german t-mobile and vodafone was ok, eplus limited service) so then I flashed them, but the same. After 2 days I know, it is an existing problem, but no answer. If anybody would ask about imei 000000.... no, my imei is the same, the original. And I also tried eeprom reset with code, and band secection also.. So how can I repair it with HWK? |
09-15-2007, 20:58 | #4 (permalink) |
Member: 90869 Status: Offline Thanks Meter: 3 | no, it is not blocked, read after about it... something happened with the signal, but 900mhz ok, 1800mhz not, but if you go to a "strong" 1800mhz place, signal can be weak, but after 4-5 seconds drop away. Something wrong inside the flash file, 1 solution is known, flash with UST PRO and will be good, but I have original HWK and it supports E250, so I would like to hear a solution from anybody or from them. |
09-16-2007, 09:17 | #7 (permalink) |
Member: 90869 Status: Offline Thanks Meter: 3 | Today I already did, e2p file was downloaded from support, I flashed to the phone, but everything is the same, except I am still in deep sh*t, imei changed. I wanted to write back, but rebuilt imei button is inactive in the software. I am 90% sure, that this weak or limited network problem is a little bit different, that can people think after the first look... Please sy give a solution with HWK, I dont have ust pro or another box. |
01-04-2008, 00:49 | #9 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | try to read a fullflash from a working set then write it to your abnormal set perhaps problem will be solved else there is a free software use a normal com cable this software is called free samsung tool and it includes repair network option try it to fix rx tx |
The Following User Says Thank You to f164 For This Useful Post: |
01-04-2008, 03:26 | #10 (permalink) |
No Life Poster Join Date: Jun 2002 Location: *Portugal* Lisbon* Age: 45
Member: 13223 Status: Offline Thanks Meter: 59 | This is not a e250 i think itīs E250D itīs diferente flash . E250D after direct unlock no network you must use unlocke e2p in E250D and type codes. try to flash phone using e250D flash but after flash Unlock e2p. |
01-04-2008, 14:45 | #13 (permalink) |
No Life Poster Join Date: May 2005 Location: CANADA Age: 42
Member: 149415 Status: Offline Sonork: 100.1609895 Thanks Meter: 77 | problem solved flash with this file in support area E250_MCU_FULL and after this writhe E2P but no ring and imei alwayse 00000000000000!!!!!!!! |
e250 after unlock ang flash can't call if you send textmessage error | eljhay | UST Pro II | 6 | 07-06-2008 14:25 |
5200 No Network On 900 Mhz after Cert Write | mishaelwillo | Nokia Base Band 5 ( BB-5 ) | 0 | 10-16-2007 01:51 |
Razor V3 any solution for NO NETWORK ON 900/1800Mhz | laboratory_gsm | Motorola Hardware Repair | 10 | 09-06-2006 00:33 |
A70 after unlock & flash no network??? | chmielgrzegorz | SST-Dongle | 3 | 07-18-2006 10:47 |
